Question about Kodak Office Equipment & Supplies
Where can I find detailed instructions for how to remove and replace the auto-focus worm shaft assembly on a Kodak Ektagraphic III AT slide projector?
The top tooth gear is 15 percent stripped.
  • 822 Answers
The link contains the service manual for your unit. These units are repairable. The plastic nylon parts are usually what requires replacement. Parts are readily available. If you elect to do DIY I suggest you take many pictures and notes to aid in reassembly. They are not particularity difficult to repair, but it is very easy to lose your way trying to re-assemble.
They are not intuitive in the operation using lots of little cams and levers to achieve the functions.
Documentation is critical. The most difficult is the timing adjustments. Study the assembly and cycle the unit with covers removed to observe the basic function.
Keep the screws/parts marking their location and grouped
Replacement of the failed worm gear is one of the least difficult to achieve, Parts available on e-bay
Careful not to to touch the bulb or lens.
If you need to remove the lenses document the stack careful for reassembly
I have used lithium grease during reassembly.
Hope This helps?
http://resources.kodak.com/support/pdf/en/manuals/slideProj/manual/ektagraphic_sm.pdf
Where can I find detailed instructions for how to  - 26410205-0iif0ln4psauhjpjgkhramus-1-0.jpg
Posted on Dec 23, 2016
Testimonial: "Thank you jhnolson. The part you've pictured is exactly what I need. However, I'm still searching for specific instructions/details for disassembling only that which is needed to replace this gear-shaft. The service manual is quite unclear and poorly illustrated. Any additional help - much appreciated! -Don"
Fix focusing on ektagraphic remote control
Ektagraphic III A did not have remote focus. Someone has probably substituted a remote from a higher functioning model on this projector. The forward / reverse functions on the supplied remote will continue to function correctly, but the focus buttons will not.
Good Luck !! Jim
May 20, 2014 | Kodak EKTAGRAPHIC III A Slide Projector
Fix remote focus on ektagraphic projector
The problem you describe on your Ektagraphic ATS could be caused by a couple of things:
1> You have the incorrect remote. You need the correct remote for the remote focus over-ride to function. Just because the "Focus" button is on the remote, doesn't mean you have the correct remote control. The remote control could be broken, as well.
2> You could have a broken or mis-adjusted focus over-ride switch inside the projector. To rectify this you may need special tools and/or parts ( I'm not sure they are still available). To check this, contact: www.micro-tools.com
Micro-Tools may be able to provide you with instructions to make the repair, as well as the parts. Good Luck!! Jim
May 20, 2014 | Kodak Ektagraphic III ATS Slide Projector
Slide projector is loading slides too fast
On an Ektagraphic III-A there is an internal adjustment you can make of the wire that captures the slide change mechanism after one revolution (or ONE slide change). Over time and usage that wire either breaks off, burns off or gets out of adjustment. Look at the attached diagram for more detail:
Feb 15, 2014 | Kodak EKTAGRAPHIC III A Slide Projector
Kodak 760h autofocus does not function
Check with the dealer who is selling you the part, to see if they can provide you with the required pages for disassembly, repair & re-assembly from the Kodak Service Manual. You should be aware that in some cases when this repair is made, it requires the technician to re-calibrate the auto-focus system. To do that, you will need 2 special tools (a "Target Slide" and a "Range Slide"), that were manufactured by Kodak for use on the assembly line and by their authorized warranty repair dealers. You MAY need those, as well.
As you can imagine, all this can begin to get expensive (if you can still get the special tools).... It may be more economical to try to locate another used projector on the internet... Here are 2 dealers I can recommend: For parts & tools - www.micro-tools.com
For used projectors - www.vinevalleyimaging.com
Good Luck!! Jim
Feb 06, 2014 | Kodak Office Equipment & Supplies
Kodak 5200 focus slide not working
The auto-focus system requires adjustment / set-up with special tools if the auto-focus no longer functions correctly. Before ordering the tools from: www.micro-tools.com
check a couple of things:
1. Is the "Auto-Focus on-off Switch" in the "ON" position?
2. Put a slide that is as dark as possible in the slide gate. Power on, lamp on. Look down into the gate, on the front side of the slide. You should see a "S"-shaped light near the center of the slide.
If you have validated both of the conditions above, then I would contact my friends at micro-tools for the special tools. They should be able to provide you with adjustment instructions.
Good Luck !! Jim
Oct 18, 2013 | Kodak ATS Ektagraphic Slide Projector
Shutter stuck on Ektagrahpic III projector
First of all, the shutter will only open IF there is a slide in the gate. Assuming there is a slide in the gate, there are 2 things that could be preventing the shutter from opening:
1. Most likely - the shutter is spring-loaded. If the spring unhooks or is missing, the shutter will not open.
2. There is an adjustment that needs to be made after the spring is replaced or re-hooked (or just is out of adjustment. Refer to the Kodak Ektagraphic Service Manual @ the Kodak web site: http://resources.kodak.com/support/pdf/en/manuals/slideProj/manual/ektagraphic_sm.pdf
Good Luck! Jim
Aug 18, 2012 | Kodak Ektagraphic III ATS Slide Projector
Just purchased a Kodak Ektagraphic AF1 & neither manual/auto focus or slide advance work. My other Kodak Ektagraphic AF had both auto & manual advance broken as well. Used it for many years. Was...
The model AF-1 did not have remote focus feature. It does have the Auto-Focus feature. The auto-focus adjustment is a pretty "fine-tune" adjustment that requires a factory alignment tool & a trained hand.
Your model AF is quite old, and probably requires replacement of the "link" that connects the slide change solenoid to the slide change mechanism. The problem is the plastic the "link" was made of gets brittle over the years and cracks, rendering slide change non-functional.
Both problems are easily remedied by a qualified repair dealer with the tools, training and parts.
Oct 19, 2010 | Kodak Office Equipment & Supplies
I'm having trouble changing the bulb in a Kodak Ektagraphic AF-1 slide projector. The bulb doesn't fit easily into the housing and I don't want to force it.
First of all, verify you are using the correct lamp: it should be a 120volt, 300watt, ANSI Code "ELH" lamp. (This may seem too basic, but you'd be surprised at the number of people who try the incorrect lamp).
If the lamp is correct and you can not insert it by pushing the base of the lamp into the terminal connector relatively easily, then chances are you have a build-up of material on one or both of the lamp contacts caused by arcing (arcing is caused by loose lamp terminal contacts). If this is the case, then you need to replace the lamp terminal assembly (the ceramic-like white piece the lamp terminals should slide into). You should still be able to buy a lamp terminal assembly for your Ektagraphic AF-1 from: www.micro-tools.com
Good Luck !!
May 20, 2010 | Kodak Ektagraphic III E Plus Slide...
I live in nyc where can i get replacement bulbs for the ektagraphic
The KODAK Ektagraphic ATS uses a 82volt, 300 watt ANSI code "EXR" lamp. You can order "EXR" lamps from Bulbman (www.bulbman.com)
Apr 19, 2009 | Kodak Ektagraphic III ATS Slide Projector
Does bulb need replacement?
I had same problem.
You have to load the slides so there is something to be projected.
Dec 15, 2008 | Kodak Ektagraphic III ATS Slide Projector
65 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
