My dial to change from normal to heavy duty completly broke off where can i replace it
    New Friend:
It all depends on what type washer/dryer you have. If you still have the manual that came with your washer/dryer, it will have a parts list in it. Find the part you need and write down the part number. It will list the phone number you can call to order the part.
You can always go right on eBay and type in the name of your appliance and the model number and what part you need. It will pop right up.
Posted on Dec 23, 2016
  • 667 Answers
Where its broken
1994 lower control arm broke at balljoint
What brand of car? Some brands have after market heavy duty replacements that are made from heavy duty tubing instead of the sheet metal pressings typical for factory parts.. We have seen them that failed due to the fact that pivot bushings wore completely through and into the pressed sheet metal that had been holding the bushings, and the wear through the sheet metal was progressing rapidly toward failure. Check all the other front end control arm components for similar progressive wear out. This kind of thing can be dangerous. It usually will give brake steer in inconsistent directions before failure.
Mar 21, 2015 | Cars & Trucks
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Kenmore washer - water won't drain. It stops
If the water drains between the wash and rinse cycles, your motor and pump are probably OK. If this is a machine with a dial, try a different cycle, like normal instead of heavy duty. If that works and the machine completes the entire cycle then the timer probably has a bad spot. You might try to find a replacement timer if that is the case although I didn't have any luck with my 10 year old washing machine. Best of luck
Mar 20, 2010 | Washing Machines
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
