Question about PANDIGITAL Office Equipment & Supplies
I have a Pandigital scanner model panscn09 that will not scan photos. I don't know what to check
  • Steven Duncan
    Steven Duncan Dec 23, 2016
    I dont think so i switch to win 10 I'll have see what i do for an update. Thanks
  • 667 Answers
Check this
Posted on Dec 23, 2016
  • 1 more comment
  • Steven Duncan
    not much of an answer
  • woodzowl307 Dec 23, 2016
    you have the software installed
    Printers & Scanners/
    Pandigital Handheld Wand Scanner (PanScn08)
    editor rating: fair
    June 21, 2012
    Scans without a computer. Includes microSD card to scan to. Highly portable. Can set resolution, color mode, and file type.
    Can't confirm scan is okay without a computer. Included optical character recognition software is highly limited.
    Bottom Line
    The Pandigital Handheld Wand Scanner (PanScn08) is a reasonably capable piece of hardware, but you'd better already have the software you need, or be ready to buy it.
    By M. David Stone
    The Pandigital Handheld Wand Scanner (PanScn08) ($109. 99 direct) has a lot in common with the Pandigital Portable Wand Scanner with Feeder Dock (PanScn09) ($119. 99 direct, 2. 5 stars) that I recently reviewed. It has also some important differences. The most obvious is that it doesn't include a dock, which adds size and weight along with a paper feed capability. If what you need is strictly a wand scanner, with an emphasis on portability, however, the PanScn08 is the more appropriate choice. (And note that it's available in several essentially identical versions, some of which add a pair of letters to the name, after the 08.)
    //Compare Similar Products
    PlanOn DocuPen Xtreme X05
    $299.99Amazon see it
    Visioneer Mobility
    $140.00Amazon see it
    At 1.4 by 10.4 by 1. 5 inches (HWD) and 0. 5 pounds, the PanScn08 isn't as small as the PlanOn DocuPen Xtreme X05 ($369. 99 direct 3. 5 stars) wand scanner, and it doesn't look as much like an actual wand. However, it works the same way, letting you scan by starting at the top of the page, and scanning down in a single sweep. Rollers on the bottom of the scanner make it easy to sweep down the page smoothly and evenly.
    Another feature the PanScn08 shares with the DocuPen Xtreme X05, as well as with the PanScn09, is that it scans to memory rather than to a computer. Pandigital includes a 2GB microSD card to save the scanned files to. When you're ready to move them to a computer, you can use the supplied microSD adaptor to plug the card into your computer, or you can connect using the supplied USB cable, let the computer recognize the card in the scanner as USB memory, and copy the files.
    Setup and Scanning
    Wand scanners don't generally need a lot of setup. With the PanScn08 you only have to insert the microSD card and rechargeable battery, and let it charge for two hours. While you're waiting, you can optionally install NewSoft Presto! PageManager, a document management program, and the only application Pandigital includes with the scanner. The program is limited in many ways, but it includes an OCR module that will let you convert scanned documents to editable text or searchable PDF files.
    Not so incidentally, the rechargeable battery is one of the other differences (besides the dock) between the PanScn08 and PanScn09, and it's the one difference in the PanScn08's favor. The only other important difference is that the PanScn09 includes a color display that lets you see a thumbnail of the scans, so you can rescan if there's something obviously wrong with the image. With the PanScn08, you have to wait until you get back to your computer and transfer the files, at which point you may not have the originals to rescan.
    Scanning with the PanScn08 is easy. The scanner offers one button to toggle between color mode and grayscale, one for 300 ppi versus 600 ppi, and one for JPG versus PDF format. Simply choose your settings and scan. As with other wand scanners, I didn't have any trouble getting good scans from the beginning—at least, not at 300 ppi. It took a few tries at 600 ppi to learn to slow down to the right speed.
    Scan Results
    Given the one program the scanner comes with, the only two applications I could test it for were optical character recognition (OCR) and document management. It didn't score well on either, but only because of limitations in the software.
    For OCR, the combination of the scanner and PageManager did reasonably well at recognizing text. However, the formatting was so far off the mark that I couldn't even determine what font sizes it managed to read without a mistake. Similarly, the document management score suffered from PageManager's limitations for converting files to searchable PDF format.
    Pandigital doesn't include any photo editing software, but I scanned some photos to get a sense of the photo scan capability. Most of the scans qualified as roughly snapshot quality, which makes the scanner good enough for casual photo scanning, but not suitable for anything more demanding.
