Televison & Video Logo
Becky Goldston Posted on Dec 23, 2016
Cant get tv out of computer modeto tv mode - Televison & Video
How do I switch of my Giant Axact 13W Wireless computer ?
You don't, you let it go into sleep mode.
AUTO SLEEP MODETo preserve battery, this computer will automatically switch to sleep mode and just displays the CLK data when it has not been used for about 15 minutes. The power will be turned on by pressing the SET button!
https://www.giant-bicycles.com/backoffice/_upload_ca/parts/Axact_13.pdf
tip
Wireless security issue. How to secure the network ?
To secure the wireless network or to change any settings on the router you will need to access the router set up interface.
Open the set up interface of the router . Make sure that your computer will be connected to the router with the Ethernet cable.
Click here for step by step instructions
Onceyou open the set up page of the router , you will find the place tochange the wireless settings of the router. In case of Linksys wirelessrouter , you will see the Wireless Tab at the top.
SSID :It is the name of the wireless network. This name will be shown on yourwireless computer or the wireless device so that you can identify yourown wireless network. All the routers come with their factory defaultsettings. For example , the Linksys router will come with the Linksysnetwork name.
It will be better to change the wireless network name.
Wireless Security
Change the security mode to WEP.This security type is supported by all the operating system. Whenchange the security mode to WEP, you will find the Network key box totype the network key. Do not type anything in the Passphrase box. Typeyour network key in the Key 1 Box. If you set the encryption to 65bits, your network key will be 10 digit hexadecimal number. that meansyou can use the combination of 0,1,2,3,4,5,6,7,8,9 and lettersa,b,c,d,e,f only. remember it should be exactly 10.
If you set theEncryption to 128 bit, your network key will be the combination of 26digits. You will need to remember the network key.
WPA
This is one of the most secured type of encryption.
Openthe set up interface of the router. Change the wireless security modeto WPA personal. You will find the passphrase box. in this box you cantype any password for your wireless network. The password should be thecombination of number and letters and it should be 8 or more than 8characters.
This security type is supported by WINDOWS XP SP2 and above Operating system.
WPA2
This is one of the highly secured type of encryption.
Openthe set up interface of the router. Change the wireless security modeto WPA personal. You will find the passphrase box.In this box you cantype any password for your wireless network. The password should be thecombination of number and letters and it should be 8 or more than 8characters. Keep the Algorithm to TKIP.
This security type is supported by WINDOWS VISTA and above.
Once you change the wireless settings on the router , try to connect to the new wireless network .
on Dec 04, 2009 • Computers & Internet
I cant connect to my tv threw my acer laptop .
The TV probably doesn't have a resolution your graphics card can detect, you're going to have to get a different GPU if you want to do this, or possibly use an HDMI port since those will adapt and stretch the screen resolution.
Num and caps lock flashing, laptop freezing
Hi alanneil19
Sounds to me like you have a virus or other malware in your laptop
Follow these steps and I believe your problems will be solved, if not then look for something mechanical/electrical wrong with the computer.
To remove a virus,trojan,worm,etc from your computer...do it the EASY way...let someone else do it for you.
Start your computer in the Safe Mode
To do this you will do the following
As the computer is starting keep tapping the F1, F2,F10 or F8 Key depending on your computer.
This will start the computer in the Safe Mode.
Once in the safe mode go to the following webage below and download,install, and run Microsoft Safety Scanner for FREE.
Once you run the Microsoft Safety Scanner (it may take quite a while depending on the size of your hard drive) it will remove all the virus's,trojans,worms,etc it finds, if it does not completely remove them all you will be given a chance to chat with a Microsoft Professional thru a pop open window and he will take control of your computer (with your permission) and finish removing all the rest of the virus's, trojans, or worms that are on your computer for FREE!! Can't beat FREE!!
Please take time to rate me
Bud
http://www.microsoft.com/security/scanner/en-ca/default.aspx
Colby mp601 need to dalete all musice
Use a paper clip to press the <RESET> button on the Bottom of the player.
setup Mode
To enter Setup mode, select SETUP in the Main menu.
look for Sys Tools Press <ENTER>
look for Reset Press <ENTER> in doing this you will reset to factory and delete everything. like songs and settings.
NOT SURE HOW TO MAKE A VIDEO,HAVE LOST INSTRUCTIONS
If this is a digital camera, simply adjust the tab or dial to video modeto video. If you are having a hard time finding that, then please provide us the make and model of your digital camera.
Aug 01, 2011 • Cameras
Im using my tv as a monitor, when i turn on my music and then leave the computer to do chores, the computer goes to no signal and i cant listen to my music, how do i keep it from doing this?
Sounds like either your computer is in hibernation mode or your TV is set to sleep, what type of connection to your computer are you using? I do believe in this model Vizio there is a sleep option on each of the Video sources. But I would guess its your computer going into either sleep mode or in your running windows 7 Hybrid sleep mode.
My laptop comes with an administrator password and no means to open it even in safe mode. so is there any means to access my laptop?
well if you cant remember the password all you have to do is to reset your computer to its factory default since you mention that you cannot go to safe modeto delete the password on the user profile...if you dont know how to reset your pc to default you can contact ThinkPad Tech Support at 1-800-426-7378
2helpful
2answers
I changed the battery on 2006 Trailblazer SS. Now I can only get AC from my windshield and floor vents. Nothing from the dash vents. Also the temp control only gives coldest temp. I have checked fuses...
once you disconnect the battery your body control module loses power and memory you have to get some one with a scanner with reprogramming capabilities and have the computers reset ,dealer?
I have a relisys lcd tv and its connected to the hdmi output mode but i want to connect my computer to it using a vga cable and once i plug it in nothing happens and i cant change the mode of the tv
if you have a PC input to your LCD panel, connect the VGA cable at both ends (one to PC and the other to LCD TV), Only after the connection switch on the PC not before.
Make sure your Computer Display settings - Resolution not more than 1020x780. If so reduce and then try.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
