Question about Garden
Quantum 120000 mower self propelled
The self propel control bar mechanism fell off when hitting bushes. How can I put this together again properly with the springs, cables, etc to assemble?
  • 11 Answers
SOURCE: SELF PROPEL FAILURE ON YARD MAN MOWER
hello
check the drive cable as not come adrift or broken
you can usually adjust the tension on top of the drive cable
also check drive belt is on the two pulleys
hope this helps
Posted on Mar 15, 2009
SOURCE: Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
Posted on Aug 07, 2009
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
Posted on Aug 16, 2009
SOURCE: my troy built 210 6.75 hp mower self propelled mow...
remove the front black plastic plate that is stamped self propelled and replace the wheel drive belt that attaches the engine pulley (above blade) to the transmission pulley (found under the cover). When you buy the belts, pick up two or three as I seem to go through a couple per season. Hopes this helps
Posted on May 30, 2010
witserv
  • 144 Answers
SOURCE: ENGINE KEEP'S DIEING, PUSH PRIMER BULB AND STARS,
Carburator issue. If you have some mechanical abilty you can pull the carb off else take it to a shop. You probably left gas in it off season. Either the main jet is clogged or the float valve is stuck. Either way, remove the carb, tae off the bottom cover and clean everything out with gum out or a carb cleaner. reassemble and eveything should be fine.
Posted on Jun 14, 2010
I have an intek 55 ohv engine as fitted to my self propelled mower but there are no id numbers on the motor apart from the sticker that says intek 55
If I remember correctly they are hard to see as are under the engine cover on the metal piece over the muffler. It be 120000 series. The governor spring depends on the model and type numbers of the engine.
Feb 16, 2015 | Garden
Remove self propel gears and axle from Troy bilt push
Most of the self propelled mowers have a pin in them. you need to use a pin punch and a hammer to knock it through. The gears will come off then. Post a picture if need more info.
Sep 02, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Just bought a self propelled toro, model #120000. Used it last weekend and tried to use it again this weekend. The self propelling part isn't working. There's a bit of a grinding sound, but it...
It is possible that the scews and/or latches for the cover will be accesible UNDER the deck where the blade it. Have someone tilt it back while you check and/or hold it for you while you removes the retainers and screws. If the unit IS defective, I suggest you take it back as the Toro should be warranted.
Sep 11, 2011 | Toro Power Lawn Mower
Self propelled #860. self propell got slower and slower. now barely assists. can I adjust the belt. manuual says bring it in. too far. how do I tighten? thx, bruce
Your self propell is not adjustable. The belt runs over a spring tensioner,you either need a new belt or axle bushings. If you pull the top cover off, you can watch the belt when you engage it. With the engine off, can you move the front wheels up or down or forward or backward? If so the plastic bushings are worn out and this changes the geometry of the drive system, making the belt appear too long.
Hope this was helpfull, Matt
Dec 31, 2010 | Troy Bilt 5.5hp Self Propelled Mower
ENGINE KEEP'S DIEING, PUSH PRIMER BULB AND STARS, BUT THEN DIES, IF I CONTINUE TO PUSH PRIMER BULB IT KEEPS RUNNING, BUT STOPS AS SOON AS STOP.TROY-BILT SELF PROPELLED MOWER MODEL E189- BRIGGS&...
Jun 14, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Self-propelled doesn't work
remove plastic cover to access drive mechanism
check belt and remove debris and try again
Apr 23, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
253 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
