Question about Furniture
How do I DISassemble my RealSpace Pro 3000 chair? Specifically, how to detach the old SEAT PLATE from the GAS LIFT so that I can replace the seat plate
dromtonpa
  • 40 Answers
SOURCE: Unable to remove seat to replace batteries
Sometimes it just takes two really strong people to remove these seats. Especially if it is that old. I`m not saying damage the chair,but i`ve had some that were almost impossible to remove.
Posted on Mar 26, 2009
dromtonpa
  • 40 Answers
SOURCE: JET 3 POWER CHAIR SEAT REMOVAL
Sometimes it just takes some real elbow grease to remove those. Try two people one on each side.
Posted on Mar 31, 2009
stiskau
  • 14 Answers
SOURCE: fitting an isofix car seat in a ford cmax 57 plate tdi
if there are a small part of the backseat (ca 10 cm high located at the bottom of the back) that can be picked out, you have isofix points.
if your backseats are in one pice, theres not
Posted on Apr 11, 2009
SOURCE: Harley Rdkng FLHPI police seat air suspension mechanism removal.
There are two screws below the rubber stem fixed it to the frame. You can hardly see them from any angle but can reach them through the two round openings next to the stem. Use a small wrench, through the openings, to access and remove the screws, then you can remove the stem. However, keep the entire police seat assembly since you might want to put it back like what I am doing now. I tried serveral Harley and other brands seat, high or low profile, and found the police seat is the most interesting seat to ride with.
Posted on Apr 14, 2009
  • 496 Answers
SOURCE: I have a Honda accord
According to the factory wiring diagram for a 2002 Honda Odyssey, the seat heater switch hi/low indicator lights won't light up unless the seat heater relay is good. The seat heaters have thermostats and circuit breakers that limit power to the seat heaters under the following conditions:
Thermostats: On below 93F and off above 109F
Circuit breakers: On below 86F and off above 122F
The breakers operate in series with the thermostats and serve as backups to faulty thermostats.
Posted on Mar 10, 2011
Looking for replacement shock for seat bar lift.
Amazon.com: HomCom 3.2" Universal Replacement ...
www.amazon.com/...Replacement.../B008XVEZG8
Amazon.com, Inc.
Rating: 4.2 - ‎123 reviews
Office Chair Pneumatic Gas Lift Cylinder Piston Replacement - Universal Size ... much right on the money and I have to say that the price just simply cannot be beat when you start looking for pneumatic gas lifts! ... ·With PP gas bar cover ....Replacement Office Chair Gas Lift Cylinder Pneumatic Shock - 5" Travel - S6111.
Lift Kits -Body Suspension Lift Kits, Bump Stops & Sway Bar ...
www.4wheelparts.com > Suspension
Lift Kits -Body Suspension Lift Kits, Bump Stops & Sway Bar Bushings ... ShockAbsorber Bushing. Upgrade or replace your ... Shock Link Kit. Shock Link Kit. Lift ...
Complete Suspension Systems and Lift Kits - 4 Wheel Parts
Dec 27, 2015 | Toys
I am returning a chair. the manual said to discard the seat plate,gas lift W/cover & chair base. How will this affect the return ?
You should coordinate this with the vendor you are returning it to and do it exactly the way they say.
Aug 23, 2014 | Health & Beauty
How to dissemble to travel
The M41 was not made to disassemble. The seat is the only part that is made to remove. The seat has a release level under the right side of the seat. To remove the seat lift up and hold the lever up as you lift the seat straight up off the center post. Do not forget to unplug the joystick cable from the base of the chair before lifting off the seat.
Jun 24, 2014 | Electric Mobility Invacare Pronto M41...
Invacare M71 surestep disassembly
hi there patty ,as a Invacare tech ill try to answer your question, first rotate seat by pulling the lever up on the right side of chair rotate and lift seat up takes 2 people gen. then remove the 4 screws that hold the shroud on that allows you to get at the control box, batterys, and the gearboxes and motors better and motors better
Mar 31, 2014 | Invacare Pronto M51 Power Wheelchair
How do you fold this chair for transport
I don't know about yours but on mine you just grab the edge of the seat in the middle and lift up. That folds it easily.
Mar 17, 2013 | Drive Infinity Wheelchair, 18" Seat,...
CAN'T LIFT OFF SEAT OF JET3 POWER CHAIR? batteries
Richard The seat is probably rusted on the seat post It will take alot of turning and pulling upward at the same time to get it off. Try spraying a penetrant on the post just below the seat to see if that will help with the turning and pulling just keep at it. It can be a tedious task and frustrating Hope this helps
Mar 16, 2011 | Jet 3 Ultra Power Chair
Hi. Just got a new Jazzy Select 6 Ultra, with the seat lift. Only now am I finding out that the seat lift raises the minimum height of the seat so much that I can't fit under a normal size table. I have...
Bruce,
There are several approaches to a solution tof the problem you are experiencing.
This chair may have a standard van seat or rehab seating. A standard van seat looks like an SUV seat and a rehab seat has a custom seat and custom back. FYI, the Jazzy Ultra 6 specification for the seat actuator is 4 inches of stroke or elevate.
If you have a van seat the cushion will be too high in its lowest position.
If you have a van seat the vendor can switch it out for rehab seating. Rehab seating is a seat pan (flat plate) with a cushion set on top of it. By varying the cushion thickness you can raise or lower what is technically called the seat to floor height measured from the top of the cushion to the floor. This is what you describe as the minimum seat height.
If you already have rehab seating, you might try a thinner seat cushion, going from 3" to 2" with a denser material.
The chair frame and actuator dimensions are locked in so this dimension cannot be altered. On some occasions, I have been able to remove some top actuator frame plates, but this will only help with about 1/4" of height and substantially weakens the seat to top of actuator mounting. Sometimes this reinforcing plate will be on the bottom of the actuator in the battery box frame.
The chair can go back to the factory and a custom modifications to the seat frame can be made. This is always easier and more cost effective on the front end at time of order of the chair. An inquiry would need to be made to Quantum (Pride) to see if this is even possible.
You may also be able to get a Motion Concepts custom, i.e. shorter actuator (less than 4 inches of stroke). This will also decrease your elevate to less than 4 inches.
Your provider and an experienced rehab tech can come up with some viable solutions. Hope this helps.
Dec 31, 2010 | Pride Jazzy Select 6 Indoor Power...
How hard is it to remove the seat for transport in a SUV
jim not too hard unless its not been removed in a while. Unplug the joystick cable running to the rear of the chair pull up the seat release lever usually on the right side of the seat and twist and lift up on the seat at the same time hopefully the seat will lift right off. Now before you try all that remove the headrest from the rear seat and lift up on the seat adjustment lever and fold the seat back forward as far as it will go. Measure the heigth of the chair in that position and measure the heigth of your SUV opening if it is 3-4 inches lower then the chair should fit without having to remove the seat. You could also unscrew the armrests where they go into the risers at the rear of the seat and lay them on the back of the lowered seat back and drive the chair into the SUV using a ramp. This used to work for me when loading into a Jimmy SUV Hope this helps you
Nov 18, 2010 | Pride Jazzy Select 6 Indoor Power...
Directions to replace the battery in a jet3 power
Unplug the joystick cable under the seat remove the seat if on a post lift handle on right side under seat and lift seat off post if not look for release levers behind front seat post and seat will rotate backwards to give you access to the batteriesdisconnect battery cables and install as on old batteries to new ones and reinstall Hope this helps
Aug 02, 2010 | Jet 3 Ultra Power Chair
Furniture Logo
112 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
