My rinse and spin cycles,it goes through wash but not the other two,also where on these machines are the filters located.
  • 667 Answers
Call a handyman
Posted on Dec 23, 2016
My washing machine top loader once reaches the spin cycle, with 21minutes time remaining, it goes back to rinse and repeats the cycle. What is the problem of my washer and how do I fix it? Thanks
If the washing is not distributed evenly by the time it reaches the rinse/spin cycle, it goes back to rinse cycle. Be present at the machine when it reaches the spin cycle. observe the drum to see if it is of balance and swaying to the sides, if so distribute washing evenly. Usually happens if there is a big garment or more with smaller items,
Oct 06, 2014 | Samsung SW62ASP Top Load Washer
Why does the lid lock light start flashing after the wash cycle and will not rinse or spin?
Lift lid, stick screwdriver into slot where lid latch-pin inserts and see if it goes into the cycle. If so, try adjusting position of latch.
Sep 01, 2014 | Washing Machines
Hello my washing machine has stooped... it will keep washing but will not rinse or spin out.. please help
sounds like you have aproblem with the lid switch , that will keep yoor unit from spinning after the wash cycle then it goes to a rinse cycle as long as the unit cant spin it then can't rinse.
Mar 10, 2011 | Estate TAWB600JQ Top Load Washer
LG WD-8013F wont spin
Hi deppgirl,
I checked the lint filter at the front bottom left hand side and it was full of junk.  Once emptied it worked a treat.  Pull the flap down and turn the large knob anti-clockwise and pull to remove.  Good luck.
Mar 29, 2008 | Washing Machines
Washing machine not spiining
sump hose filter blocked, running out of draining time, when you put it on again it allows more time to drain, remove sump hose and clean out internal filter.
Dec 10, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Full of soap
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Plug off the wall, refer to manual re. outlet filter. Siphon out maximum water by removing the tube from behind machine which goes into wall drain. (refit this after cleaning into EXACT position) Clean outlet filter and refit. Good luck. When your outlet filter is clogged or blocked, the machine refuses to spin.
Nov 28, 2007 | Frigidaire ATF6000ES Front Load Washer
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Machine stops and goes to end half way through a cycle
Check the filter is not blocked it sounds as if it cannot drain in the time allowd at end of wash cycle. Regards Advisor
Jan 17, 2007 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
