Dvd player not playing, region appearing - Audio Players & Recorders
    Problem Solver:
  • 5 Answers
Is either your DVD or your DVD player a non-US product? Did you buy your player new from a reputable U.S. retailer? Do you have a boot-leg or e-bay purchased DVD you are attempting to play? Any of these could cause this problem.
Posted on Aug 01, 2009
Incorrect region for panasonic dvd player
The player is set to a fixed region relevant to the country you are in for play back of DVD disks and the disk you are trying to play is not compatible with the country you are in! You need a multi region player or to have your current player unlocked to be multi region! Which country are you in?
Oct 02, 2014 | Panasonic Televison & Video
Cant play a region 1 dvd
The DVD and *and* the DVD player both have a region code embedded in each. A map of the regions used appears below:
Regions 0, 7, 8 & 9 do not appear as they represent "No Region Coding" "Unused" "Cruise Lines" and "Region Free" respectively.
A DVD player will only play a matching region code DVD, or the player OR DVD have one (or more) 0, 7, 8, or 9 region codes imbedded. You'll not be able to change the DVD code, but you *might* be able to change the region code of your player. Computer DVD players can sometimes be flashed to a new region more readily than the entertainment system DVD players, but it relies solely on the manufacturer and model of the player. Some require file be downloaded and run, while others require a DVD or CD be created and played with a specific file saved on it. Here's a link to results that discuss how to change the region code for DVD players. You'll need to know at the very least the manufacturer and model number of you player to begin.
I hope this helps and good luck! If you found this helpful, please rate my reply 4 "thumbs up". Thanks!
Jul 12, 2011 | Audio Players & Recorders
Message "wrong Region" appears in my Sony DVD -
DVD region is an anti-piracy method to block DVDs from other countrys to be played on a region where that DVD isn't available for selling. You still can watch that DVD by changing the DVD Player region code from options but be aware that you have a limited number of changes, after changes reach 0 you cannot change DVD region code anymore and your DVD player will be stucked to a certain region that you selected.
Nov 02, 2010 | Sony DVPFX810 Portable DVD Player
Mac book pro is currently locked to region 1,
Home Index DVD Region Codes
In order for you to view a DVD's content, the region code on the DVD and the region code for DVD Player must be the same. Your DVD drive is automatically set to a region code the first time you play a coded DVD. If the region code for a DVD does not match the current region code for DVD Player, a dialog appears for you to change the code for DVD Player.
IMPORTANT: You can set the region code for DVD Player only five times (including the original setting). The fifth time you change the code, it will be permanently set. The following map and table indicate the code for the various regions. Some DVD discs can be played in any region, and are sometimes referred to as having region code 0. These discs can be played regardless of the region to which DVD Player is set.
Mar 30, 2009 | Apple Computers & Internet
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Can't play region 2 dvd's on my player
Newer DVD224 is actually DVD-224ss - small print on front of manual. There are two possible hacks:
DVD224SS (This worked for me)
1. Open the DVD tray
2. Press STOP button on the remote control
3. Press 70
4. Press MENU
5. Use the numeric keypad to select your region code number (0 – 6).
OR
DVD224 (224SS)
2. Press STOP button of remote control
3. Press the digit number buttons “2008” of remote control.
4. Press MENU
Region code will appear, select your region code number.
Jun 22, 2008 | Coby DVD-224 DVD Player
Change Change Oppo DV-980H DVD player to play DVD's from all regions.
1. Press Setup.
2. Press "9210" in quick succession. A new window should appear.
3. Press "0" to set the Region to R0.
4. Press Setup to exit.
Dec 12, 2007 | Oppo Digital DV-980H DVD Player
LG DVD player LG276
I picked up a LG DV276 DVD Player here in Australia but I am from the United States so I own region 1 DVDs. I unlocked my new player by instead 1. Open the tray. 2. Press 0 0 0 0 on the remote and a Menu will appear. 3. Press 0 for region free. 4. Press pause and power off.
I can play everything now, Aussie and US DVDs. Thanks LJ66.
Dec 01, 2007 | LG DV276 Recorder
Dvd region codes
Try this (for a LH-T360SE)
Open disk tray and press 0000, a two line menu appears with "Edit Region _" and "Region Code:x" put in required region (presumably 0) and press enter. Region Code:0 appears. power off and enjoy.
region code 0 is No region restrictions.
Nov 03, 2007 | Televison & Video
Play all region dvd's
Found this hope it helps Multi-Region: * With no disc in the machine switch it On * Open the tray * With the remote enter: 2, 4, 0, 5, 9, 1 and 5 * A region menu appears indicating current * Press Enter until the region is set to 9 (Region FREE) * Close tray
Sep 10, 2007 | Televison & Video
170 people viewed this question
 Grubhead
Grubhead
