Question about Sewing Machines
I thought I had a timing issue with the needle and hook because I could not make stitches.Turns out the hook itself isn't moving around... anything I can do?
  • Sewing Machines Master
  • 12,515 Answers
Am guessing something in the machine is broken, perhaps a gear or even a belt.
Posted on Dec 23, 2016
I have a Brother Model LX2500 It is threaded correctly and the bobbin is full. It moves as if it is stitching, but it is not stitching the material..all of the parts move as they should
Make sure your needle is facing the correct direction and all the way in. Otherwise it is the hook to needle clearance or the timing that is off. With the needle all the way up the hook should be at "2o'clock. If that is correct turn the hand wheel until the needle is all the way down then bring it up until the hook tip is right behind the needle (you will have to take the Needle plate off to see), and gently press the needle into the hook making sure you don't deflect it to the side as you push. it should be as close as possible without touching. Also take this opportunity to make sure the hook tip is passing higher than the eye of the needle.
Dec 10, 2016 | Brother Sewing Machines
Problems with the walking foot on a janome skyline s5. Worked well for awhile. Now skipped stitches, puckering, length &width off.
The U shaped clamp usually hooks "around" the needle screw. Yes, usually the walking foot may need oil (just a tiny bit) where the parts move against each other.
Dec 25, 2015 | Janome Sewing Machines
How do I adjust timing on a Singer 20u33? I have the user manual, but that is not included.
THE HOOK IS UNDERNEATH THE PLATE. YOU WILL SEE IT SPIN AROUND OR ONLY A LITTLE OVER HALFWAY AND SPIN BACK TO BEGIN A NEW TIME. THE HOOK HAS TO MEET THE TOP OF THE NEEDLE HOLE AS THE NEEDLE IS RISING. (BENEATH THE PLATE.) WATCH THIS CAREFULLY WHILE ROTATING THE HAND WHEEL TOWARDS YOU. YOU WILL SEE THE NEEDLE AND THE HOOK MEET WHERE I SAID. IF THEY DON'T MEET AT THE RIGHT TIME THE THREAD FROM THE NEEDLE WON'T BE SNAGGED. TO CORRECT THIS YOU WILL HAVE TO LOOK IN THE BOTTOM PORTION OF THE MACHINE AND STUDY THE CRANKSHAFT FOR ADJUSTMENT HEX SCREWS. THIS CRANKSHAFT GOES TO THE HOOK. LOOSEN THE SCREWS AND MOVE THE HOOK SLIGHTLY TO MOVE THE HOOK UNTIL IT HAS BEEN TIMED WITH THE NEEDLE HOLE.
May 08, 2014 | Sewing Machines
Timing a bernina
Well a simple way to check timing (it's not foolproof) is to push the needle bar fully to the right. Drop the bobbin door, take the bobbin case out and tip the machine back slightly so you can see the hook/shuttle area. Rotate the handwheel until the needle goes down through the stitch plate and just starts to come back up ... stop. Now release the hook retainer by pressing the release lever on the left of the bobbin door and open the retainer carefully, leaving the hook/shuttle in place. Watch carefully at the top of the hook, whilst you continue to rotate the handwheel towards you - you'll see the point of the hook move clockwise behind the needle. Stop when the point of the hook just emerges from behind the needle - it should be just above the eye of the needle - if not, the timing may be out (the needle might also be at the wrong depth too, so this isn't foolproof) - this is the only check you can do without special 'pinning tools' that are used to set various parts of the machine into specific positions for adjusting the timing. Shout if you need more advice.
Feb 06, 2012 | Bernina Activa 140
I am having problems with my Juki TL98E skipping stitches when I free-motion quilt. I have cleaned it well, put in a new needle but still having problems. When I stitch forward, it's ok, but when I try to...
It is a timing issue. I have a TL98E. The needle bends a bit when free motion quilting, moving the needle away from the hook, thus missing the thread. Try to put in a larger needle, or have the timing changed so that the hook "kisses" the size needle that you want to use. Tammy
Nov 18, 2010 | Juki TL-98Q
I need help in adjusting the feed dogs, they messed up when I adjusted the timing for the needle and bobbin.
