Question about Sewing Machines
Once I have the wire threaded it runs for a few inches then bunches up as it exits the wheels
  • kakima Dec 23, 2016
    Hi Lionel higdon, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model is "it"?
    Top Expert:
  • Sewing Machines Master
  • 8,204 Answers
When you goto this link just close the popup down do not sign anything on this page.
Sewing Machine Thread Bunching Up Here Why
Posted on Dec 23, 2016
Brother LS-2125 bunches bobbin thread then won't sew.
Check your stitch sample. Dollars to donuts it's the top thread bird nesting (also called thread nesting) under the fabric. Issues appearing under the fabric is usually top thread related. Problems appearing on the top of the fabric is usually bobbin thread related.
Remove the top thread from your machine.
Be sure to start with a brand new needle.
ALWAYS RAISE the presser foot and rethread the top.
Jan 13, 2018 | Brother Sewing Machines
Bunched thread...
here is a free manual for the machine, it should have the information
about the tension in it
Apr 02, 2013 | Singer 5050 Mechanical Sewing Machine
When I sew a few inches, bunches of threads come out of the bobbin case. It's like it gets clogged or something. I'm getting nowhere with this. Help!
If your bobbin is the correct one for your machine and it is wound tight, not loose and puffy, make sure the thread is going the right way when installed (over the top to the left and then placed flat in the bobbin case). Usually if the thread bunches underneath your fabric it means that the TOP thread is threaded incorrectly. Try re-threading the upper thread. Good luck!
Aug 21, 2010 | Brother LS-2125 Mechanical Sewing Machine
Older Kenmore sewing machine stops due to threads bunched
Mary, just re-thread the upper and make sure the threaded is seated between the tension disc
Aug 01, 2010 | Kenmore 11101 Mechanical Sewing Machine
Hi...i have been having trouble with my bobbin thread bunching up really bad underneath and causing the machine to seize up when i try to starts to do this just after a few stitches...i make sure...
Always remember that it is the opposite of what you think, it is your upper thread that is not threaded right, not your bobbin. Once you thread it right, you should be okay. You can buy a manual at for about $14.95
Jul 22, 2010 | Euro-Pro Sewing Machines
The bobbin thread breaks
if upper thread is breaking
1. needle in backward
2.upper tension to tight-check manual for proper setting
3.needle maybe bent-try rolling needle on flat surface to see if it's bent & if so replace
4.thread may hang on bobbin case-check area for lent or fragments of old threads
5. knotty or cheap thread-always use good quality thread
if lower thread is breaking
1.the most probable cause of lower thread breaking is an inproperly wound bobbin
2.bent bobbin
3.lint built up in case
4. thread catching on a spring or latch
Jul 21, 2010 | Necchi 3537 Mechanical Sewing Machine
Sewing a bunch of thread from the bottom, this stops the machine from actually sewing
Yes, it does. There are a couple of reasons the bobbin thread could be bunching up on the underside of the fabric. It could simply be that the machine needs cleaning. Take the bobbin assembly out, brush all the old lint out as best you can, reoil the machine once it's all clean, and make sure there aren't any little bits of thread caught in the bobbin assembly. Rethread the machine (carefully) and change the needle. This solves the problem usually--especially if the machine was sewing along fine and the problem develops suddenly. '
The other thing to check is your tension. It could be that the top tension is too loose. But different color thread in the top and in the bobbin, stitch a few inches (be sure to held the top and bobbin thread ends behind your needle as you start to stitch) and check. WIth the pressure foot down, adjust the tension, and stitch again. Keep stitching, checking, and adjusting until you see little if any bobbin thread on the top or top thread on the bobbin.
Another thing to reminder: use the appropriate thread and needle for the fabric you're sewing.
Let me know if this works, ok?
Jan 31, 2010 | Elna Sewing Machines
Sews fine at lower speed, but when you speed up, every few inches loops of thread clump up on the bottom side .
bunching lower thread is actually the upper thread not having enough tension.
Jul 19, 2009 | Sewing Machines
Janome Sew Mini bobbin problem
Hi, Usually wrap-ups in the bobbin area are caused by the lack of tension on the top thread. The slack arm ( shinny lever that moves up and down while sewing) has to pull the loop around the bobbin case and it does so only if the tension on the top thread is sufficient to keep it from pulling more thread of the spool.
Try this: Thread the top of the machine all the way just short of the needle eye. When the presser foot is up the thread should pull through easily. Now drop the presser foot (this closes the tension discs) and pull the tread while adjusting the upper tension control.
If everything is working correctly you should feel the drag on the thread change if not something is keeping the discs from closing.
Most Janomes aren't too difficult to remove the nose cover, usually just one screw and you can get a look at the thread path. Look for thread wrapped around the mechanism.
Sorry, no easy answer but I hope this helps.
Mar 16, 2017 | Janome Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
