Question about Husqvarna Garden
I bought the Husqvarna 141 chain saw maintenance kit.
It has the new fuel filter, but not the replacement fuel line. I need to know the fuel line diameter as well as the length to try to keep it at factory condition. Thanks...Gregg
    Sergeant:
  • 384 Answers
Most likely it is 6 mm.
Posted on Jul 21, 2009
How do you replace a fuel filter for 235e husqvarna chain saw
They are kinda hard to get them out but it is in the fuel tank on the fuel line just get it out the gas tank filler hole then pull off and replace with new one..
Jul 15, 2014 | Husqvarna 235e 16-inch 34.4cc 2-stroke...
How to replace pickup fuel line in craftsman chain saw?
The lines fit tight to prevent leaking. You must disconnect the fuel filter and pull the line out. Cut the new line end "v" shaped to allow you to push back into tank. Long needle nose pliers will complete the job.
May 01, 2014 | Husqvarna Chain Saw 20" Bar
HUSQVARNA 41 CORRECT FUEL FILTER TO BIG FOR MY FUEL LINE IN TANK--DO I NEED TO GET BIGGER FUEL LINE??
you can get saw specific parts from a Husq. dealer or you can make shift something to get you by. the key is to make sure the hole in the tank is slightly smaller then the diameter of the hose to ensure there is no air leak there. I drill the tank hole out a size at a time until I have to force the hose in that will fit snuggly on the carb inlet then replace the fuel filter with one that fits the line
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Mar 20, 2013 | Husqvarna 36 41 50 51 55 136 141 154 254...
I have a Husqvarna model 444 chain saw. The fuel pick up line disolved in the fuel tank. How do I replace?
order new fuel line and filter from www.randysenginerepair.biz
remove top cover, remove air filter, remove fuel line from carburetor, empty gas tank, pull remains of fuel line out of tank and replace with new.
Aug 25, 2010 | Husqvarna Chain Saw 20" Bar
Husqvarna chain saw Model 141 running at high rpm's
You may wnat to inspect the intake manifold/boot that mounts inbetween the cylinder and the carb. Also, the impulse tube that comes from the bottom of the cylinder to the carb manifold or carb itself. Sounds like you are running a lean condition. You need to locate the source very quickly, or continued operation will permantly damage the saw. I have listed a few other things to check.
Please let me know what you find. rwvanlue
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled (black and carbon deposits)
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 13, 2009 | Husqvarna Garden
Describe your Husqvarna "Chain Saw -
Remove the spark plug and test for spark. If ok, try some starting fluid in the plug hole, install the plug, and try to start. If it runs a short time, it is not getting fuel. Check fuel lines including inside the tank. Clean or replace the air filter. If this saw is fairly old, the carburetor probably needs a re-kit and cleaning. Does it have good compression? Check the muffler for plugging. Make sure the fuel/oil mix is fresh. Good luck!
Sep 12, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Fuel line for Stihl 025 chainsaw
there is a good video on this problem on you tube. should be easy to find.
Dec 20, 2008 | Husqvarna Chain Saw 20" Bar
''How do I change the fuel filter on a Husqvarna 141 Chainsaw''
Hi michael
Just follow the fuel hose from the carburator and see where it is entering in the fuel tank.Fill out the gas from the fuel tank.At the end of the fuel hose is the fuel filter.Take them out (hose filter and fuel filter),then change it.Disassembly the carb and carefully cllean the inner parts.
:-* best wishes savumihai71
Dec 04, 2008 | Garden
Garden Logo
341 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