When the sewing machine is properly timed, all the parts work together in a seamless flow of coordination. The needle moves from it highest point down toward the needle plate. The feed dogs reach the farthest point toward the back of the sewing machine. The feed dogs drop under the needle plate. This is just before the needle point reaches the needle plate. The needle continues to move down dragging the upper thread under the needle plate. It proceeds toward its lowest point.
The needle begins its rise back up. A loop of thread forms along the back of the needle. A special cut out on the back of the needle to accommodate this loop is called the scarf. The sewing machine hook slides behind the needle. The point of the hook slides into the thread loop and pulls the thread around the bobbin. The bobbin thread and upper thread wrap together. The needle and hook proceed through their actions under the needle plate. The feed dogs move under the needle plate from back to front.
The needle proceeds to rise again up out of the bobbin area exiting the needle plate. At the same time the feed dogs rise up out from under the needle plate. They begin to move from front to back as the needle continues to rise.
The thread from the bobbin flows through a bobbin tensioner providing resistance to the thread as it is drawn up by the upper thread knot. The upper thread is also under tension. This comes from the upper tension, thread guides, tension spring, and sewing machine take up lever.
The thread from top and bobbin grow increasingly tighter until they form a locked stitch in the middle of the fabric. This process is repeated for every stitch.
How do you adjust sewing machine timing?
The needle, hook, and feed dogs must move in harmony. If they fail to do so, the machine will not perform as expected. When the hook is just slightly out of time with the needle, you will notice skipped stitches. This may begin on only one side of the zig zag stitch or intermittently. If the timing is just a bit more out of sync, stitch formation will become impossible.
If the feed dog timing is out of sync, the fabric will not move through the machine as expected. Threads may bunch up or the fabric may just not move.
As you can see, timing is everything.
click on this link directly
http://www.fixsewingmachines.com/How-to-Adjust-Sewing-Machine-Timing.html
This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya
Jan 29, 2010 | Sewing Machines
Stitches won't catch each other.
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Aug 26, 2009 | Sewing Machines
2020 rotary hook continuous one direction pfaff tiptronic 2020
You are absolutely correct - your machine doesn't come apart much because it is an electronic machine. There really are very few moving parts in modern sewing machines - and the electronics are better left to a technician who's been specifically trained.
It sounds as if your machine is no longer in time (needle rubbing the plate as it goes around if I'm understanding correctly). While not really a "major" repair, unfortunately with computerized/electronic machines, retiming your machine is something better left to an authorized Pfaff technician.
If the needle struck metal as you were stitching/basting, there may also be a rough spot/burr on the hook that your technician will be able to smooth off as well.
Hope this helps get you back up and running soon.
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Nov 23, 2008 | PfaFF Tiptronic 2030
Zigzag stitch not right.
This is an issue entirely related to the timing of the hook to the needle.
What model is your machine, top loading or front loading bobbin ?
The correct passage of the hook behind the needle, is generally very similar for either type of bobbin...adjustment requires the ability to disengage the shaft movement tying the top (needle) and bottom (hook) so that each may move separately and the small adjustment be made.
As the needle rises from the lowest position approx 1.2mm, the tip of the hook should be at the point of beginning to pass behind the needle, to pick up the bobbin thread, when in wide zig zag and at the widest and furthest travel of the hook........there is a shallow "groove" in the back of the needle just above the eye to allow a very close pass by the hook as it whizzes around.
If the hook travels clockwise, the furthest needle position is when the ZZ is in the right stitch position, so conversely, if the motion is anti-clockwise, the left needle position is the one to set.
The method of releasing the two shafts from each other will depend on the machine model, typically there are grub screws on the bottom shaft near the drive belt, or connected to the handwheel at the top........generally 2 screws at 60 degree offset in either case.
Re-timing is not especially difficult, but does require knowledge of the screws to aim for, hence the model is necessary info.....
...If you want any more help with this, just post back here with a photo of the machine (< 150kb) , or, drop a line through the "Contact Us" page at www.bargainbox.com.au and remind me of the posting.
Jun 01, 2008 | Euro-Pro Sewing Machines
Sewing Machines Logo
24 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
