Question about Refrigerators
ICEMAKER CONNECTION CAN NOT FIND WHERE TO CONNECT WATER LINE FOR ICEMAKER ON KENMORE 795 7730 BOTTOM FREEZER. MANUAL NOT VERY PLAIN
    Champion:
  • 363 Answers
Normally the water connection is at the bottom right rear. There should be a blue valve.
Posted on Jul 22, 2009
We can't get our icemaker to work in our Kenmore bottom freezer refrigerator-model 795.7160. It is not making ice-you can hear it go through the steps and even dumps, but there is no ice.
check your water line and filter. Defrost the freezer in case its frozen. Also check the water line where it enters. Check for leaks under the valve. Otherswise you may have a bad icemaker.
Jan 10, 2018 | Kenmore Refrigerators
The icemaker on my older kenmore side by side refrigerator doesn't make ice?
What you are probably dealing with is the little valve called (Water Valve) on the back of side of the refrigerator usually down low towards the bottom right hand side if you are facing the back of unit. Its the part that the water line run into and also will be a water line coming out of it going up the back of the fridge and goes thru into the freezer to the Ice maker in the freezer
Aug 08, 2012 | Kenmore Refrigerators
Icemaker not making ice
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Will not dispense ice or water, beeps when lever is pushed, no interior light in frig part. both frig and freezer work, freezer light works
Jun 06, 2010 | Maytag MFI2569VE Bottom Freezer French...
My Kenmore refrigerators (model #79177990) ice
Ice inlet tube may be frozen up inside of Fridge. Thaw it out with a hair blower. Shut of water supply and disconnect the water line that goes into the back. Use a flexable item at the connection to see if will go all the way through to the icemaker. I used a zip tie.
If you still don't have water going to the icemaker, you may need to replace the "Water Inlet Valve" at bottom back right of your Fridge. Easy to Do.
Jun 02, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
I connected water line to freezer inlet at back of our used Maytag bottom freezer refrigerator model mbf2255kew. now how do i start the icemaker? I do not have the manual.
Most ice makers have a wire bar that needs to be pushed down (from a locked position.) Then after 1 - 10 minutes, you should hear a sound for about 10 seconds that is a solenoid valve opening, letting the water pour into the ice maker.
If problems continue, please report back here. OK?
Aug 05, 2009 | Refrigerators
I have a Kenmore refrig./ model# 363.9741714
The problem is actually not the ice maker itself. The problem is the electric solenoid valve in the rear bottom of refrigerator. If you follow the water line on the back of the unit down to the bottom and replace the valve that it is connected to then your problem will be solved. Hope this helps. Good luck cj2176.
Jul 25, 2009 | Kenmore Refrigerators
How to hook up water line from sink to icemaker.
You have to put a T between the cold water valve and the faucet, then run a plastic or copper line to the refrigerator(the size could vary from 1/4' to 3/8", you have to look at the water valve in the bottom back of the refrigerator).
Apr 24, 2009 | Freezers
Refrigerators Logo
154 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
