Question about Amperite Dayton Solid State Timer On Delay Time Relay
Off delay for Lighting
I am having a industrial garage door installed and i would like to install some lights to come on in the warehouse for about 5min when the door is activated to open. What kind of relay do i use and how do i wire it?
    Sergeant:
  • 384 Answers
You will need a timer. Run power line from input of door opener to timer. Set timer for 5 minutes connect lights to timmer.
Posted on Jul 21, 2009
Why do the headlights. Come on when any door is opened on my 2008 trailblazer
The Headlamps On at Exit and Perimeter Lighting modes can be adjusted using the steering wheel controls to select the wanted function as displayed in the driver information center. The Headlamps On at Exit selection will allow the driver to customize the period of time that the headlamps remain illuminated upon exiting the vehicle. This period can be adjusted from 0 seconds to 180 seconds. The Perimeter Lighting feature allows the driver to select if they want the headlamps and backup lamps to illuminate when the door UNLOCK button on the key fob is activated. This feature can be turned ON or OFF by using the driver information center steering wheel control buttons.
programming Features with the Driver Information Center (DIC)
To enter programming with the driver information center (DIC), perform the following actions:
Turn the ignition to RUN.
Place the vehicle in PARK.
Press the Personalization button on the steering wheel to enter personalization programming.
Automatic Door Locks
Continue with the following steps in order to personalize the automatic door locks:
Press the Select button in order to enter the menu. The first choice seen is the current setting.
Press the Select button in order to scroll through the following options:
• LOCK DOORS: IN GEAR
• LOCK DOORS: WITH SPEED
Press the Personalization button in order to advance to the next option.
• UNLOCK DRIVER: IN PARK
• UNLOCK DOORS: IN PARK
• UNLOCK DOORS: AT KEY OUT
• UNLOCK DOORS: MANUALLY
Remote Activation Verification
Continue with the following steps in order to personalize the remote activation verification feature:
• LOCK FEEDBACK: BOTH
• LOCK FEEDBACK: OFF
• LOCK FEEDBACK: HORN
• LOCK FEEDBACK: LAMPS
• UNLOCK FEEDBACK: BOTH
• UNLOCK FEEDBACK: OFF
• UNLOCK FEEDBACK: HORN
• UNLOCK FEEDBACK: LAMPS
Delayed Lighting
Continue with the following steps in order to personalize the delayed lighting feature:
• HEADLAMP DELAY: 10 SEC
• HEADLAMP DELAY: 20 SEC
• HEADLAMP DELAY: 40 SEC
• HEADLAMP DELAY: 1 MIN
• HEADLAMP DELAY: 2 MIN
• HEADLAMP DELAY: 3 MIN
• HEADLAMP DELAY: OFF
Perimeter Lighting
Continue with the following steps in order to personalize the perimeter lighting:
• PERIMETER LIGHTS: OFF
• PERIMETER LIGHTS: ON
Mar 13, 2017 | 2008 Chevrolet Trailblazer
Craftsman model 139.53918d. Why doesn't it turn on lights when garage door is opened or closed?
Free Craftsman Garage Door Opener User Manuals ...
homeappliance.manualsonline.com > ... > Household Appliance Craftsman
Products 1 - 50 of 60 - Craftsman Garage Door Opener 139.53515SR - I/2HP.Craftsman Garage Door Opener User Manual. Pages: 0 Saves: 0. See Prices
Aug 24, 2015 | Building Materials
Hi, In the sensors there is no light coming. What should I do?
No light will come out of the sensor lenses. The light beam is invisible. However, if the indicators are not lighting, you should check your wiring to ensure that they are properly connected to the motor unit, there are no staples cutting the wire, or causing a short in the wire, and they have not been pulled out of the back of the sensor. If the sensors and wires are properly installed and in good condition, and you still have this issue, replace your sensors.
Sep 01, 2013 | Sears Craftsman LiftMaster Chamberlain...
I have a Chamberlain garage door opener - Electrolift Executive with command control model #5446. I need to program the remotes but do not have a manual. The remotes have dip switches inside that I can set...
THERE SHOULD BE A SQUARE BUTTON NEAR THE ANTENNA WIRE THAT IS THE LEARN BUTTON. IF THERE IS NO SQUARE BUTTON THEN THER SHOULD BE A ROW OF SWITCHES ALSO NEAR TH ANTENNA WIRE
HOPE THIS HELPS
Mar 07, 2010 | liftmaster Chamberlain Garage Door Opener...
Interior lights (10 Amp) will blow the fuse as soon as you turn them on or open the door.
Look for a short circuit in the lamp socket or the lamp itself. A lesser possibility is a wiring short due to abrasion or pinch of the wire going to the lamp socket.
Oct 25, 2009 | 1999 Oldsmobile Aurora
1/2 HP Craftsman Garage Door Opener works but lights don't
I think you are saying that normal incandescent bulbs do not work. If that is correct you should unplug the unit and using a small screwdriver reach into the socket and pull out slightly on the center contact.
Aug 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
New eye sensor not lighting up when installed
Make sure the sensors are pointed at one another. Also one of them should say "sending unit" and the other is the "receiving unit". Did you buy them new and from a dealer?
Jun 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Amperite Dayton Solid State Timer On Delay  Time Relay Logo
464 people viewed this question
Top Amperite Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you an Amperite Hardware and Accessory Expert? Answer questions, earn points and help others
