Question about Photography
I have a small bottle of water from theJordan River. I need to find someone in the Searcy, AR...Little Rock area who can vacuum seal a pouch or two so I can preserve it.
I plan to put this is some sort of frame with photos, etc., so it absolutely cannot leak.
  • Andrew Taylor
    Andrew Taylor Dec 22, 2016
    I had a butcher vacuum pack 5 pairs of mittens to take to the UK. They took up a quarter of the space and sprang back to shape when I let the air in.
  • Photography Master
  • 20,941 Answers
Ask your butchery department at the supermarket or a catering butcher in the area. They have vacuum packing machines. However, I would put it in a miniature perfume bottle and put silicone, or acrylic sealant on the threads. Have a frame made that has depth, and mount the bottle and the pictures in a matte frame.
Posted on Dec 22, 2016
Testimonial: "Thanks!"
Why cant I find vacuum leak/
Waterboard it!
No, really. Get a spray bottle that can spray out a fine mist, and fill it with water. Start the engine and let it idle. Now wet down all suspected areas-vacuum hoses and fittings, intake manifold gaskets, pcv hose, etc.. Special attention to the intake. Wet it down good around the intake sealing area.
If you have a vacuum leak, the water will get sucked into the intake, and you will hear the engine idle change pitch, it may stumble and the idle will drop.
If no leaks found, maybe was something else. Check fuel pressure for one.
Aug 31, 2014 | 2004 Kia Sorento
Wont idle
I had an '87 Celica doing the same thing and it was an intake manifold gasket that wasn't sealing-pulling in a lot of air. A lot more than a vacuum hose leak, which would only raise the idle a bit, but not cause the surging you are having and that I had. So check for a large air or vacuum leak. A rip or hole in the large intake boot may also be the source.
To check the manifold gasket, get a spray bottle filled with water and have someone keep the engine running at around 2000 rpm or higher. Soak the area all around the intake manifold gasket, wet it down pretty good. If any leaks are there, the water will get sucked in and cause a noticeable stumble in the engine, may even try to die. Check all hoses for vacuum leaks too, the large hose to the power brake booster.
If it's not a vacuum leak, try unplugging the MAF sensor and see how the engine runs. If it settles down, clean or check the sensor.
Jul 25, 2013 | 1994 Toyota Land Cruiser
My headliner was driping wet so i removed it. I found water entering somewhere near the left rear hinge for the hatch back. water instantly starts driping from hinge bolt access holes. I resealed hinge,...
Try this: Clean all of the dirt out of your vacuum cleaner and connect the hose to the discharge side of the vacuum.
Close everything windows etc on the vehicle but leave one window open enough to put the pressure producing hose through then using wide removable masking tape seal up the rest of the window opening. Turn the vacuum on and inspect all of suspected leak areas of the vehicle.
Anyplace there is a leak you will feel air escaping.
Nov 02, 2017 | Jeep Cherokee Cars & Trucks
Water leaking through the seals on my 93 mx5, what
buy and install new seals ar try and see if window is adustablie
Sep 07, 2009 | 1993 Mazda MX-5
Dishwasher began smoking while cycling. Noticed some water in the bottom before starting the dishwasher. The little door for the soap pouch opened but the pouch stayed inside the door area. It smelled like...
hi..the reason to this problem is probably due to the
bad belt.you need to replace it with a new one.
check this out..
thank you..
kindly rate my response..
Jul 21, 2009 | GE Dishwashers
SHU43 built in dishwasher
There is no heater element in bosh D/W
Problaby, your hot water is not hot enough and I don't know nobody in your area.Your water heater in your home should be set at 120-140 degrees, read the book to make sure.
Aug 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Shu43 built in dishwasher
Running the hot water in the sink until you get the water hot then, make shore you are using jet dry. Bosh dishwasher dry with condensation. Let me know
Photography Logo
193 people viewed this question
Top Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Photography Expert? Answer questions, earn points and help others
