Question about Cell Phones
It says selection fi network i go to att6zjymvs and it says authentication problem I don't know what to do
  • 652 Answers
Buy a new phone
Posted on Dec 23, 2016
How do I change the password on the kindle for the wireless network?
To add a new Wi-Fi Network:
If you don't see the network you want to connect to in the list of detected networks, you can add it by choosing "Enter other Wi-Fi network" at the bottom of the list of detected networks.
  1. Make sure you are within range of the network you want to add, and that you know the network name and password (if required).
  2. Press the Home button, then press the Menu button.
  3. Navigate to "Settings" by moving the 5-way controller down, then press the 5-way controller to select.
  4. Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks.
  5. Use the 5-way controller to navigate down to "Enter other Wi-Fi network" and press to select.
  6. Enter the name of the Wi-Fi network that you want to add.
  7. Enter the password (if required). Press the Symbol key to enter numbers or characters not present on the Kindle keyboard. You can continue to use the keyboard while the Symbol menu is displayed.
  8. Choose "submit." Kindle connects to the new Wi-Fi network.
If your Kindle fails to connect to the new Wi-Fi network, it will display an "unable to connect" message. You can try manually entering all the network information for the Wi-Fi network by choosing "set up network" when you see the "unable to connect" message. If you don't know the network information, try connecting to a different network, or contact the network's administrator.
To forget a Wi-Fi network:
You can tell Kindle to forget the Wi-Fi network you're connected to so that your Kindle doesn't connect to it automatically in the future.
  1. While connected to the network that you want to forget, press the Home button, then press the Menu button.
  2. Navigate to "Settings" by moving the 5-way controller down, then press the 5-way controller to select.
  3. Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks. You may have to wait a moment as your Kindle detects networks in range. The Wi-Fi network you are currently connected to displays the word "forget" next to it in the list of available networks.
  4. Choose "forget" to disconnect from the network.
To connect to a Wi-Fi network:
  1. Press the Home button, then press the Menu button.
  3. Select "view" next to "Wi-Fi Settings" to display a list of detected Wi-Fi networks. You may have to wait a moment as your Kindle detects networks in range. Kindle automatically scans for available Wi-Fi networks at periodic intervals. To rescan for available networks at any time, select "rescan."
  4. Select "connect" to connect to a network. If you see a lock symbol next to "connect," the network requires a password to connect.
  5. If necessary, enter the Wi-Fi network password, and choose "submit." Press the Symbol key to enter numbers or characters not present on the Kindle keyboard.
Once you are connected to a Wi-Fi network, Kindle automatically connects to it again whenever that network is in range. If more than one previously used network is in range, your Kindle automatically connects to the network that was most recently used.
Tip: Once your Kindle connects to a Wi-Fi network, that network displays "forget" next to it in the list of available networks. Selecting "forget" disconnects your Kindle from that Wi-Fi network and also prevents Kindle from automatically connecting to it in the future.
Mar 07, 2016 | Tablets & eReaders
I cannot connect. I keep getting a message "authentication Failed"
Do you connect your PC to router in an administrator role using web browser? Or do you connect some device to Wi-Fi network?
  1. Administrator role: You need to have correct login name and password for admin access. Search in manual or ask Google for default login name and password of your router type. If non-default password is set in the router then you must reset router setting and erase its settings to default (factory) status. You will lose all router configuration but default password is back.
  2. Wi-Fi client role: There are more possibilities why authentication fails in wireless communication. Mentioned error message describes what kind of problem occurred.
    (a) A password you put to client device does not match the wireless network password which is set in router. Your computer, tablet or smartphone WI-Fi interface must have exactly same password as WI-Fi network which is transmitted from router. Check and compare passwords on both sides, in client device and in router.
    (b) Client Wi-Fi interface security (encryption) mode differs from Wi-Fi network encryption used in router. But the same mode must be set on both sides (client and router) for successful connection.
Encryption modes are
  • WPA2 Enterpise
  • WPA2 PSK ("home")
  • WPA Enterprise
  • WPA PSK
  • WEP
  • No encryption (open)
Higher position - better security. Enterprise Wi-Fi modes require security devices like authentication servers, certification authorities etc. They are not used in home networks usually.
Jan 21, 2016 | Computers & Internet
Authentication. problem
Is this your home network or are you trying to connect at a hot spot? Can you see that wi-fi is available? It may be as simple as needing a password to connect. I need more info.
May 28, 2014 | Computers & Internet
I have to enter my password several times to get my kindle to log on. I always have to log on..the signal seems to be weak adjacent to the router. authentication failed is a normal response on my kindle....
your kindle device should be able to connect the network automatically , if this is not happening try adding the network manually.
