Question about Singer Sewing Machines
I have a 9020 singer sewing machine I bought without a manual. I can't seem to sew without looping the thread under it. Almost in knots.
  • Singer Master
  • 11,756 Answers
Are you saying the upper thread is knotting under the fabric as it stitches? This is bird nesting or thread nesting and is generally caused by mis-threading, the thread not being seated in the tension disk, or the upper tension too loose.
When threading the upper thread, ALWAYS RAISE the presser foot. Verify that the machine is threaded correctly. If one guide is missed, the stitching will go haywire. Start out with the upper tension set around the midway point and then tweak it through test stitching.
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Posted on Dec 23, 2016
My bobbin isn't sewing correctly
If the bobbin stitches look out of whack, your machine is probably threaded incorrectly. rethread with the presser foot up and see if this fixes the problem.
May 20, 2016 | Singer Inspiration 4206
Singer touch sew 645
Singer website has a plethora of manuals to download, http://www.singerco.com/accessories/instruction-manuals is the link, your manual is there for $15. If the bobbin thread is knotting up in the bobbin then I'd say you need to rewind a fresh bobbin and make sure it is smooth with even tension as it goes onto the bobbin. If your bobbin thread looks a bit chunky and uneven, then you won't get good results from it. Also, check that you are putting the bobbin into the bobbin case the right way, the thread needs to come off the bobbin and make a reverse direction into the tension spring (assuming yours is a removeable bobbin case, not top loading)
Oct 11, 2013 | Sewing Machines
I hit a pin with my Singer Stylist 7258. It jammed. I changed the needle, rethreaded it, and turned it off and on, but it snarls up thread under the fabric, and seems that the thread does not always loop...
Good that you changed the needle. Did you rethread just the needle or did you rethread the machine? You may have already taken these steps, but if not, here is what I would suggest:
1. Replace the old needle (which you did), even if it looks ok, as it may be bent or have a tiny burr or other damage that isn't easily visible. Make sure the needle is seated properly - facing forward and fully inserted.
2. **Completely rethread the machine, making sure the thread is going through the take-up lever. It can easily pop out when the machine jams, and you can't always see that the thread is out of place. That could explain why the thread doesn't loop properly around the bobbin.
3. Remove the bobbin and clean any knotted thread or lint from around the bobbin carrier. Canned air is great for cleaning the lint.
4. Replace the bobbin, making sure the thread-end is clipped neat, not frayed or knotted.
5. Try sewing on some practice fabric to make sure the stitches are going to form properly before returning to your sewing project.
Apr 01, 2011 | Singer Sewing Machines
I have a Euro-Pro 7500. I can't seem to sew a straight stictch without the thread binding up from the bottom of the material.
Do you mean the thread knots and loops up under or over the fabric? If so it sounds like you need to re-thread. You may have not put the thread into one of the tension wheels correctly. Keep the presser foot up when you do it.
Jan 25, 2011 | Euro-Pro 7500XH Mechanical Sewing Machine
I have a singer touch and sew and the bobbin keeps knotting up when i sew. what could be the problem/
You may have tangled thread or the bobbin not threaded right. Totally rethread your machine according to your manual. If, you do not have your manual handy, download one for free at singerco.com. Good luck
Sep 12, 2010 | Singer Touch Sew 7462 Mechanical Sewing...
Thread bunches up under the fabric
For normal everyday fabric, tension should be 3-5.
If it is looping on the bottom, the problem is the threading of the machine. If it loops on the top then the problem is with the bobbin.
Mar 22, 2009 | Singer 3116 Simple
Singer 6412- thread loops up and knots up on bottom of material
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Good luck ..
Dec 31, 2008 | Singer 7462 Mechanical Sewing Machine
Threading CG-590
I have a CG590 SEWING MACHINE AND CAN NOT THREAD IT WITH THE DIRECTIONS THAT CAME WITH IT. CAN YOU HELP THANK YOU, SANDY
Sep 21, 2007 | Sewing Machines
Sewing Machines Logo
35 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
