Question about Miscellaneous
To Verify my Registration as an Armed Response Officer & Security Detail
Transfer of registration of ICV from QLD to NSW potential problems
you will need a road worthy certificate in NSW as the certificate from QLD is not recognized there
you will have to do it immediately you have a permanent address unless you are in the armed services
you then request a refund from the main roads QLD for the balance of registration and pay full costs in NSW
Jun 01, 2016 | Cars & Trucks
To turn the beep sound off when system is set to armed
Troubleshooting FAQs - Solve Problems Quickly by ...
The ADT CorporationHow do I silence low battery beeping? ... Why is my ADT Pulse security systemreceiving an unavailable message? ... How do I fix a disconnected camera? ... by a motion detector while the system is armed, the burglary alarm will sound. ... Some common events that may cause a motion detector to set off a false alarm ...
Five Steps: How to Stop a Beeping Security System
Vector SecurityFeb 9, 2015 - The shrilling sound of a continuously beeping security system is enough to drive anyone crazy. A power outage, faulty wiring or bad batteries ...
The Top 15 Questions about ADT Home Security Systems ...
Oct 10, 2012 - How do I turn off the voice descriptions but keep the chime sound on?... If your time on the Lynx system is not set all you need to do is push your user code + # + 63. ..... When our security alarm is not armed it beeps every few seconds ....Reasons to Install Security Cameras in your Home ยท Small Business ...
Jan 03, 2016 | Home Security
Replaced battery in my 1993 jeep grandcherokee limited now security system seems to cut fuel off seconds after engin fires
Here's some info as it sound like the theft deterrent is armed.
Reset Procedure
NOTE: This information applies to a Vehicle Theft Security System (VTSS) that was armed when the battery was disconnected and reconnected.
When the armed VTSS senses that the battery has been disconnected and reconnected, it enters its power-up mode. In the power-up mode the alarm system remains armed following a battery failure or disconnect. If the VTSS was armed prior to a battery disconnect or failure, the system will have to be actively or passively disarmed following a battery reconnection.
The power-up mode will also apply if the battery goes dead while the system is armed and battery jump-starting is attempted. The engine no-run feature will prevent the engine from starting until the alarm system has been actively or passively disarmed.
Passive disarming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the liftgate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter.
Once the alarm has been activated (horn sounding, lights flashing, and the engine no-run feature), either disarming method will deactivate the alarm.
Depressing the Panic button (if equipped) on the RKE transmitter will also disarm the VTSS, but the horn will sound and the lights will flash for about three minutes as part of the Panic feature. The horn and lights can be stopped by pressing any of the RKE transmitter's buttons or driving the vehicle above 15 mph.
Feb 11, 2013 | Dodge Stratus Cars & Trucks
i do have great understanding of security officer
Jan 16, 2013 | Checkpoint Safe At Office 500 Wired...
How do verify my friendster?
Registration won't be complete until you verify the email address you registered with. Aside from confirming that you have access to that email address, it further improves the security of your friendster account.
To Verify your email address
- Just wait for the email from friendster with the subject: 'Please verify your email address' (this usually comes within seconds of signing up)
- Once you have this email. open it, look for the 'Verify Email' button and click it. It's as simple as that.
- In case the button doesn't work, you may copy and paste the verification link which will be provided in the same -email.
Thanking you
Dec 18, 2010 | Yahoo Mail
Yahoo adress email setup
Go to Yahoo Mail home page to create your email account at Yahoo.
Click the 'Sign Up' link that appears near the top of the Yahoo home page.
Enter your name and other information in the fields provided.
Choose Your Username and Password
Create a username that you will be comfortable using for a long time
Type the username you choose in the field provided.
Choose a password when you have successfully entered a unique username.
Passwords must be at least 6 characters long and keep in mind that passwords are case-sensitive. You will be asked to type your password twice to ensure accuracy.
Enter Security Information and Verify Your Registration
Select a question from the following drop-down menu as your security question. Yahoo will ask you this question if you should forget your password in the future, in order to verify that you are the correct user.
Type in your answer to the question in the field below.
Enter your birth date, zip code and any other requested information in the fields provided. Entering an alternate email address is not required but it's good to give Yahoo personnel a place where you can be reached if for any reason you do not have access to your Yahoo account.
Verify your registration by typing the characters you see shown in the last section of the registration page into the field provided.
Read the Terms of Service thoroughly and print a copy for your records.
Select 'I Agree.' You have successfully set up your Yahoo email account
Jul 14, 2010 | Yahoo Mail
What is the red flashing light on top of the the driver's side dash?
Don't worry. That is the light that tells you the vehicle's security system is armed - nothing more. Many Ford/Mercury vehicles have it, as does my 2004 Mercury Marauder.
You can verify this information at Just click on the link for 'owners' then 'owners guide'.
Hope this helps!
Apr 27, 2010 | 2003 Mercury Grand Marquis
I changed my battery and don't have the security code for the radio. I have the 8 digit code the radio flashed but need the security code to have it work.
Just go to your local Honda dealer armed with your registration and driver's license. They will look up your code by the VIN.
Nov 29, 2009 | 2003 Honda Civic
Registration fix for Ultra 2
Dec 16, 2008 | Serious Magic ULTRA (20020000E) for PC
Miscellaneous Logo
20 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
