Question about Crane Humidifiers
Crane et 2500x manaul - Crane Humidifiers
I am looking for more information regarding cranes, can anyone help me?
Tasked with lifting and lowering loads of varying weights, cranes have a fundamental role in many industrial environments. Because they are able to lift weights which would otherwise be impossible to lift, they are extremely important and valuable mechanical objects. Anybody who works with cranes or has worked with them in the past knows how complicated they can be - servicing and maintenance, usage safety, and installation are just some of the responsibilities associated with the lifting medium. The team over at Cranes Direct have complied all their expert knowledge into one handy infographic, titled "Essential Tips for Working with Cranes". Whether you are new in the lifting and lowering industry, or if you have been involved with cranes for years, this infographic provides you with all the information you may need. If you're perhaps looking for something more specific regarding a certain aspect of the equipment, don't hesitate to ask me!
Sep 13, 2017 | Humidifiers
Crane humidifier stopped working
My crane cool mist stopped misting. I always use filter water. Cleaned it with vinegar. What's can I do?
Mar 02, 2013 | Crane Penguin 1 Gallon Humidifier
Hi. It keeps going from the green light to the red light so its not generating any moisture. It does this on its own sometimes it runs for a while and sometimes it does it right away. Any idea what is...
This is usually a problem with the water float. Clean the float and assembly (see the instruction manaul) and that should fix it. The light is coming on cause the unit 'thinks' there is no water.
The unit works for a few minutes (green light) and then stops - is typical of a float that sticks when it gets to the bottom. So pay attention to that part of the assembly or the bottom of the float having grime or buildup.
Dec 12, 2009 | Crane Frog EE-3191 1 Gallon Humidifier
Crane Adorable One Gallon Cool Mist Ultrasonic Humidifier
I posted the instructions for cleaning the unit a little while ago, but under a different Crane humidifier product. See
Nov 25, 2007 | Crane Penguin 1 Gallon Humidifier
Humidifiers Logo
Top Crane Humidifiers Experts
Danny Kuhlmann
Andrew Taylor
Andrew Taylor
Are you a Crane Humidifier Expert? Answer questions, earn points and help others
