Question about Moen Showhouse S112BN Waterhill 10 Rainfall Showerhead, Brushed Nickel
Hours after I take a shower, the showerhead will start dribbing
The dribbingly can sometimes go on for minutes and be pretty heavy. Then it stops. I'm sure it's partially due to the large showerhead having built up water, but what causes it to then dribble out and should I be worried that I have a defective showerhead. It's a 10" rainshower head
    President:
  • 1,273 Answers
No, the showerhead is probably OK. My guess is that the head is relatively level, and the design of the nozzle allows water to pool inside. When you take a hot shower and turn the shower off, it begins to cool. As the shower head cools, a slight vacuum is formed, pulling air up into the showerhead. As you reach equilibrium, water is allowed to discharge as a dribble. This continues until the water has all been displaced. The fix for this is to turn the showerhead to the side, allowing the water to drain more quickly, and allow the air in. Try it.
Best regards, --W/D--
Posted on Jul 21, 2009
It's the Mini. Just dribbing and not filling more than 1/3 of the cup
It might be time to clean your Keurig. Fill the water tank with vinegar and run through 5-6 glasses after that it should start brewing regular sized cups again.
Apr 04, 2015 | Keurig Coffee Makers & Espresso Machines
My delta 400 shower is dripping
Take off the shower head and check the rubber washer inside. If it is cracked, off center, or missing, you will have a leak. Also, make sure you are using plumbers tape (teflon tape) around the male threads on the shower pipe that comes out from the wall. Sometimes the pipe leaks at the point where the pipe and showerhead are fastened together, but it looks like the shower head itself is dripping because water always flows downward so it goes over the showerhead at the top and drips off the side.
Nov 20, 2013 | Home
Dribbing oil from exhaust
You don't mention the year or motor type. Has any work been done to the motor? The problem you describe could be caused by a worn or improperly timed breather valve.
Jun 26, 2011 | Harley Davidson FLHT Electra Glide...
Dripping showerhead mirasport 8.5 kw - shower is approx 15 yr old when switched to off continues to dribble then drip for hours after
It is normal for instantaneous electric showers to drip after shutting down. However, yours sounds as if the water stop valve is failing.
You could have this replaced ( or even cleaned out, sometimes they can be affected by calcium build-up on the seal) but realistically it's probably best to consider unit replacement....15 years is an excellent service span for an instantaneous electric shower.
Hope this helps.
Mar 03, 2010 | Home
Flow of water thru shower head is barely a trickle
There is a chance there is mineral deposits in the showerhead openings. You can try products sucha as limeaway by unscrewing the showerhead , soaking in the limeaway for a few minutes and rinsing with water. You may have to repeat this a few times to get it clean.
Jan 20, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
We have an Ondine Hand Shower. Ondine Interbath 112.18.1M 25GPM/9.5 LPM MAX and the head is clogged and we do not get a full spray - How do I clean it? S. Seipp
Either remove it and soak it in CLR (calcium,lime, rust remover) or fill a container and tie it to shower outlet in such a way that head is emersed in the CLR. You can buy it at pretty well any hardware store, or home depot. If you don't want to try that, use vinegar, and soak it as well, I usually try to do it at end of day when shower won't be used, then let it sit in solution overnight.
Jan 03, 2010 | Ondine Brass Showerhead
Winshield wipers just stopped working
put wipers on high check voltage at motor if theres volt. at motor and its not working motor is defect,if theres no volt. check wiring circuit!
Jun 22, 2009 | 1992 Toyota Tercel
Asr and BAS lights stay on after installing new battery
You have to get the coeds cleared by a garage .
Jun 04, 2009 | 1998 Mercedes-Benz C-Class
Somehow I have no drivers for either of my cd rom drib ves and my hard dribe has no partition
Did you insall windows? If you can access the harddrive at all then it is a single partition.
Apr 20, 2008 | Computers & Internet
Moen Showhouse S112BN Waterhill 10 Rainfall Showerhead, Brushed Nickel Logo
255 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
