Question about Miller Welding Tools
Electrical troubleshooting for a 220 Miller Bobcat generator welder
5 Suggested Answers
  • 26 Answers
SOURCE: nopower
armature winds bad??? how old is unit ,maybe just brushes are bad
Posted on Jan 14, 2009
luxur4
  • 92 Answers
SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
Posted on Jan 23, 2009
mamicheddy
  • 79 Answers
SOURCE: miller bobcat 250 welder with kohler lp gas engine
Make sure that the idle is set at 40Hz. You do this by placing a frequncy meter on one of the 120Vac outlets. If frequency is low, the engine will run rough at idle. There is a 3/8 nut next to carberator that needs to be turned to the right to increase the idle speed.
Posted on May 13, 2009
RixsFixes
  • 2200 Answers
SOURCE: looking for an instruction manual for my miller 225g plus
You can get this manual from the following link http://personafile.com/Miller-Welding-Equipment-BOBCAT-225G-P9207349821373.htm
Please remember to rate my answer. Many thanks.
Posted on Jul 07, 2009
225Bobcat gen.runs but will not excite when trying to strike arc
#Tags bobcat 250 welder service manual
coop.bounceme.net/term/bobcat-250-welder-service-manual
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and ... Won't strike an arc,fuses ok brushes and slip.
Aug 11, 2015 | Electrical Supplies
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and forth to high then to low idle?
The unit may need recalibrating the idle/run setting. Instructions found in manual at 8-6 (subaru engine) and 9-5 (kohler). Idle speed around 2200rpm. Simple screw adjustment. PDF manual here :- http://www.millerwelds.com/om/o4434l_mil.pdf
Aug 02, 2014 | Bobcat Miller 225 Welder Generator 907209...
How to separate the kohler engine from the generator of a miller bobcat 250
The shaft is tapered and will have a bolt in the center, loosen the bolt enough so you can tap on the end of the bolt. This should release the shaft, if not there should be 2 hole that you can thread a bolt into to push the connection apart.
Jun 25, 2011 | Bobcat Miller 250 Welder Generator 907212...
Would like to know how much a used bobcat migwieldier costs?
Depending in the city you are in. Here in N California the average price for the Miller Bobcat 225 is 3,425.00. Try your local Praxair Distribution welding store.
If this was useful please vote.
Feb 23, 2011 | Bobcat Miller 225 Welder Generator 907209...
Bobcat 225 does not produce ac current 110 or 220?
Probably you need to act the braker, put the idle at max (pull throtle) and let it run for a minute, that will reset the braker.
Dec 03, 2010 | Bobcat Miller 225 Welder Generator 907209...
Welding Tools Logo
118 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Jose Velazquez
Jose Velazquez
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
