Question about Miller Welding Tools
225 bobcat Miller welder,generated I go-to start,blows fuse on#6 plug instantly i,m thinking it's the start run switch
  • 26 Answers
SOURCE: nopower
armature winds bad??? how old is unit ,maybe just brushes are bad
Posted on Jan 14, 2009
  • 100 Answers
SOURCE: i own a miller bobcat 225 nt where can i buy a
miller for less.com
Posted on Feb 15, 2010
luis_david
  • 407 Answers
SOURCE: Can i power this unit with my old Miller Bobcat
If your Hobart Mig is less than 250 amps then yes you can, bobcat 225 will give you10000 watts and you require at least 8000 watts for the hobart.
Posted on Jan 09, 2011
  • 18 Answers
SOURCE: Bobcat Miller 225 won't start.
Check the oil safety switch maybe it is bad. It will stop running if low on Oil or wont start.
Posted on Feb 19, 2011
wentlanv
  • 710 Answers
SOURCE: How do you drain the
Hi pplmelita,
If you don't have a petcock to turn the fuel off below the tank, I would disconnect the line at the filter and drain the gas out that way.
If you're wanting completely drain all old gas out, drain as above and then run until dry.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 14, 2011
I have a miller bobcat 225, it keeps blowing 30 amp inline fuse on a blue wire that runs to the hot side of the starter, any idea?
millerwelds.com will let you down load a manual for this unit, it can help you with this problem, also you can call miller and tech support should help
Jan 22, 2015 | Bobcat Miller 225 Welder Generator 907209...
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and forth to high then to low idle?
The unit may need recalibrating the idle/run setting. Instructions found in manual at 8-6 (subaru engine) and 9-5 (kohler). Idle speed around 2200rpm. Simple screw adjustment. PDF manual here :- http://www.millerwelds.com/om/o4434l_mil.pdf
Aug 02, 2014 | Bobcat Miller 225 Welder Generator 907209...
Location of oil switch onan motor miller welder
Hi Martin,
I do have this site that has manual for you in order for you to locate it and its function as well. Hope it helps.
https://www.millerwelds.com/pdf/spec_sheets/ED4-4.pdf
Apr 26, 2014 | Bobcat Miller 225 Welder Generator 907209...
My miller 225 welder will crank but not start, no spark, i tried jumping the oil psi sensor. what do i do next?
I had a problem like this a few days ago try taken of the air filter to were u can see the choke it may not be opening rite just cause it opens don't mean itsnot opening rite get a small spray bottle put gas in it and as u start ur welder spray the choke with with the gas a lil if it starts turn ur switch to run for while it workd for me if that don't maybe change the spark plugs
May 20, 2012 | Bobcat Miller 225 Welder Generator 907209...
Would like to know how much a used bobcat migwieldier costs?
Depending in the city you are in. Here in N California the average price for the Miller Bobcat 225 is 3,425.00. Try your local Praxair Distribution welding store.
If this was useful please vote.
Feb 23, 2011 | Bobcat Miller 225 Welder Generator 907209...
Bobcat 225 does not produce ac current 110 or 220?
Probably you need to act the braker, put the idle at max (pull throtle) and let it run for a minute, that will reset the braker.
Dec 03, 2010 | Bobcat Miller 225 Welder Generator 907209...
New fuel pump but won't pump fuel
start from the geginning. fuel tank- trash water etc. fuel line, valve open line not plugged, caberator clean and float not stuck closed. use air to blow lines out. good luck
Sep 02, 2010 | Bobcat Miller 225 Welder Generator 907209...
Welding Tools Logo
124 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
hubiam
hubiam
Level 1 Expert
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
