Question about Sony Televison & Video
KV-32HS420 problem standby light blinks 7 before repair
I have replaced the IC6501 & IC8002. Now it blinks 6 times . Can some one tell me what to do next. I have a service manual for this unit & i am an electrician. Very handy with my tools and can perform some repairs.
Please advise
  • Eric Vanderberry Jul 21, 2009
    Yea I read that. Can't locate said parts. Check C515 & 516 and the jungle IC, IC206.
    When I search my manual is pdf., it doesn't come up. Spent 1.5 searching the board for them and don't see them. I'm not very familiar with the manual and terminology. Can you help further?
    I do appreciate it
    So what board are these items on/located? DZ? or what?
    Thanks again!
  • 3,037 Answers
Right from the Sony manual, sounds like you know what you are doing
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
Let me know how this turns out.
Benjamin
Posted on Jul 21, 2009
  • Benjamin Patri
    Benjamin Patri Jul 21, 2009
    This indicates that you should look at three components: 2 caps and an IC. The C515 and C516 are capacitors the the IC 206 is an integrated circuit.
    Radio Shack will have the parts
  • Benjamin Patri
    The fault and parts lie within the horizontal circuitry. It is pretty
    complicated to dig into this section unless you are a trained tv
    expert. It will still require some investigation to determine the
    exact problem area. The jungle IC spoken of in the Sony blink code is
    a monster that operates over a hundred circuit functionalities. It has
    inside almost 1 million transistors. So, it takes some skill to check it or replace it.
Sony Trinitron Problems - Red light blinks 6 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully.Visit this site " Electro help "for more details. Google for it.
It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Apr 23, 2015 | Sony FD Trinitron WEGA KV-32HS420 32" TV
I have sony crt tv problem of 4 time blinking not stand by model no kv-21L70
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given
Mar 04, 2014 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Stand by timer sony triniton color tv Model kv-32hs420
How many times the standby button blinks before going OFF at one time switch ON?
Apr 17, 2012 | Sony FD Trinitron WEGA KV-32HS420 32" TV
I have a Sony Vega KV 32HS420 it will not come on and bliniks 6 times. what is up?
Try replacing IC8002 and IC6501 (MCZ3001D).
Hope this helps.
Apr 07, 2011 | Televison & Video
My Sony KV-32HS420 won't turn on -- blinks 7 times, pauses, blinks 7 times. I've seen the same problem described on this site, and the answer seems to be that 2 ICs on the DZ board need to be replaced. I'm...
The 7 blinks on this model indicates that the horizontal section of the TV has stopped working. Horizontal Deflection Stopped
Occurs when either:
1) a +B overcurrent is detected (IC5007), or
2) overheating is detected (Thermistor TH5002).
I have the serrvice manual if you need it. Let me know where to send it to.
Dec 16, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
My sony wega 32hs420 timer light is blinking 7 times stops then blinks 7 times and so on. do i need a repair man to come look at it?
Yes,this problems must have parts change.Repair and parts should be under $250 more than that not worth it to repair old CRT tube tv.High Voltage parts are dead must get it replaced.
Jan 23, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Light blinks 6 times, no picture, no sound
6 times blinks shows error of Low +B, OVP/ OCP
Replace IC6501 & IC8002 [ MCZ3001D ] on D board.
If you are handy with electronics stuff repair and can solder parts in circuit board then replace above said ICs or call local TV tech to do the job.
Thanks.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32HS420 won't come on.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 02, 2017 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Sony KV-32HS420 will not come on has blinking standby light
Get out your original remote and hold the "Setup" button at the same time as holding the On/Off button on the TV set. It just worked for me!! Thank goodness. I was just about to bring it for repair but there's a snowstorm. Here's the link I got this from: http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=http--esupportsonycom-perl-tutorial-displaypltutid297templateid1regionid1KSMFlag7370&sliceId=&docTypeID=DT_TUTORIALS_1_1&dialogID=53101564&stateId=0%200%2053105132
Nov 16, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Blinking Standby Light
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Jan 31, 2008 | Televison & Video
Televison & Video Logo
63 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
