Question about Refrigerators
Icemaker will not fully make ice - Refrigerators
I unplugged my frigidaire pn 241691311 unit and now my icemaker won't make ice. Any suggestions on how to get it to work again?
If the icemaker was removed and reinstalled, double check to make sure the plug is fully engaged and the ice bin shut off arm is back to the down position.
Aug 31, 2014 | Frigidaire Refrigerators
I have a Kenmore Coldspot refrigerator with top freezer. The icemaker is "leaking" if it is the right word into the ice tray bin that it is building a chunk of ice along with the regular ice...
What that sounds like is the water valve isnt fully closing. This tipi wrote is about that issue,
Reply with your exact model number as found on a label usually on the ceiling of the refrig. compartment and i will give you the part number for that water valve.
Sep 05, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a GE Adora side-by-side refrigerator Model # DSD26DHWA-BG. About 1 year ago the ice maker stopped producing ice. The mold that forms the ice cubes is filling up with water but never pushes out...
Hello, there are three screws that hold the icemaker in place if you remove these three screws and unplug the icemaker and remove it from the unit. After you take the icemaker out take the entire unit with the cover on it and run it under hot hot water this is actually quiet common for an icemaker to freeze up well actually its the parts on the inside of the icemaker that are freezeing up. After you defrost the icemaker as I term it then you would dry the icemaker and reinstall it. when the icemaker reaches 32 degrees the icemaker will call for water once again from the water valve if at this time after the ice forms the unit still doesnt drop the icecubes then you would have no other alternative then to buy another icemaker they usually sell for around 50-90 dollars american. The icemaker is not worth replacing parts on due to if you were to replace parts on the icemaker you would end up spending about 4 times as much as the entire icemaker costs. If you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks again Rick
Jun 04, 2011 | GE Refrigerators
if water was leaking consistently then you would have an issue with the water valve in the rear of the machine whereas if it were overfilling the icemaker ice tray this would be a seperate issue with your icemaker and you would have to replace the icemaker best thing to do is turn off the water line that comes in from the rear of the machine There are no repairs for the icemaker that I would suggest seeing how it would cost you 4 times as much to do a repair to an icemaker rather then just buying a new one if you have any further questions message me back and please remember to rank how this opinion has helped when our chat has fully concluded it allows me to help others in similar situations in the future Thanks again Rick
Apr 28, 2011 | Frigidaire FRS23R4A Side by Side...
My boat u-line icemaker shutoff arm does not go down fully. I need to manually push it down last half inch to begin next cycle. Any suggestions?
You shouldnt have to do this. I would replace the faceplate of the icemaker head. Then while the head is off take a flashlight and look at the housing to make sure the support housing isnt broke.
Jul 06, 2009 | U-Line Icemaker
I have this ice maker and after 6 months I had to call for a repairman and they fixed it and then came back and told me to shut it down and not to eat any of the ice because it was contaminated but they...
Whenever the icemaker is worked on, the water in the tube feeding the icemaker has the potential of picking up a little rust or other debris from the fittings that are opened up.
To fully put your mind at east just toss out the first two batches of ice, tand the first six cups of water to assure that both your ice and your water are clean and fresh.
Jul 02, 2009 | Refrigerators
Maytag mzd2766gew icemaker
Sounds like you have a bad motor module on the icemaker. Part # is W10122536
Jan 05, 2008 | Maytag MZD2766GES Side by Side...
Ice maker is dumping ice but arm is not fully going all the way down
Is your Ice bin filling up too much? Frigdaire did have problems with there ice makers, and I belive the new ones come with a arm extention. Your one of the lucky one's and your icemaker still makes ice! I dont know how old your unit is but they were replaceing icemakers under a factory warrenty. I could be wrong but I think they were doing it up to a 5 year old unit.
Jul 15, 2007 | Frigidaire FRS23H7CS Side by Side...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
