Question about Gateway 7330GZ Notebook
Does not boot up
Dell
works sometimes , then not
  • yamon00 Jul 21, 2009
    check the ac adapter
    then the power jack
  • 744 Answers
Hi...
Probably a virus, or your windows folder got corrupted. Try to use Knoppix (A linux distrobution that boots from a CD) to get all your data onto a pen drive or external hard drive. Download the Knoppix ISO at Knoppix.com and burn it onto a CD or DVD using MagicISO (magiciso.com). Insert the CD, and you should see the boot screen. Open the file manager, and copy all the files you want to keep from your hard drive to a pen drive or external hard drive. Then, reinstall Windows using a recovery CD (one might have come with your computer). Copy the files back
thank u
rate me
Posted on Jul 21, 2009
  • 201 Answers
Theres a pin in the jack
see if it moves
Dell latitude d600- won't boot up!!!
Yes this can be a opverheating problem that's why sometimes it boots up, if the processor is not working fine because of overheating you check first the cooling system of your computer liek the fan if they are working fine because if the fan is not working the way it should be working oeverheating may occur and will result to this problem...
Hope that helps.......
Aug 06, 2008 | Dell Latitude D600 Notebook
Tip
Had "mirror image" boot screen.
I had a Dell XT2 tablet, brand new-when I went to boot it, the POST screen and Windows load screen were half-off the screen and mirror imaged as well. After trying the Dell website, as well as Google and Bing, with no success, I decided to try a trick that sometimes works on Toshiba Portege tablets too. Remove the battery, unplug the power adapter, and hold the power switch for 10 seconds. Replace the battery, plug back in, and it appears to reset the CMOS-both the Toshiba and Dell boot normally.I suspect that this will work for many other models of laptops, but I have no proof-I do know that it will work on Dell D-620/D-630 laptops. I have also used this trick to bring laptops out of what appears to be a 'hung' sleep/standby state.
on Jan 20, 2010 | Computers & Internet
Hi just wandering if there is a button like f5 or another to restore ur computer as my keyboard is not working I have a Dell inspiron 6400 laptop about 5 yrs old and need to restore it back? Thnx Sharon
Sometimes Dell has a utility under start menu all programs while running the OS...to restore the system. If no utility then you can try the below options.
Try pressing F8 at boot time and choose repair computer...then select Dell factory image restore.
(Win XP might require CTRL+F11 at boot time)
If there is no option to restore factory image then you will probably need to use the original Dell install disk. Press F12 at boot time to boot from CD-DVD and perform install.
If you need detailed instructions please refer to this link:
http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&cs=19&l=en&s=dhs&docid=DSN_3E48AE3870775D64E040A68F5B2877D4&isLegacy=true
May 16, 2011 | Dell Computers & Internet
I have a dell D820 which will not switch on today, sometimes it gets to the windows XP page sometimes the initial dell page. Other times nothing at all. All worked well last night
immediately run a diagnostics for the hdd alone power on laptop then keep tapping F12 then run the diagnostics. if no errors found then.
try this. power on laptop then keep tapping on F8 to boot options then select last known good configuration. if same problem then boot in F8 then safe mode if still the same problem. use now the OS disc to do startup repair. Boot F12 then select DVD drive in booting make sure the OS media is already on the driver. then just select repair computer then make startup repair. if all fails this might end up reinstalling OS as clean installation.
Oct 21, 2009 | Dell Latitude D820 Notebook
Dell Dimension 8400 Won't Boot Up
call dell first tell them the problem,they should help you,or use chat i use that sometimes.
Apr 18, 2009 | Dell Dimension 8400 PC Desktop
Dell D600 Wont turn on sometimes.
Reseat the harddrive (take out the screw and slide it in and out)
You can run diagnostics, during startup (just after Dell logo) press F12,then select Boot to Utility partition, or Diagnostic partition.
It may reveal you issue
Hope this helps
Feb 04, 2009 | Dell Latitude D600 Notebook
Dell Latitude D620 - Screen shows boot up, but then goes blank. I know the screen is ok as the dell part shows on screen, but when the blue screen should appear to insert password etc, the screen remains...
Here are some easy things that can sometimes resolve this problem:
1) Sometimes there can be a static buildup on the mother board. Power off, remove the battery, remove the power cord and hold the power button in the on position for at least 30 seconds.
2) If that didn't work- Power down, remove the battery, remove the Hard Drive and memory modules and reinsert them. Try to power back up
If these things don't work, get back to me for some more ideas.
Hope this helps and have a super day!
Ron
Dec 15, 2008 | Dell Latitude D620 Notebook
I'm getting blue screen on bootup
Sometime hitting F8 during boot up brings the safe boot screen. Booting to safe then booting normally sometime fixes the problem.
Aug 23, 2008 | Dell Vostro 1500 Notebook
Dell latitude C400 will not boot from hard drive.
Hi, This sounds like a dead hard drive. Still, you may want to try: 1. Enter your CMOS/BIOS and verify that your laptop can detect the hard drive. Further check if it is configured to boot first from the HD; 2. Slip in your XP or Recovery CD and boot from that. It may be that the boot section/files of your HD got messed up. When prompted, instruct the CD to repair; 3. Remove your laptop's HD and connect it to a 2nd PC as an external/removable drive using a 2.5 enclusore with USB attachment. Thereafter proceed to diagnose, check and hopefully recover your important files; 4. If confirmed of a defective HD, replace and reinstall your OS. Hope this be of some help/idea. Post back how things turned up or should you need further information. Good luck and kind regards.
Sep 29, 2007 | Dell Latitude C400 Notebook
Gateway 7330GZ Notebook Logo
75 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
