Question about Hoover Washing Machines
My Hoover 2307L washing machine won't function at all, water connected,outlet hose connected, power is on, turn dial around to the function I want, pull dial out to start, but no action at all.
    Habit-Forming:
    Scholar:
  • Hoover Expert
  • 167 Answers
Check the lid switch is working when you put lid down.
Posted on Dec 24, 2016
  • 1462 Answers
SOURCE: hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
Posted on May 04, 2007
SOURCE: indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Posted on Feb 27, 2008
  • 351 Answers
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
timer or timer module fault
Posted on Mar 02, 2008
  • 135 Answers
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Posted on Jan 22, 2009
SOURCE: hoover quattro system 1100 ab power jet as 110
I had the same problem when i got my machine, if you slide out the powder and softener tray just behind the face of it on the right hand side you will see a white plastic tab about 2 inchs wide! That plastic tab slides out and has all the programme settings on it!
Posted on Jul 25, 2009
Hi my Hoover 2307L washing machine won't empty water Is this a problem that will cost a lot of $$$$?
WP35-6465 is the pump number it is about
$50.00 if you buy and install. Call a Repair shop and ask them for the price of parts and labor. I don't know how old your machine is so weigh the cost of repair to a new machine.
Jan 29, 2018 | Hoover Washing Machines
Hoover Model SH80520 starts and won't quit
that's how it's supposed to operate, switch on turns the unit on. switch off turns the unit off. thier is a wire that is connected to the leads on each outlet that turns the unit on when the hose is inserted and the switch is in the off position.
Mar 30, 2012 | Vacuums
My Hoover 750 washing machine does not spin any more. What would cause that and can I fix it with a new part?
Hello.
The answer to your question is YES.
And below is the instruction on how to solve the problem.
The Hoover750 is a washing machine that offers many standard features and a few additional options, including energy saving cycles, variable spin and water pressure options and pre-wash, extra rinse and timer features. Available online and in select appliance, department or home retail stores, the Hoover washing machine should function well with basic maintenance and care. However, if individuals experience problems with the machine, some troubleshooting steps may be beneficial in locating the source of the issue and a potential resolution.
1. Ensure the Hoover washing machine is firmly connected to a grounded power supply if the machine is not working. Reset the circuit breaker if necessary.
2 Turn the main power switch to "On" and open and close the washer door firmly if the electrical outlet has power but the washer is not functioning. The washer will not operate if not turned on or if the door is open.
3 Verify the water inlet hoses are connected firmly and are turned on if there is no water flowing to the washing machine. Straighten out any kinks in the hoses and remove possible obstructions from the inlet screen.
4 Straighten the drain hose if the water is not draining from the unit. Remove any possible blockages from the drain hose. Tighten the hose if necessary.
5 Avoid selecting a "No Spin" option if the washer is not spinning water out of the drum. Choose a new spin cycle and press "Start" to remove water from the drum.
6 Verify that all four feet are touching the ground evenly if the washing machine is rocking or vibrating during use. Adjust as needed.
Thanks.
Feb 19, 2011 | Hoover Washing Machines
My washer will not fill with water or do any functions when i turn the dial
My Hoover 7700l ...on "fill" cycle, the water dribbles in. Takes hours to fill so we use buckets to reach the required level.
Tried: Swapping cold and hot water inlet hoses, making sure that dial is in "hot". This solved the problem for filling, BUT when "rinse cycle appoars, it's back to the dribble again.
any ideas?
Jan 23, 2011 | Maytag LSE7806A Top Load Stacked...
I have a Hoover washing machine, its a front loader, I don't have the exact model in front me at the moment. I recently moved house, and yesterday after re-plumbing my washing machine, I put the washing...
If water remains in the drum after the drain cycle, the unit will not go into the spin cycle. There may be a couple of reasons for your problem.
Make sure the drain hose is raised above the machine hose outlet to create a siphon effect. The drain hose needs to have a loop in it to work correctly. You can tie a string around the hose and hook it on the water valve creating a loop in the hose. Raise the loop of the drain hose so the top of the loop height is at the center of the washer drum.
Apr 06, 2010 | Hoover AI130 Front Load Washer
Hoover 200m, keeps letting water in, will not advange to wash cyc
Your outlet hose is too low at the back of the machine tie the hose at about the level as your inlet hose eg to where your inlet hoses are festened and then let the remainder of the hose go to your outlet as usual.that should work Kind Regards Stefan.
Jul 08, 2009 | Hoover HTC243 Top Load Washer
Hoover Premier 706 (model A6950) washing machine.When filling water wont shut off.Turn power off water shuts off.If I remove hose from side of bowl and gently blow into it water shuts off.Machine is old...
Inserted flexible piece of thin wire into hose connectioin on outside of bowl and vigoursly wriggled it around - replaced hose and bingo water fills and shuts off and machine operates correctly. Seems like the hose connection was blocked, not a very scientific repair method but seems to have worked. Thanks.
Aug 14, 2008 | Hoover Washing Machines
HOOVER 500MB WASHING MACHINE
the pump hose has to be above tub level or the water will run out
the dial control unit is faulty and if the parts are are available will cost up to $150.00 aud approx to buy
the leak under the machine could be from a tub to pump hose or water level hose up to sensor
how new is almost new as it seems you have inherited a lemon and not a working machine
Jul 17, 2017 | Washing Machines
Washing Machines Logo
42 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
