1E error is coming what would be the problem - Washing Machines
2 Suggested Answers
SOURCE: Lens wont retract, makes noises, error code on blue screen D:1E 1A
I posted the same problem on the 15th June and in the meantime I have been playing around with the camera. After holding the camera upside down and gently tapping the back of it, the lens decided to work and retract back into the camera. Not the most technical advice I know but it seemed to work.
Posted on Jun 29, 2008
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
Showing a 1E error code
You need to post more info like a model number
Aug 29, 2016 | LG Dishwashers
WHAT DOES ERROR MESSAGE 1E MEAN AND HOW DO WE FIX IT?
On LG's, a 1E error message usually means there is a problem with the water inlet valve. Check your shutoff valve under the sink, first, just to make sure someone didn't accidentally turn it off. If it's on, then it's most likely the water inlet valve located under the dishwasher.
Oct 18, 2014 | LG Dishwashers
1E error code
The Flex zone Temp sensor is the most common issue. check your model number suffix to make sure the part is correct:
http://www.appliancepartspros.com/samsung-temperature-sensor-da47-00095e-ap4136048.html
Best,
Joe
Jan 31, 2014 | Samsung RS2534 Side by Side Refrigerator
How can I fix the error code 1E in my washmaching samsung SW70A1P
Error 1E is no pulse to weighing sensor to open and closed valve.
Step to solve:
1. Open top cover (behind door cover)
2. Check connecting cable of pressure switch, pull out and clean up connector (usually dirty with rust)
3. Open back cover, pull out pressure switch.
4. Clean up hose of pressure switch, blow the hose slowly.
5. install again pressure switch to the position.
6. Install cable to connector, check the current & resistant by tester.
7. Push "on" selector and fill drying position, wait until digital no blink. Running test.
8. If machine is running well closed the cover.
If still error condition (1E Error still come out), change part of "Pressure Switch" by the new one.
Regards,
Priyo
Nov 16, 2010 | Washing Machines
My lg wm12225fd direct drive error 1E
Is it 'IE' ? There is no '1E' error code. Input error. Is water turned on? Are waterline filters clear, the ones between the hose and the unit?
Apr 07, 2017 | LG Washing Machines
Error message 1E is displayed at start up samsung model SW75C3S
1E error mean there is malfuntion on your sensor pressure. Maybe because the sensor is damage or rusted. You must replaced, it's cost me about $15
May 19, 2009 | Samsung SW62ASP Top Load Washer
LG LDF7811ST 1E code
Are you sure it's 1E and not LE error code??  The symptoms you mentioned indicates that it is an LE error code and the motor has an issue.  You will need to call a qualified LG technician to diagnose and resolve the problem.
Jun 28, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Nov 18, 2006 | Olympus Camedia C-60 Zoom Digital Camera
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
