QCA Malta 175BD model which I believe same as the Mystic. Stopped heating giving me Sn error code alternating with current temp which has dropped to 78 so it is not a temporary condition.
jumptrout51
  • 3361 Answers
SOURCE: Temp set for 78, fan continues to run, this am temps were at 64
You should replace your thermostat.
Posted on Sep 17, 2009
Coastsider
  • 331 Answers
SOURCE: mystic hot tub doesn't stay hot enough
Is your spa wired for 110Volt or 220V?
Posted on Apr 14, 2010
Coastsider
  • 331 Answers
SOURCE: THE ERROR CODE READS SN.
Did you replace both temp sensors or just one? Did you make sure that the new sensors are the same model? If you did replace both sensors with the correct ones, the main board is bad and will have to be repaired or replaced. The actual manufacturer of your controller can provide limited technical support for someone who has the ability to use a multi-meter and test a few components at the spa over the phone.
Posted on Sep 08, 2010
adamh294
  • 310 Answers
SOURCE: QCA Dream Series, Mystic SPA.
After refiling a spa, typicall the water is below 50 degrees F. Spas have a freeze protection in their programming so that when the water is that cold, the pumps run constantly to keep it from freezing. It will correct itself
Posted on Oct 28, 2010
SOURCE: Kelvinator Dish Washer Model KD14SS
mine is doing the same what can it be
Posted on Mar 05, 2011
Jacuzzi j210 heater
bad temp sensor replace
Feb 01, 2014 | Qca Spas Pool & Spa
Heat pump?
There could be several issues at work here.
  • First, is the heat indicator light showing on the topside?
  • Is the pump running but temp is not rising?
  • Any error codes displayed on the topside panel?
The drop in water temperature could be caused by a faulty temp sensor or faulty high limit sensor.
Check those items out and see what you come up with.
Rod
US Parts Center
888-521-6183
Mar 14, 2013 | Pool & Spa
Overheat errors
possible temp sensor bad if ok bad control board
Feb 25, 2013 | Balboa Instruments BALBOA VS500Z PUMP ,...
Hot tub pump noisy, heats to set temp, fl error code
This sounds like your motor is going out. When they get noisy and run really hot is when they go out
Rod
US Parts Center
Jan 08, 2013 | Qca Spas Jewel Series Topaz Plus Hot Tub
OH error QCA spa High jets work and heat
OH is the overheat code.
Your spa temperature is set above 108, or your thermostat is faulty & not reading correctly.
Jan 23, 2012 | Qca Spas Jewel Series Topaz Plus Hot Tub
QCA Dream Series, Mystic SPA. Drained, cleaned and re-filled. Following power restore (and 5 min or so prime cycle), the the pump runs continuously at low speed - it NEVER stops. Everything else works fine...
Aug 09, 2010 | Qca Spas Dream Series Dream Master Hot Tub...
Reset error code hot tub
tub is in sleep mode usually to change u must press temp button then light button you want to b on standard mode STD
Oct 04, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
