The pilot lights but when the burner never comes to full burn. It has a low intermetent flame then goes out after a few minuntes
    Master:
  • 946 Answers
Can be a bad gas valve. Sometimes you need a new one. don
Posted on Dec 23, 2016
Slant fin boiler galaxy natural gas, pump starts and runs. Igniter comes on . Pilot lights. Burner lights. Runs for seconds. Burn shuts down. Igniter starts pilot light, pilot goes out and on and on
The flame sensor, which is located in front of one of the burner flames is probably oxidized and needs cleaning or replacement. If the unit can't "sense" the flame, it will continue to cycle.
Jan 22, 2017 | Slant Fin Heating & Cooling
I have a VC Wonderfire model 2610. The pilot flame is perfect blue on both sides... however, when I hit the switch for the main burner to come on...the pilot goes out... any ideas ???
You may have moved the safety sensor or pilot flame tip. The pilot light heats a wire. The wire is the safety sensor. The wire has to be clean and in the pilot flame near the flame tip.
Jan 10, 2015 | Heating & Cooling
Pilot light flame too loeeds adjustment
Adjust the pilot flame height using the adjustment screw for each burner.
Mar 12, 2014 | Magic Chef Ovens
The pilot seems to light but then when I turn the knob to ignite the main burner, the pilot goes out. Is there a technique to clean the igniting assembly?
let the pilot light burn for a few min and get hot after this try slowly moving the knob over to full burn. Sometimes it just need to heat up.
Feb 14, 2011 | Endless Summer 233000 Open Flame Patio...
Pilot burnes yellow and stays lighted when I turn the may burner on its on for about 30 sec. then goes out pilot and burner
You may be low on gas in the tank and there's not enough pressure and/or volume of gas to sustain it. Also, try carefully cleaning the burner elements.
Jan 19, 2011 | Blue Rhino ES200209 Open Flame Gas Patio...
My patio mushroom heater lights up ok but keeps going out by itself after about 5 to 10 minutes and then can be started again inatantainiously by starting pilot light and away you go until it goes out...
Here's a few things to check. When you light the pilot, is it a strong blue pilot flame, a weak blue flame or a lazy yellow flame? Is it heating the thermocouple enough to make it red hot after a few minutes? If the pilot is small blue or lazy yellow flame, it may be dirty and need cleaned. When the burner lights, the weak pilot flame may diminish causing the thermocouple to cool off enough to shut down the main burner. Clean the dirty pilot orifice by using a can of compressed air with attached straw. (The same canned air you use to clean computer keyboards) Blow it into the pilot assembly where the pilot flame burns out from and blow thru the air holes on the side, if applicable. You might also check the thermocouple itself to make sure the tip is not partially burn't off. It should be a smooth, rounded tip. Replace the thermocouple if cleaning the pilot orifice doesn't solve the problem. Douglas
Aug 05, 2010 | Coleman (5040B750) Patio Heater
The pilot light won't stay lite
Flame is way too high on pilot . blocked injector or hole on injector is too big . Being sucked off by main burner .
Jul 04, 2017 | Dyna-Glo (PPH16-LP) Utility Heater
Pilot goes out
If the pilot won't stay lit, the thermocouple may be loose or faulty, the pilot orifice may be clogged, or the pilot light's flame may be set too low and needs to be adjusted. You can clear a clogged orifice with a piece of thin wire, such as a bread tie with the paper stripped off of it. Be sure to turn off the gas to the furnace first! Also shut off the switch or circuit breaker that controls power to the furnace. Just poke the thin wire into the tiny orifice where the pilot flame normally burns to knock off any ash or debris. Some pilots have a flame adjustment screw for adjusting the flame. To adjust this, refer to your owner's manual. Normally, this is simply a matter of turning the flame adjustment screw to achieve a full, steady 1 1/2-inch to 2-inch flame that doesn't have any yellow in it.
Jan 18, 2006 | Coleman 2 Burner Compact Gas 425F499G...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
