Question about Health & Beauty
I have a rascal mobilty scooter 8mph and the wire to the moter from the controller gets very hot if left running will Bern out do you have a idea what it is
The scooter has a 110v controller and the wire to the moter from the controller is going to melt all wire and connecers are ok could it be possible that the point's in the controller are s ticking together?how do I check the controller? Psychology I did try a smaller version controler and that did work fine but can't leave that one on cus too small and won't last doe's not over heat with this smaller one
  • Health & Beauty Master
  • 16,174 Answers
Bad connections, or the wire isn't a heavy enough gauge, so go thicker, and a multi-strand steel or copper core.
Posted on Dec 23, 2016
Does the owners manual have a wiring diagram in it for the rascal 230 electric scootetr
Hi marilyn, Sadly no mobility scooter manual will give you such information, i willing to help , what do you want to know ? faulty lights , thinking of fitting a new controller ?
Regards
Rob
Feb 15, 2016 | Electric Health & Beauty
Rascal 370 wiring schematic
I can't get the wiring schematic for my Pride scooter either.
For some reason these seem to be proprietary and only available
to their dealers. Try monsterscooterparts.com to see if they
can help you.
Aug 30, 2014 | Electric Mobility Rascal Scooter...
Wiring schematic rascal 600 24v electric
hi, firstly what controller is fitted (curtis) ? then i can give you a ideal controller wiring schematic but you won't get hold of a Rascal one..
Regards
Rob
www.gewizrepairs.co.uk
Aug 16, 2014 | Rascal 600 T Electric Scooter w Seat Lift...
I replaced the controller on a rascal 318 scooter
an aftamarket part can do this--but chec all grounds and wiring again-is the battery at 12.6volts-any less is a factor--seek a maintenance manual online or somethin similar at ur library
May 28, 2014 | Rascal 318 Electric Scooter
Rascal 600
Neil wood, the Rascal 600 DOES use an on board charger. What signal is the white wire looking for to make the scooter move is the question. 28v?
Apr 20, 2012 | Electric Mobility Power Electric Scooter...
I have a 245 Rascal Scooter. I need to know if I can lower the seat?
most rascal 235 and 245 scooters come equiped with power seat height control. you turn the key to the left and then the throttle lever becomes the seat height controller. the seat motor is ditectly uuder front of seat post. if it will not run follow wires to see that they are plugged up good.
Jun 09, 2010 | Golden Technologies Golden CompanioN II -...
Rascal mobility scooter will now only go backwards
On some scooters it is possible to change the polarity of the motor. If its a two brush motor (most are) you can just swap the red and black wires around in the connector plug for the motor. Make sure you get the right wires if you do this but I have to point out that there is obviously a problem with the scooter and I would strongly advise you to get it looked at by your local dealer as the problem is potentially serious and may cause other problems aswell. I cant really understand why it would only go backwards. May be a throttle pot problem or main controller fault. Either way, as I said, best get it looked at as even if you do swap the wires, it is most likely that the scooter will only travel forward at the usual speed for reverse, normally 2mph! Hope this helps...
Feb 24, 2010 | Health & Beauty
Rascal scooter mo 655 motor stops going up hills
the batteries could be the problem, is it possible to try some other batteries, silly question , how steep is this hill ? remember scooters cannot climb steep hills as the motor will shut down due to the increased load.
1 Year old batteries ok ? but if they get used on a non daily basis and are not fully charged after use, I would question the batteries but again the motor could be overloading,
How much do you weight ? sorry for the personal question but it all loads the motor and that increases the current and that will cause the motor controller to shut it down.
Jun 14, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Health & Beauty Logo
54 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