1.First, make sure you are within range of the network you want to add, and that you know the network name and password (if required).
2.From the Home screen, tap Menu and select Settings.
3.Select Wi-Fi Networks to display a list of detected Wi-Fi networks.
4.Tap Join to enter network details.
5.Use the onscreen keyboard to enter the name of the Wi-Fi network that you want to add.
6.Once the Network Name has been entered, tap the Password box and enter Wi-Fi password / Network Key using the onscreen keyboard (if required).
Tip: Tap the 123 key to enter numbers or symbols. Tap the ABC key to return to the regular keyboard. Tap the Shift key (up arrow) to enter uppercase characters. Your password may include non-English letters (accents, umlauts etc.). To view accent options, press and hold a letter down, and accent options appear.
7.Tap Connect
Does all your wireless devices have weak signal issues?If so , Then problem may be with the wireless router.Try changing the wireless channel on the router by logging into the router interface page.
Authentication failed is the message u ll normally get when u enter the password incorrectly.
Aug 07, 2013 | Belkin (F5D7230-4) Router (587009)
I have the GT 15510M samsung phone, howdo i connect to the internet from my wireless at home?
Your mobile has a built it Wireless Fidelity or WI-FI module enabling to catch ata over wireless networks.
By turning ON your wi-fi, it will search wireless network along the nearest location of yours. Once you found a network(s), just open it and wait until established and connected,but some authenticating connection never allows you to connect because it needs a password encryption.so you won't able to patch the network if you do not know the code.
If you have a broadband installed at home, you need a wireless router that can supply internet connection using your mobile phone via wi-fi,just easily series the broadband connection thru a wireless router and also add encryption like WEP key to ensure you are the only one catching the connection.
please state your broadband if any so that i can guide you the procedure in installing your wireless router connection.
If you have some questions, don't hesitate to reply cause i will glad accomodate any comments.
Thank you for visiting FixYa..
Jul 03, 2011 | Samsung Star GT-S5233 Cell Phone
Connection to the internet blacberry 9780
1. On the Home screen, click the connections area at the top of the screen, or click the Manage Connections icon.
2. Click Set Up Wi-Fi.
3. If you want to connect to a public hotspot or to a Wi-Fi® network that does not require authentication, select the Show Open networks only check box.
4. Click the Wi-Fi network that you want to connect to.
5. If the Wi-Fi network requires authentication, type a password for the network.
Feb 09, 2011 | Cell Phones
I can't get my netbook to hook up to my wifi. Can you help? When I get to the window about authentication I don.t know what to put.
it thepends in your router or wi fi settings.. If you are using your personal router make your setting WEP. you can also do the settings manualy if nothing else works. go to my internet connections- right click-select advance and tipe the info. close-shot down and re start your pc....you will have access to your wi fi automatically........
Sep 23, 2010 | Sylvania G-Netbook
Dell axim x51 will connect to to wifi hotspot i need detailed instructions to get it to work
Hi, follow the steps found in your owners manual. That can be downloaded at this link.
http://support.dell.com/support/edocs/systems/aximx51/en/om/om_en.pdf
Using Wi-Fi (802.11b)
Wi-Fi provides your device access to WLAN (Wireless Local Area Network.)
Short for wireless fidelity, Wi-Fi refers to any type of 802.11 network,
whether 802.11b, 802.11a, or dual-band. Wi-Fi certified products from
different manufacturers are interoperable.
NOTE: Mid and High configurations of the Axim have Wi-Fi 802.11b built in and the
drivers factory installed. For a Low configuration device, you must purchase the
802.11b SD card, insert it in your device, and load the drivers.
NOTE: The default Wireless Networking Client utility for your device is the
Dell WLAN utility. The following configuration steps are for the Dell WLAN utility.
Configure wireless networking for your device in one of the following
scenarios:
• Network Card is set up
• Wireless Network is broadcasting SSID
• Wireless Network is not broadcasting SSID
If the Network Card is Set Up
Normally the internal wireless card is already set up. There are times when
you must choose the network card. On the Axim X51/X51v configurations
that have built-in wireless, the network card is associated with the enabled
wireless. If wireless is not enabled or you are using a socket card for
wireless connection, then choose the network card:
1 Tap Start → Settings → Connections.
2 Tap Network Cards.
3 Choose either Internet or Work from the menu.
4 Choose the network card to connect to the network. For the
Axim X51/X51v with built-in wireless, choose Dell Axim X51/X51v
WLAN Wireless Adapter.
5 Choose whether the network card assigns an IP address or receives an
IP address automatically.
