No sound on my television - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 8,248 Answers
My Vizio gallevia 1080 progressive liquid crystal hdtv has no sound-see details for question/detail..
Here are the most common reasons you may not have sound.
Starting with the most common solutions for no sound from TV:
Television Has No Sound Answer 1: Make sure TV is not muted.
Television Has No Sound Answer 2: Make sure the TV is not set to SAP (secondary audio protocol)
Television Has No Sound Answer 3: Make sure TV input is correct (someone may have accidentally pressed the "aux" input button or similar causing the TV to use an input with no sound going to it)
Television Has No Sound Answer 4: Make sure there is not a pair of headphones connected to the TV audio out jack on the side or front of your TV.
Television Has No Sound Answer 5: Check all of the cables that are connected into the back of your TV. (it is possible the TV was moved slightly and a cable has become disconnected or loose)
Television Has No Sound Answer 6: If you have a receiver or surround sound connected to your TV, turn it on and see if you get sound coming from the external speakers.
Television Has No Sound Answer 7: Turn off the TV, cable box, and anything else connected to the TV. Sometimes turning everything off and then back on can fix the problem.
Sep 28, 2016 | Shopnbc VIZIO Gallevia 42" 1080p LCD HDTV
Connecting sound bar to proscan TV
Proscan has released hundreds of models of televisions over more than two decades, so I can't be specific without more information. There are also hundreds of different sound bars on the market. The answer given should apply to all situations:
Ideally, the sound bar should be connected to the television using one of the methods (in order of preference):
  • Optical cable output from the television into the optical cable input to the sound bar; (best)
  • SPD/IF coaxial output from the television into the SPD/IF coaxial input to the sound bar; (really just as good)
  • RCA R/L outputs into RCA R/L inputs to the sound bar. (not nearly as good as either of the above)
Jun 03, 2014 | Televison & Video
Sound on tv went completely off
Hello there,
The problem simply is that the sound IC is bad that is why the sound went off completely. First be sure that the television is not on mute, then you go ahead to replace the sound IC.
To replace the sound IC, turn to the back of the television, but before you do so, turn of the television and allow the high voltage dissipate for a while before you start working on it.
Unscrew the screws around the television, then you open up the back cover, then you trace the wires of the speakers, it will lead you to a board, on that board is where the IC that is bad is lying.
Have the board replaced or fix the bad IC and the television will produce good sound once again.
Hope this helps. Goodluck Elect_Comp
Aug 28, 2011 | Panasonic Televison & Video
How can I connect a 5.1 sound system to a sharp
Sharp televisions don't work like you need them to when connecting them to a 5.1 sound system. You can connect them with a fiber optic cable from their digital audio out to the sound system's digital audio in BUT when you turn everything on no sound comes out of the sound system. So you start checking connections and troubleshooting, call Sharp, and maybe even call the sound system manufacturer. You may get a customer service representative knowledgeable enough to explain to you that Sharp televisions were designed without center channel capability. This means that the only use for the digital audio out is to get sound from your sound system when watching tv channels when your Sharp television is connected to your rooftop antenna only or directly to basic digital cable with no cable box or satellite tv receiver. Yes I just stated that you only connect the sound system to the Sharp television when you are watching over the air broadcasts or basic digital cable without a cable box.
People say "but that doesn't make any sense." But it is true. Sometimes you will get lucky and connect a Sharp television to the sound system with the fiber optic cable and get sound out of one of the devices you've connected to the Sharp television with an hdmi cable. You will then be directed by the customer service rep to connect all your devices to the sound system and connect them all to the television as well OR connect all your devices to the sound system with hdmi cables and connect the sound system to the television with one hdmi cable.
Jul 19, 2011 | Sharp LC40E77U LCD TV
The Sound has gone out on the TV.
