Question about Hisense Televison & Video
My hisense flat screen LED blacklight tv, model: LEDN32D20 can't just be turned on,whenever I turn it on its blinks continuously.... Is the any how I can use remote to sort such letter out?
  • Hisense Master
  • 6,694 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Posted on Dec 23, 2016
SOURCE: TV does not turn on
needs a new power supply board
Posted on Jan 23, 2009
  • 11800 Answers
SOURCE: lg flat screen model 26lx1d
The blinking red light signals the fact that the power source is in protected mode - it's fully functional (as the green light also shows) but has been shut down by it protection system.
The protection system of the source is engaged when 2 things happen: either there's a short on one of it outputs (you will have to test the output voltages to identify the failing board and from there if the board can be repaired - start with the inverter) or if the processor can't load the firmware - this is almost always caused by a hardware failure of the processor and in that case the mainboard will have to be replaced.
In that case it will cost you around $200 to get a replacement board, plus the labor. Now you must decide if the tv is worth that amount of money - in my opinion it doesn't.
Posted on Sep 27, 2010
  • 8457 Answers
SOURCE: TV will not turn on. Problem with the Panasonic
Tries tv unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting.Now the tv should be working again.If still have the same result.Mean ur tv power supply board have problems and the causes.That the board,where the power a/c plug into it.Tries websites like Shojimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Jan 19, 2011
caroldon
  • 17130 Answers
SOURCE: how to switch on Hisense flat screen tv without remote control - powerbutton only goes to stand by
Tips to repair your remote control.
Click on: remote control
Posted on Jul 06, 2012
gopakumarg43
  • 74887 Answers
SOURCE: How to program the netgear smart TV remote to a hisense 42' flat screen tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Posted on Mar 06, 2015
I have a Hisense led tv model F39V77C.
Yeah, replace the set since it appears to be trashed. But if you have a few bucks lying around you might want to try replacing the unit's power supply to see if that resolves the many issues you have.
Jan 03, 2017 | Hisense Televison & Video
HISENSE MODEL 46K360M Question WHEN TRYING TO TURN TV ON RED POWER LIGHT BLINKS CONTINUOUSLY AND NO PICTURE OR SOUND ALTHOUGH 1-IN-20 ATTEMPTS DOES POWER UP THE SET
Nov 25, 2016 | Hisense Televison & Video
My Hisense 50K23DG T.V. wont turn on?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Aug 22, 2016 | Hisense Refurbished 50"" 1080p LED-LCD...
I have a hisense 50 inch tv, when I turn it on the brand name and the red light just blinks until I turn it back on. What does that mean and what do I do?
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Dec 07, 2015 | Hisense Televison & Video
I'm having issues with a Hisense LED tv.
Check all the wire harness inside; for firmness. re-seat all of it.
Sep 09, 2015 | Hisense Televison & Video
Power ligt blinking but wont turn on
most flat screen if you unplug it for and hour will reset it.
Jul 30, 2014 | Hisense 40K366W 40" 1080p Wi-Fi LED TV...
I jus bought a universal remote for my HiSense 32inch full hd LCD32v88peu and can't seem to find the code any help pls.
Hi, Try this and good luck
1. Turn the TV on.
2. Press the TV button on the top of the remote.
3. Press and hold SETUP until the LED light blinks twice.
4. Press 9 9 1 and the LED should blink twice again.
5. Press the POWER key on the remote.
6. Press CH+ repeatedly slowly until the TV turns off.
7. Press SETUP when the TV turns off.
Jul 26, 2011 | Televison & Video
Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
May 13, 2010 | Hisense TL1700 17 in. LCD Television
Televison & Video Logo
47 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
