Question about Haier Dishwashers
My haier 18pa countertop dishwasher is leaking from th bottom
  • Haier Master
  • 3,092 Answers
When I checked ours... (steel liner)
the bottom was rotted out pretty good.
The bottom was thin enough to poke my
finger right through...
(real trouble is ... modern units MOSTLY don't have dryers...
You have to HUNT for a DECENT REPLACEMENT.
Carnac the Magnificent
(stainless steel insides + ALL the BELLS & WHISTLES)...
PRO- Series... followed by a complete kitchen REFRESH.
Posted on Dec 23, 2016
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: HDT 18PA 17 in. Haier Dishwasher... leaking at
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 29, 2010
Why is my danby countertop dishwasher is leaking?
I would check hoses to make sure they are not kinked.... mine also loosened after I pushed it back and had to re-tighten. HTH
Jul 08, 2014 | Danby DDW497W 22 in. Countertop Dishwasher
My Danby countertop dishwasher won't wash-the dishwasher detergent is never used at the end of the wash and nothing is clean
Was it working before, and now has stopped working? If so, it sounds like it has poor water circulation. It might be caused by a leak. If you have not noticed a leak, it might be clogging due to hard water deposits. Do you live in a region with hard water?
Feb 10, 2014 | Danby DDW497W 22 in. Countertop Dishwasher
HDT 18PA 17 in. Haier Dishwasher... leaking at bottom of door. Need a new gasket. How do I order one and from whom do I order?
heatman101
Mar 03, 2010 | Haier 17 in. HDT18PA Built-In Dishwasher
Dishwasher is leaking from the bottom
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
vb
Jan 28, 2010 | Haier ESD200 Built-in Dishwasher
Dishwasher leaks water as it fills
  • Step 1 Remove the front access panel (see step 1, "Tightening the fittings"). This will give you access to the dishwasher's adjustable feet.
  • Step 2 Open the door completely and remove the bottom dish rack.
  • Step 3 Unscrew the dishwasher from the kitchen countertop so the dishwasher can move freely as you adjust the feet.
  • Step 4 Check to see if the dishwasher is level side to side. Place a small level inside the dishwasher so it's sitting on the bottom pan and facing parallel to the front lip of the dishwasher. If the dishwasher is not level, use adjustable pliers to turn one of the dishwasher's front feet up or down until you hit level.
  • Step 5 Check to see if the dishwasher is level front to back. Turn the level perpendicular to the door, and place it on one of the bottom ledges that run along the side of the cabinet. Check the level again. If the dishwasher isn't level, use your adjustable pliers to turn the back feet up or down until you hit level.
  • Step 6 Reattach the dishwasher to the countertop and reinstall the front access panel.
    Fixing a leaking door
  • Step 1 Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
  • Step 2 If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
  • Step 3 Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
  • Step 4 Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
  • Step 5 Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
  • May 14, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
    Need service manual for HAIER HDT18PA countertop dishwasher
    Click the link, then click the picture of the manual on the page, it will begin loading the manual.
    HDT18PA Haier Table Top Dishwasher
    Apr 10, 2009 | Haier 17 in. HDT18PA Built-In Dishwasher
    Haier countertop dishwasher will not empty
    There is a filter at the bottom of the tub that has to be cleaned out once in a while. Then it will drain. This should help. It is a plastic looking mesh filter most can be removed and hand washed. Hope this helps.
    Jan 18, 2009 | Haier 17 in. HDT18PA Built-In Dishwasher
    i would think the drain hose from the unit is leaking from the description you give.let me know
    Dec 24, 2007 | Danby 22 in. DDW396 Free-standing...
    Hose sizes
    compactappliance.com has stats on the models they sell.   I think this one's hoses were 4 feet long.
    Jun 27, 2007 | Haier 17 in. HDT18PA Built-In Dishwasher
    Dishwashers Logo
    57 people viewed this question
    Top Haier Dishwashers Experts
    Tim Doolittle
    Tim Doolittle
    Melissa Martin
    Melissa Martin
    Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
