Question about Sewing Machines
What else can I try to get the Overlock tensions correct on a Burnett funlock 003? I have re-threaded checked the threading and messed with the tensions to no avail
  • Sewing Machines Master
  • 12,526 Answers
You haven't provided symptoms of what is happening with your machine, so this is just a general guideline.
Remove all the threads from the machine. ALWAYS RAISE the presser foot when threading. Be sure to thread each thread IN THE ORDER specified--threading out of order will guarantee a problem! When threading the tensions, always give each thread an extra little tug to make sure it is seated completely (with one hand, grasp the thread below the thread tree and the other hand below the tension disk and tug--it may make a "pop" as it seats). Verify that each thread pathway is correct.
Set the tensions to the midway point. This is the standard beginning point for overlock tension adjustment, although some tweaking may be needed because every machine is different.
If the machine is still not performing correctly with some tweaking of the tensions, you may want to take it for service.
Posted on Dec 23, 2016
I have a YAMATA fy14u4ad, but I don't have the book to tell me the thread setting so what should the thread setting be for all 4 threads
Assuming this is a 4-thread serger. The thread tension setting will depend on which stitch you are making. A standard 4-thread overlock stitch would generally have the tensions set in the middle. FWIW, the tension in this setting is correct when the threads meet in the middle of the fabric. It should neither be off the edge of the fabric or so tight as to create a puckered edge.
Aug 10, 2017 | Yamata Sewing Machines
Nr 3 thread keep on breacking
Check your tension and especially you needle.
Jul 03, 2017 | Sewing Machines
Bernina Funlock tension is all out. Please help!
Unless something has gone haywire with the tension controls:
Remove all the thread from the machine (never pull the thread up, always pull the thread down through the needles & loopers after cutting the thread near the spools).
ALWAYS RAISE the presser foot and rethread from the beginning. Give each thread an extra little tug when going through the tension disks.
Set the tensions at the midway point. (This is the factory default but may need to be tweaked for your machine because of wear and deviations.)
If you still cannot get consistent tension, then your machine may need service.
Apr 15, 2017 | Bernina Sewing Machines
How do I get the correct tension on my Elna 792D 4 thread overlocker?
ALWAYS Raise the presser foot when threading the machine. Give each thread and extra little tug when threading the tension disks so it seats completely. The midway point on the tension disk is the standard factory setting when using the standard thread weight, however, with use, age, and thread weight that setting may change. So, the user can use the midway point as a starting point for the basic overlock stitch but will need to make adjustments to get the correct tension. When testing your tension, it works best to use the 4 thread colors so it is easier to identify which thread is misbehaving. When you become familiar with your machine and how the stitch looks, it is easier to identify which thread is which.
The Anatomy of The Best Serger Tension My Tips Bonus Unpick it Serger...
Make It Handmade Perfecting Serger Overlocker Tension
Solving Serger Dilemmas
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=7&ved=0ahUKEwjjhv6Uw4PSAhXJrVQKHQrmCtgQFghBMAY&url=https%3A%2F%2Fwww.bernina.com%2Fen-NZ%2FExperience-NZ%2FSewing%2FSerger-projects%2FUSA-nz%2FSewing-Embroidery-nz%2FTensionHeadaches%2FBERNINA-Serger-StopTensionHeadaches-nz.pdf&usg=AFQjCNEAPID5FKBVa_amKfVmrTKgadlmRw&cad=rja
Remember that the tension settings will also determine the stitch you are trying to create. A basic overlock will generally have the tension set around the midway point, however, when changing to a rolled edge or some other stitch, certain tensions will be increased or decreased in order to create that particular stitch.
Feb 09, 2017 | Elna Sewing Machines
Has been threaded but will not sew
check needle thread tension --too tight
check bobbin has cotton on it and is threaded correctly in the bobbin carrier
check bobbin thread tension ---too tight
Feb 10, 2016 | Sewing Machines
Bernina 335 serger won't sew/overlock. carefully rethreaded the serger but that hasn't helped.
The 335 has a two thread chain stitch (stitch type 401), and the overlock side (right needle side), is a three thread plain overlock. If you are describing the plain overlock as the problem, I would first suggest the following in re-threading:
1. Thread the upper looper
2. Thread the lower looper
3. Thread the needle last (important)
If the needle threaded, you cannot re-thread the lower looper without breaking the thread.
In order to thread the lower looper, the lower looper must pass by the needle thus picking up the needle thread. So, instead of threading the lower looper thread underneath the needle thread, the looper would be threaded on top and cannot sew without breaking the thread.
Make sure that the threads are bedded between the tension disks. Check this by stretching the thread fore and aft of the tension disks as well as visually noting that the threads are not accidentally threaded behind the disks. You can also loosen the tension disks when threading so as to allow the threads to bed deeply between the disks.
Please reply with your observations.
Sep 27, 2015 | Bernina Sewing Machines
Fix thread tension?
maybe set to snap buttons?
Jan 13, 2015 | Sewing Machines
What are the tension settings for a janome ml 304 over locker?
Tension settings on an overlock machine vary by the stitch you are trying to accomplish. You can usually fine the correct settings in your manual. A good trick to setting tension is to start with 4 different thread colors so that you can see what thread requires adjustment.
May 17, 2014 | Sewing Machines
The tension on my overlock is not the good one,
make sure your thread is running between the tension discs and there is no fluff between your tension discs
Jan 19, 2010 | Sewing Machines
Thread wont overlock
When the thread breaks too often, try these, that goes for all sewing machines
1. Replace the needles,
2. Loosen slightly the tension of the needle threads.
3. The top threads are to thin,
4.The sewing (rotary) hook or looper, has burs,
5. Wrong threading
May 21, 2008 | Husqvarna Viking 1
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