HERE'S THE ANSWER TO YOUR PROBLEM:
There are times that TV sound problems does not require you to call for a technician. Some TV sound problems are just easy to repair, and you can just do it yourself. Try to do this one:
1. Press the "Mute" button on the remote control or press the "Volume Up" button. The most common cause of no sound is accidental use of the television's "Mute" function.
2. Make sure the speaker source switch on the back of the television is switched to "Int" if you are using the television's speakers and "Ext" if using surround sound. If not set properly, you will not hear the television sound.
3. Access the television's equalizer by pressing the "Menu" button, selecting "Sound" and then "Equalizer." A list of sound options will appear on the screen. Use the up and down arrow buttons to select the option you want to adjust, and the right and left arrow buttons to make adjustments to the option. You should use this method of adjusting the sound settings if the audio output is in some way unusual.
4. Check the surround sound speaker wires and make sure they are secured to the audio jacks on the back of the television. In addition, ensure that the surround sound speakers are powered on.
If it does not work still. Contact your service provider. Thanks...
Jul 04, 2011 | Protron PLTV-32 Television
TC-P50GT25 Viera has no audio out put.I need to connect surround sound.
In that case all you can do is connect each device you're connecting to the television to the surround sound. You would connect the device to the television for video only and connect the sound cables to the surround sound. You may also be able to connect the devices directly to the surround sound (video and audio) and then connect it to one of the television's inputs.
May 07, 2011 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Good evening. When you connect the computer system unit to a television sharp lc-32a47e AQUOS not hear the sound. Explain why. Thank you
The reason that you may not be getting sound is the cable you are using to connect the computer system to the television. Without that specific information I must speculate that this is the case. The only cable that carries both video and sound is hdmi. If you are using an hdmi cable then you must go to your compute system's sound properties and designate hdmi as the choice. Even if you are using dvi to hdmi it will not carry sound. A VGA (an RGB) cable will not carry sound.
On this television in particular there is input #7, which has an input for the computer system and an audio jack so you would connect an audio cable between the computer system and the television. It does not appear that you have to designate input #7 for audio to the television when doing this. It appears that the sound will come through automatically.
Feb 08, 2011 | Sharp LC-32D6U 32 in. LCD Television
Tv stopped playing sound. picture still perfect but no sound when watching tv or dvd???
If Your television keeps showing the picture and has no sound, then it means there is a problem somewhere. First check if the television is not in mute mode by pressing the increase volume button from Your remote. Once You have checked the volume and seen that the problem is not from the volume control. If that is confirmed not to be the problem. Then it means the sound IC of the television is bad. To replace the sound IC, please follow the steps below.
  1. Power off Your television,
  2. Unplug it and leave it to rest for about 6 hours, because television stores high currents, so leaving it will dissipate the high current,
  3. Get a screwdriver, a glove a cup and a replacement sound IC,
  4. Wear the gloves and unscrew the screws behind the television to take off the back cover,
  5. Trace the wires that are from the speakers to main board where it is connected to,
  6. Then You See the panel it is connected to, that is the sound IC,
  7. Disconnect it and replace it with a new one,
  8. Reverse the process to reassemble the television back together,
  9. Power on the television and try to play anything that has sound.
You can the television to a deck and use it as an auxilliary for Your television.
Hope this helped. Thank You for using FixYa!!!
Jan 18, 2011 | Televison & Video
NEONiq HD TV MODEL LEH21F8 FROM FOX TO SET GOT PICTURE NO SOUND
The sound IC of your television is bad that is why you have picture but no sound.
The sound IC is the card that the speakers are connected to, and it is connected to the main board of the television.
Once you get the sound IC replaced, your television will be in good conditions once again.
Take care
Oct 10, 2010 | Televison & Video
Television sound
First unplug the unit and leave it for about 5 min.,then plug the unit in and see if you have sound,if not check to see if the speakers are on in menu,if they are on,sounds like the outputs or maybe the e prom.
Nov 21, 2007 | RCA P52930BL 52" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