    The Pandigital Handheld Wand Scanner (PanScn08) is potentially attractive for portable scanning, but is also severely limited by the software Pandigital includes. If it came with a more capable set of programs, as with the Editors' Choice Visioneer Mobility ($199. 99 direct, 4 stars), for example, it would be a much stronger contender. As it is, it earns a recommendation as being worth considering, but only if you already own the software you need or are willing to buy it elsewhere.
Pandigital scanner for photo negatives. the setup is for Windows xp. I have windows 10. I have 64 bit and not 32 bit which what it requires. The model number is PANSCN05, serial # 0105000510800606.
Older scanners are not compatible with newer operating systems and if the manufacturer does not provide you with a driver you are SOL and have to buy a new scanner that will work with your OS. End of story.
Aug 22, 2017 | PANDIGITAL Computers & Internet
Why will scanner only scan 1 photo?
possible lack of memory where ever it's scanning to?
Jan 04, 2015 | PANDIGITAL Computers & Internet
Panscn10rd manual
Not enough information . Is it a usb type cable that recharges the wand ?
What voltage is your electricity supply this is extremely important as I blew up a printer I purchased on the internet as US uses 110v and Aus uses 240V AC. I found Amazon has a product that might be what you are looking for but find out what AC voltage and country it runs on before even thinking about purchasing it.
Apr 23, 2014 | PANDIGITAL PANSCN09 Handheld Wand Scanner...
Wand Scanner - panscn08 buttons do nothing
Yes follow the first steps to set up the scanner (charge it, properly insert the memory card, etc.) Then you are ready to scan
Once you press the SCAN button and the Green LED stays lit its time to roll the scanner down your document to be scanned. When finished press the Scan button again to STOP the scan. If successful your Document count in the display will move from 000 to 001. That is the only indication that you now have a successful scan.
Next Press and hold the SCAN button until the display goes blank.
Now you can remove the memory card (by pushing in and it will release). Place this memory card into a memory card reader on your computer to transfer and view your scanned documents. Rinse and repeat.
BTW, I found a quick start guide for this Pandigital Handheld Wand Scanner Model PANSCN08 at:
Good Luck!
May 04, 2012 | PANDIGITAL PANSCN Office Equipment &...
I installed Scan2Mac n my iMac. Mac recognizes Scanner and I can read SD card. When I select Scan to Mac - and scan - it saves to SD card and not Mac. I reinstalled and same thing happens
Are you running OSX Lion? If so, that may be the issue.
I have 2 MacBook Pros, one running Lion, one Snow Leopard.
The Scan2Mac software works fine on the Snow Leopard machine - takes only a few seconds to create image in a MBP directory.
It does not work at all on the Lion machine. Worse, the scans to the memory card take up to 2 minutes, before the scanner will process another photo.
I installed the Scan2Mac app on both machines from the same dmg.
The Pandigital website offers no updates to the software, which was created in 2009.
Aug 24, 2011 | PANDIGITAL PhotoLink PANSCN06
How do I scan negatives?
You can try scanning negatives the same way you scan prints, but the results may not be great. Scanners that are designed to scan negatives usually have some way to put light behind the negative to make sure it scans with enough contrast. They often also come with special holders for negatives. I don't know if your model was specifically meant to do negatives, but you can't hurt anything by trying.
After you scan a negative you need to convert it to a positive. The scanner may have come with software that can do this. If not, IrfanView is a free program that can do that as well as much more. It's a great general-purpose image viewer, so it's worth downloading in any case.
May 13, 2011 | PANDIGITAL PANSCN05 Film Scanner
Scanning photo's on Pandigital Photolink - One Touch Scanner. Scanner is only scanning approximately 1/2 inch of photo
check the set up procedures of the scanner and select the proper size of paper. it sounds like the setting is wrong
Feb 19, 2011 | Office Equipment & Supplies
Pandigital mini photo scanner pictures have white lines on them
have a pandigital scanner that worked great for about 500 pics then lines stared to show up, tried cleaning and calibrating but did not help, decided to take apart and found that the glass on the surface of the scan part was dirty, cleaned the glass and put back together works perfect, took about 10 minutes to fix
Sep 05, 2009 | PANDIGITAL PhotoLink PANSCN06
94 people viewed this question
Top PANDIGITAL Office Equipment & Supplies Experts
Are you a PANDIGITAL Office Equipment and Supply Expert? Answer questions, earn points and help others
