How do you open the subwoofer/receiver/amp on a Frisby FS-5020BT 5.1 Channel Bluetooth Surround Sound? I need to fix the center channel output.
furion187
  • 54 Answers
SOURCE: 4 ohm and 8 ohm speakers
You can plug in higher ohm speakers , the higher the ohm the higher the resistance is, it is a danger when you plug lower ohm speakers into a higer ohm Amp , at a high volume that will cause them to blow , the center speaker would be fine to use a higer ohm speaker , your best choice is to buy a Active Subwoofer, which means the sub has it's own power supply , and u can blast the thing as much as u like , thn u can turn the bass down on all the other speaker's so u can play it louder , and have the sub turned up has high as u like , this is the best way to get great sound with high volume , buy a Active sub woofer , any active subwoofer is ok , a active sub woofer has its own volume and inputs on the speaker ,
Posted on Dec 09, 2007
  • 13 Answers
SOURCE: center channel
Just to rule out the easy solutions, have you made sure no settings changed? Make sure that you didn't accidentally turn off any surround sound settings or turn off the center channel in the MCACC setup or the like (I have the VSX-D814, so your receiver should have MCACC as well). If you're sure no settings changed and the center channel should be working according to the receiver, then it would appear that the center channel amp went out in the receiver. You can either get a Pioneer service center to take a look at it, or if you're comfortable with electronics, I believe you can get the parts straight from Pioneer.
Posted on Dec 20, 2007
lynchms
  • 93 Answers
SOURCE: Center Channel not working on pioneer vsx-d608
Be sure the sound source has a center channel output ie. not a 2 channel source only, try the test tone setup for 5 or 6 channel balance, if no sound from the center channel still then it is looking like maybe the center channel is blown.
Posted on Jan 28, 2009
SOURCE: Kenwood VR6070 speaker/amp problems
unit needs repair. Look at the b speakers. Conect a speaker or two to the B position. If you have no sound than your surrond sound is ok and the unit is bad. Sound comes directly into the b speaker and not threw the surrond system. My 6070 has a cold start up problem. no sound. time to purchase a new one. to costly to repair.
Posted on Feb 09, 2009
SOURCE: center channel is too quiet for dialogue from PS3 movies
turn the other speaker decibal levels down then increse main volume until you are satisfied.
Posted on Feb 06, 2010
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
How do I hook up speakers?
If you are referring to 5.1 surround you would have to have 5 speakers plus one powered subwoofer. The front left and right as well as your center channel to the majority of the sound reproduction with the rear channel being there for intricate sounds and background noise. The subwoofer will be a preamp output from your receiver. That signal will then get amplified by your subwoofers power amp. Generally subwoofers are tucked away in a corner while the other 5 speakers form a box around your viewing area.
Feb 11, 2010 | Pioneer VSX-453 Receiver
My center and surrond sound speakers don't work with just one output from my dvd do I need to purchase an amplifier also?
You need to first check whether your dvd player supports dolby 5.1. If it supports that then you could connect the digital output of your dvd player to a surround receiver such as Yamaha RX-661. You can then connect all the speakers to the output of RX-661 which has 7 inbuilt amplifiers for all the channels. Its a 7 channel receiver and would be useful with DVD-Audio and such that comes in 7 channels. For your requirement any 5 channel receiver will do. Please let me know if you need any more clarifications.
Jul 28, 2009 | Audio Players & Recorders
NO INSTUCTION MANUAL. CAN NOT GET IT TO WORK AS A 2 CHANNEL AMP.
Click Yamaha Support and download required user manual of receiver to figure out to set it on 2 channel output.
Need further help, please intimate receiver model number.
Mar 18, 2009 | Yamaha RX-V870 Receiver
Best amplifier for bose 901 VI speakers
By all-in-one amplifier that handles the surround I think you mean all-in-one receiver or preamp. Amps are just big dumb muscular power supplies for speakers.
The source control and digital decoding could be handled by a modern AV receiver with multichannel analog outputs for driving separate amps or you could get a digital AV preamplifier/control unit functionally like this Adcom. Prepare for sticker shock.
http://hdtvdreams.com/Adcom-GTP-870HD-7.1-Multi-Channel-Processor/Preamplifier-GTP870HD.aspx
Understand that EACH PAIR of Bose 901's will require its own DEDICATED two channels of amplification AND someplace to jack in its Active Equalizer - between the line level source and the power amp.
Conventional speakers can probably run off the receiver's amplifiers since they don't/can't/must not have the Bose Active EQ in line with them.
Having a single pair of 901's plus a passive subwoofer or two in the same room for accurate 6- or 7.1 surround would require at least four stereo amps or some combination that adds up to 8 channels.
In my own system I have a Pioneer VSX-36TX Receiver (with 5 potential channels of amplification for Left, Right, Center, two Surrounds) doing light duty as the control and routing center but ONLY driving the Center (two Kenwood 777's) and Surround speakers (Bose 301's). I have a Carver 5-channel amp pushing the Bose 901 Front speakers (100Wx2), two dbx Subwoofers (110Wx1) and the Bose 301 Rear Surround speakers (60Wx1).
You could probably get by with a powerful 2-, 3- or 4-channel amplifier to push the 901's and subwoofer(s) as I did. It's the cheapest way out if you get a decent AV receiver. Once you set up the levels and delays the receiver does all the thinking and controlling for you.
Mar 18, 2009 | Bose 901 VI Main / Stereo Speaker
I have pioneer receiver Vsx-454 i want to know if this receiver is 5.1 surrounds
Yes. It is 5.1 surround. There are 2 front channels, 1 center channel, and 2 rear channels which comprise the "5" in 5.1 surround. The pre-amp output channel for a sub is the ".5".
Jan 11, 2009 | Pioneer VSX-454 Receiver
How to hook up bose series 2 eq to onkyo tx sr 875 receiver.?
I wrote most of this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great! I see on the SR875 there are Pre Audio OUTS. This is easy.
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Jan 07, 2009 | Bose 901 VI Main / Stereo Speaker
 Grubhead
Grubhead
