See if this link helps you out.
sensor camshaft position of hyundai sonata gls 2010 2 4 4 cylinders Google...
SOURCE: location of the camshaft position
It is located at the right top of engine (V6). Looking from the front of the car, it is just past the plastic cover over the engine. It has a silver clip (looks like a paper clip). remove clip and unplug sensor.
SOURCE: 99 HYUNDAI SONATA, ENGINE WHEN WARM CONTINOUSLY REVS
Sme thing happened to me, but the advice is grim. I had to have the whole transmission replaced because of a bad torque converter...I would be sitting at a light and the car would just go all by itself, or as I was driving down the highway the tach. would go crazy and shut the car down into "safe" mode where it would not go out of first gear. Other times I would have to keep both feet on the brakes because the car would be pulling so hard! The dealership told me the crankshaft position sensor too, then a month later the car just shut down and would not start. Hope this helps.
SOURCE: I have a 2000 hyundai Sonata, 6 cylinder eng. My
The sensor is located on the left hand rear side of the block (near the bell housing). It is held in place by a 10mm bolt. It's to the right of the exhaust manifold (LH - radiator side) on the V6. Once you purchase the new sensor you'll be able to identify it on the engine. The connector to this sensor is located in the illustration.
A word to the wise... replace the O2 snsr as well.
SOURCE: trouble replacing timing belt ... setting timing
Sorry for the severe delay.
I am personally going back to answer your unanswered question.
I do not know if you still need the answer, but I am going to answer it in case you still do.
Click on the following direct Link. It has the Timing Belt Diagrams with Marks for the Camshaft and Crankshaft that you will need. It also has numerous other helpful diagrams for use.
Again my apologies...
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/1996/make/hyundai/model/sonata/1996_hyundai_sonata_timing_belt_diagram_marks.htm
SOURCE: hyundai sonata cranks fine but won't start
other things it could be crank position sensor or maybe a fuel issue?
