When it goes into spin cycle agitates really hard like it's full of boulders
  • 129 Answers
SOURCE: Agitator not spinning
could'be water level switch or timer control. another posibility is corrosion on the motor wiring connector
Posted on Jun 22, 2007
  • 71 Answers
SOURCE: kitchenaid top load washer wont agitate or spin
you have a direct drive washer with a coupling broke.Here is a good article on it http://repair2000.com/coupling.html
Posted on Dec 12, 2008
  • 1214 Answers
SOURCE: GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Posted on Jan 26, 2009
MNTECH
  • 1543 Answers
SOURCE: my ge washer whdsr209d model wont agitate
Reach down to the bottom of the tub and pull the agitator straight up and out of the machine. Sometimes this is a bit difficult. If so, slip a belt or rope under the agitator, attach to a 2 x 2 or similar object, and **** it straight up and out of the machine. Now, take the bolt out of the center part with a 1/2 inch wrench. Pull the upside down can shaped nylon part straight up and off. If it does not come off, you can crack it in parts with a hammer and chisel if needed. Try to turn the splined shaft with your fingers. If you can turn it, you are screwed. (need a new transmission) Most likely you will not be able to turn it with your fingers, which is good. That means that all you have to do is replace the agitator drive (sometimes called an air bell coupler) part number WH49X10042, reinstall agitator, and you are ready to go. Cheap fix.
Posted on Feb 15, 2009
SOURCE: doesnt agitate or spin.
Mine is 1 1/2 years old and this worked for me
unplug from power for at least 30 seconds
turn the dial to spin but don't pull out
plug back in to power and open and shut completely so switch is engaged solidly 11 times in 15 seconds.
pull out knob to turn on
This should clear a error code.
hope it helps!
Posted on Jul 30, 2009
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Mav7600aww maytag spinning but not agitating
RDU Appliance Repair 919 827 1482 Serving Raleigh Cary Durham NC
mav7600aww has a brake that goes bad. some will just spin slowly during agitate cycle and not really agitate
Sep 07, 2013 | Maytag Atlantis MAV6000 Top Load Washer
My Hotpoint wf000 1000 spin model won't spin. It goes through a full wash cycle, agitates fine, but just won't spin at the end of the wash. Any help appreciated.
Sorry if it may be too obvious, but have you checked the philtre? generally they stop spinning when it's stuffed... when you open it, make sure you have a mop and bucket handy, some water will come out!
Nov 06, 2012 | Washing Machines
Hi, our simpson enduro 701 washing machine does not spin back and forward in the deep rinse cycle. but operates ok and spins in spin cycle. thankyou Tina.
Hi Tina just read your posting. From the information in your posting the machine fills, then when the machine is full of water the agitator moves clockwise then anticlockwise until it gets to the rinse cycle then drains the water ,then it fills for the rinse cycle but does not move the agitator in the rinse cycle.Then it drains and spins the clothes dry .Is this assessment of your posting correct.If it is not 100% correct please reply to tell me what the machine is doing or not doing.If it is correct then the problem with your machine is the control board.Is your model the electronic one with the push buttons?Looking forward to your reply.
Jun 26, 2010 | Washing Machines
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
My Capacity Plus Admiral Washer will spin and agitate, but it makes a loud grinding noise.
Well, Sounds to me like the Bearings are going out, but it could make that noise a good while, before it goes completely out.. Replacement would possably be more cost effective, Kinda hard to beleive !!!!!!
Oct 26, 2008 | Washing Machines
Wont spin or agitate
Not sure what you mean? if you have normal wash action then it is agitating in the wash cycle.  Otherwise if it doesn't agitate or spin but does fill with water then your motor or motor control board is bad.
Oct 27, 2007 | Frigidaire ATF6000ES Front Load Washer
Jun 22, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
