Question about Maytag Kitchen Ranges
Can anyone tell me what the maytag stove error code F2EO is please?
The stove top is working but the oven went out last wk. Today it turned on and then within minutes the error code appeared.
SOURCE: stove and oven not heating---display works. no error codes
faulty element
Posted on May 13, 2007
fridgetech
  • 473 Answers
SOURCE: Kitchen Aid KESC300 smooth top electric stove
Look on the back of the oven for a tech sheet. This will tell you what the code means and what to check. May be an oven temp. sensor or oven control bad. Can't remember what f7 is without looking at the tech sheet.
Posted on Oct 06, 2007
  • 1314 Answers
SOURCE: F3 error code
f3 is the code to replace your oven sensor most you replace by pulling the back panel and removing the scerws
Posted on Feb 18, 2008
SOURCE: MAYTAG GLASS TOP STOVE
I had the same problem, all you do is hold the clock button down for about 5 seconds.
Posted on Mar 11, 2008
codfish124
  • 36 Answers
SOURCE: range flashing code f2eo
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open
Posted on Dec 13, 2008
I had a power outage and now my kenmore ultra bake glass top stove, has no power to oven.only when i hold cancel button for few secs"F2EO" shows up on screen. 4 burners still work,along wif oven light
The error code E0-F2 indicates that your touchpad has a stuck key. You might try disconnecting the electricity from the range and pushing and releasing the buttons on the touchpad several times. Be aware as you push them of any button that feels different. If you notice one that is stiffer or just doesn't feel like the others, give it several more pushes. Worst case scenario, you will need to replace the touchpad.
Jan 19, 2018 | Kenmore Kitchen Ranges
My maytag flashes the code F1. What does that mean?
I just went through the same thing. According to what I have researched, it means a problem with the touchpad. Found out the clock/touchpad can run up to $200 to replace minus labor. I had nothing to lose so I took the back panel off the stove, took out the unit which is held with 4 screws, and used alcohol on a qtip to clean the circuit board. Mind you the stove is 15 years old and wasn't about to pay 200 dollars for a part. Put it all back together and the error code went away and the oven is now working again. It is getting me through Thanksgiving but I am buying a new stove because I don't know how long this repair will last. You have to consider the age of your range and what you are willing to pay.
Oct 18, 2014 | Maytag Ovens
Error code F2EO
Hello Marie,
The F2EO error code means that button on the keypad has shorted out and the keypad(touchpad) needs to be replaced.
GENE
Nov 06, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
I have a maytag performa ceramic top stove andwhen I turn on the oven it will only heat up to 230 degrees
I have a Maytag Performa Ceramic stove top which I have "washed" the serial number, I broke the glass top and need to replace it, but I don't have the model/serial number. If anyone has one please give me the numbers. Thank you
lilkadoc@hotmail.com
Apr 27, 2010 | Maytag Kitchen Ranges
F9 error
hi there,
can you tell me the model # on your stove please?
Sep 14, 2008 | Maytag CWG3100A Gas Single Oven
F3 error code
Feb 17, 2008 | Maytag MGR5750 Gas Kitchen Range
Maytag top oven lock won't lock
Do you get any error codes? What shows on the display when you try? does it make any noises , like it is trying to lock? Is it a manual lock with a lever?
Jan 19, 2008 | Maytag MER5775Q Electric Kitchen Range
Kitchen Ranges Logo
46 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