6 Enter the Server IP addresses if required and tap OK.
If the Wireless Network is Broadcasting SSID
1 Press the wireless button to enable wireless capability. The green LED
in the right top corner of the device indicates that the wireless
is functional.
2 Tap Start → Settings → Connections.
3 To add, edit, or delete a profile, select the corresponding action and
tap Network Cards.
4 In the Configure Wireless Networks window, select one of the available
network names and tap OK.
If the Wireless Network is Not Broadcasting SSID
The Configure Wireless Networks window only shows wireless networks
that broadcast a Network Name (SSID) and those that have been added.
Add the network if it is not listed. Contact your network administrator for
the following information:
• SSID (network name)
• Authentication
• Data Encryption
• Keys (if the key is not provided automatically)
• Log in if necessary
To configure the wireless network:
1 From the Configure Wireless Networks window, tap Add New.
2 Provide the Network Name (SSID).
3 Select either Internet or Work in the Connects To box.
• Selecting Internet allows you to connect to your network but you
will have to manually start a VPN connection, if needed.
• Selecting Work automatically starts a VPN connection any time
you connect to the network.
• If you are having trouble connecting to your network, change the
Connects To box to Internet.
4 Tap the Network Key tab.
5 Enter the Authentication and Data Encryption information. If a key is
required, enter the network key.
6 Select the 802.1x tab.
7 The Authentication and Data Encryption chosen on the previous
screen determines whether this screen is available. If available choose
the EAP type used on the network.
8 Tap OK.
9 If more than one network is listed, tap and hold the stylus on the
network name you want to connect to. A pop-up menu appears.
Tap Connect. After a few seconds you should see Connected next to
the wireless network you selected.
Thank you,
lee
Mar 09, 2010 | Computers & Internet
I can't connect to my wi-fi settings
Activate and connect to a WLAN
1.In range of WLAN network, access an application or menu that needs a wireless connection.
2.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
3.Press <Menu> → Turn On Wi-Fi.
The device will display available WLAN connections.
4.Select a network profile from the list.
The device will attempt to connect to the WLAN.
5.Select a network type and press <Next>.
6.Enter a pre-shared key for WLAN and press <Next> or <Finish>.
7.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type and press <Finish> (if necessary).
Create a new WLAN
1.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
2.Select New...
3.Enter a network name, configure connection settings, and press <Next>.
4.Enter network authentication settings and press <Next>.
5.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type (if necessary).
6.When you are finished, press <Finish>.
Jan 08, 2010 | Samsung Omnia Pro B7320 Smartphone
LG Incite: Connect to a multiple-user WiFi network
To enable or disable Wi-Fi
  1. Choose Start, choose Settings, choose the Connections tab, and then choose Wireless Manager.
  2. Choose the Wi-Fi button. If it is turned off, the button will appear as a lighter color and display an icon marked with an "X".
  3. Choose Done.
clear.gif To set up a Wi-Fi connection
  2. Scroll to Wi-Fi and press ENTER. The device will detect available Wi-Fi networks.
  3. Select the network you want to connect to, and then choose OK.
  4. Select Internet or Work, and then choose Connect.
    If you select a secure network, you may have to enter a network key that is provided by the network administrator.
clear.gif To edit a Wi-Fi connection
  2. Choose Menu, and then choose Wi-Fi Settings.
  3. Scroll to the connection that you want to edit, choose Menu, and then choose Edit.
  4. Make changes as needed, and then choose Finish.
clear.gif To delete a Wi-Fi connection
  3. Scroll to the connection that you want to delete, choose Menu, and then choose Remove Settings.
clear.gif To change Wi-Fi settings
  2. Choose Menu, choose Wi-Fi Settings, and then choose the Wireless tab.
  3. Scroll to the connection that has the settings that you want to change, choose Menu, and then choose Edit.
  4. Change any of the following information:
    • In Network name, enter a name for the connection.
    • In Connects to, select The Internet or Work.
    • If the network is a hidden network, which means that it does not broadcast its Service Set Identifier (SSID), select This is a hidden network.
    • If you want to connect directly to another device or computer, and not to a network through an access point, select This is a device to device (ad-hoc) connection.
  5. Choose Next.
  6. On the Configure Network Authentication screen, do the following:
    • Select the authentication and data encryption methods.
    • Enter the network key information or select the The key is automatically provided check box.
      If it is necessary, ask the network administrator for authentication, encryption, and network key information.
  7. Choose Next.
  8. Select or clear the Use IEEE 802.1X network access control check box.
  9. To use Extensible Authentication Protocol (EAP) or smart card authentication, make the selections appropriate to your choice of authentication.
  10. Choose Finish.
Aug 05, 2009 | LG Incite Cell Phone
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
