Question about Dehumidifiers
My dehumidifier model # ku34313 leaks water and doesn't fill up the water pan. What do I need to try to fix it
SOURCE: leaking all over floor
sorry wrong model number. my model number is m7dh65b2a.
Posted on Aug 22, 2008
  • 508 Answers
SOURCE: watwrleaks out of the bootom of the dehumidifier -
There should be a drain hose to drain water!!Check tank for leaks or obstructions-check that drain isnt clogged!!un clog and clean as necessary!!! Best of Luck!!!!
Posted on Jun 24, 2009
billyvangogh
  • 108 Answers
SOURCE: Dehumidifier comes on runs for hours but does not
is there a setting ?? Dehumidify ??? as opposed to "Fan" if so set to Dehumidify...also turn up the dial to a higher number.....Is the element in the back Cold???? If on Dehumidify . turned up high and the element is cold...then you have a refrigerant leak and not worth fixing unless its under warranty
Posted on Oct 25, 2009
  • 20 Answers
SOURCE: My Santa Fe RX dehumidifier is leaking lots of
Your pump hose may be damaged or the adapter that connects the small hose to the pump may be loose. The pump itself may be damaged as well. Unfortunately this means that the unit must be partially disassembled in order to access the pump and associated tubing. The pump is located on the bottom of the dehumidifier next to the fan.
You can call Therma-stor service at 1-800-533-7533 for specific advice on your dehumidifier.
Posted on Feb 28, 2011
  • 4736 Answers
SOURCE: My model is Frig. Dehumidifier,
Check the float valve in the top of the bucket. It may be stuck in the UP position. If that the case, jiggle the float valve arm to get it to return to the DOWN position. That should solve the problem.
Posted on Jul 10, 2011
Fan running but no water and hot on inside. 50 pint danby premiere dehumidifier
Compressor not running, possibly because refrigerant is low
Jul 30, 2016 | Danby Dehumidifiers
How do you turn on the 30 pint KU34313 dehumidifier
I think you have to put water in it then push the start switch. The manual has a complete set of instructions.
Feb 21, 2014 | KUL 30 Pint Dehumidifier
Whirlpool gold dehumidifier leaks water on floor and we do not use hose just the pan, puddles of water on floor.
check your condensation hose for leak or the pan may have a crack in it or it runs too much for the water to disapate
Oct 23, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Hose connected but not draining and bucket filling
I am also an air conditioning tech, with same problem and same soleus dehumidifier problem. you must remove the plug and install the drain line hose adapter. Hose must lay flat and have no "hills" for water to drain. With this done pull your drain pan out and set aside. look under right side facing the dehumidifier and you will see a small spout. Has a lip like a little tea pot. Plug that spout. I used a foam ear plug used in work shops. Now give the front of dehumidifier a slight rise on front wheels about the thickness of a pies of cardboard 1/8 to 3/16 of an inch. Now put drain pan back in an start up. The problem is the drain pan was made with very little differance in pitch between the the hose drain and the bucket drain. Remember to check your drain hose periodically and the air filter also. Good luck
Sep 09, 2011 | Soleus CFM-40 Dehumidifier
Our model JA2M193N Edison dehumidifier runs but doesn't produce water, the coils get cold, but the fan doesn't come on. What do we need to do to fix it?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 14, 2011 | Edison 40 Pint Dehumidifier
Water leaks out of the bottom of the humidifier and the bucket does not fill up. The water just leaks out.
Based upon my experience with the same problem on my Kenmore 54701 last summer: The condensate water collects in a plastic pan below the coils. This pan has a single drain hole where the water flows down into the bucket. When I suddenly found water puddling on the floor instead of in the bucket, I opened up the unit, and I found that the collection pan's drain hole had become blocked by "bioslime". I cleaned out the goo from the drain hole, and the problem was solved.
Apr 22, 2010 | Kenmore 54701 Dehumidifier
I BOUGHT 50 PINT DEHUMIDIFIER AT CANADIAN TIRE LESS THAN A YEAR AGO.IT LEAKS WATER.NOT SURE WHERE IT IS COMING FROM.ANY POSSIBLE SOLUTIONS?
Try cleaning the filter first. Pull it out and then wash it with water and let it dry overnight. Then clean the spigot/nozzle which fills the pan. This often becomes clogged with dust or debris or even insect webs. Once you wipe the nozzle with a rag, really clean it well with a finger. You should feel the rubber gasket at the end of the nozzle with your finger.
Likely the fill nozzle was just clogged so water drips along the top and down the sides of the pan instead of into it.
Good luck.
Oct 07, 2009 | Whirlpool AD50USS Dehumidifier
Water leaks from the bottom front under the bucket. Bucket does NOT leak. Attached a piece of tubing from the outlet to the bucket to no avail. still leaks. No visibe cracks anywhere.
Try cleaning the filter first. Wash it with water and let it dry overnight. Then make sure no debris is blocking the inside of the spiggot which fills the pan. The spiggot can get blocked by dust anddebris or insect webs. Clean thoroughly with a rag and your finger.
Oct 07, 2009 | Haier AHD50 Dehumidifier
Water goes in reservoir, not thru hose to sump pump, leaking
blow some air thru the discharge line,, thats all it is the line is clogged, if the pan is filling with water, it is working but they do get clogged with dust and lint in the air,,
Jun 11, 2009 | Maytag M3DH30B2A Dehumidifier
Leaking all over floor
Jul 20, 2008 | Maytag M7DH45B2A Dehumidifier
Dehumidifiers Logo
85 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
