Question about Watches
Unable to set correct time in minutes - Watches
How to set the day of the week
here is your manual (I think)
http://cdn.invictawatch.com/invictawatch/website2014/webroot//uploads/manuals/2-8040n-pdf
If not, their site is pretty good.
http://invictawatch.com/service/view-the-instruction-manuals
nice video but as good as a chocolate teapot!
https://youtu.be/iv0aXQNH4yY
anyway, here is your info
Invicta Watch Setting Instructions By Ashley Brown eHow Contributor Found This Helpful A watch is only useful if it displays the correct time. Over time, your watch may display the incorrect time as the battery wears down. After installing a new battery, you will also need to reset the time. All Invicta watches have similar instructions for setting the time. Setting the time does not require any tools or equipment.
Other People Are Reading
Watches with Time Only
  1. Pull out the crown. The hour and minute hands will stop.
  2. Turn the crown until the hour and minute hands are positioned on the correct time.
  3. Push in the crown to start the watch.
Watches with Time and Date
  1. Pull out the crown to the first position. The crown can be pulled out to two different positions. Pull gently once to reach the first position.
  2. Turn the crown until it reaches the correct numerical date.
  3. Pull out the crown to the second position.
  4. Turn the crown until the hour and minute hands correspond to the correct time.
  5. Push in the crown twice. It should now be resting firmly against the watch, in its original position.
Watches with Time, Day and Date
  2. Turn the crown to reach the correct day.
  3. Turn the crown clockwise to reach the correct date.
  4. Pull out the crown again to the second position.
  5. Turn the crown until the hour and minute hands display the correct time.
  6. Push in the crown twice so it rests against the watch. The crown should be back in its original position.
Read more : http://www.ehow.com/how_7352591_invicta-watch-setting-instructions.html
Sep 13, 2015 | Invicta Watches
How to set the time?
Timex Digital Watch
  • Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side
  • Press the "Date Advance" button on the upper right side. This will reset the seconds.
  • Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
  • Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
  • Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
  • When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
  • Mar 13, 2011 | Timex Watches
    Set time on wr50m watch
    Hi capttimpcb,
    To set the digital time and date on your Timex, please follow the steps below.
    1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
    2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
    3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
    4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
    5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
    6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
    Hope it helps.
    Thank you for using FixYa.
    Dec 01, 2010 | Timex 1440 Nylon watch
    I am unable to change the time
    Hi kbrownigirl,
    You can easily change the time of your Timex watch by following the steps below.
    1. With the time and date showing, press the top left button.
    2. Press the right top button (this sets seconds).
    3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
    4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
    5. Press the bottom left button, month flashes. Press the top right button until correct.
    6. Press bottom left button, date flashes. Press the top right button until correct.
    7. Press bottom left button, day flashes. Press right top button until correct.
    8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
    To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
    Hope it helps.
    Nov 09, 2010 | Timex 1440 Nylon watch
    Setting the time
    Hi frenchdscent,
    Hope it helps.
    Nov 02, 2010 | Timex 1440 Nylon watch
    Setting the correct time on Seth Thomas clock.
    Correct technique definitely is CLOCKWISE ONLY. You are unbelievably lucky person if did not damage striking mechanism within 25 years while adjusting hands anti clockwise. If I'd have such a luck, I'd try to play lottery. :))
    Feb 04, 2010 | Timex Watches
    CAN YOU EASILY EXPLAIN HOW TO SET ME TIMES 1440 SPORTS WATCH. SINCE TIME CHANGED WE ARE UNABLE TO SET AND CANNOT FIND INSTRUCTIONS THANK YOU
    Hi garysuzie,
    Hope it helps.
    Nov 03, 2009 | Timex 1440 Nylon watch
    Change from miliary time
    Please follow the procedure below.
    Hope it helps.
    Oct 02, 2009 | Timex 1440 Nylon watch
    Unable to set time
    The time on this watch is set by changing the digital display time then transferring the digital time to the hands.
    1 - Turn the crown until the mode hand points to the time mode [TME].
    2 - Press either button (A) or (B) to select the city for which the time is to be set.
    3 - Pull the crown out to the second click (3) to enter time setting mode.
    4 - Pressing button (A) will change the digits to be set. These digits are the ones that are blinking. Press button (A) to select the digits that you want to change.
    When button (B) is pressed in the [SMT] daylight savings time correction mode, DST can be turned ON or OFF.
    When button (B) is pressed with the seconds digits blinking, the seconds will return to "00".
    5 - Turn the crown clockwise to advance the hours or minutes when those digits are blinking.
    Although the crown may be turned in either direction, you should always turn it clockwise to the final setting.
    6 - When the 12H/24H selection is blinking, pressing button (B) will turn it On/Off.
    7 - After correcting the time on the digital displays, push the crown in to normal position (1) to complete time setting.
    i think this may solve ur problem
    thank u.................
    Jul 29, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
    I am unable to set the correct time since putting in new battery
    Try this one(paste it in to your browser):
    http://world.casio.com/wat/download/en/manual/
    Jan 07, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    Watches Logo
    13 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
