Question about Tablets & eReaders
Just received memo pad 7lte it's an as us memo pad i don't know the first thing how to work it can you help or do I send them back
My asus memo pad 7 wont send, receive or pair with devices through Bluetooth
hai there, as i analyze, you have to pair manually to other device, cannot straight send file to the others by bluetooth.
before send file and other thing, first make sure some one or other device you want to send have to be recognized by your device by pairing manually.
you have to go to bluetooth setting, for pairing manually you can choose by search or by listening device, don't forget the other device must do the same. after your device completed pairing to the others you can transfer all files you want.
cheers. hope its helps
Nov 07, 2015 | ASUS 8GB ME170C MeMO Pad 7" Wi-Fi Tablet...
I have bought a new asus memo 7 and i cannot connect it my wifi, it keeps saying authenticating problem
The issue isn't with the tablet, it is something in your Wifi...there are a number of things that it could be, try simply rebooting your router, that would be the easiest thing to try. If that doesn't work, try switching your tablet to "airplane mode" , and then try to connect...
Oct 08, 2014 | ASUS 16GB MeMO Pad 7" Tablet Cherry Pink
The touch pad on my 10.1 inch asus memo pad doesn't work
Hoe long have you had this tablet? The fix may not be one that can be repaired without opening the case. But I would try a factory reset first.
With this problem, you will need to contact Asus.
Sep 17, 2014 | ASUS MeMo Pad Smart 10
Froze whilst playing a game nothing is working
you should go to your tablet setting and check it there.
if you can not find it i suggest you to change your setting to default.
Apr 05, 2014 | ASUS MeMO Pad HD 7
Tablet will not charge or come on.
I did this with my Asus memo pad 7 HD and it worked.
The difference is only in removing the back cover. Use your nails to pop the cover to prevent damage. Do not use knife. Unplug the battery for 15 minutes than plug back in and pop the rear cover back on. After plugging the charger you should have the battery symbol on the screen. Then leave on the charger until fully charged.
Apr 01, 2014 | ASUS MeMO Pad HD 7
Cant download itv player
go to download itvpplayer to android and then instal it in you memo pad and ready vote please
Jan 20, 2014 | ASUS MeMO Pad HD 7
Trying to factory restore a asus memo pad
It not power on or it have a paswoard problem ? if is paswoard remove it with yoo pc and this program mobogenie instal it in you pc then conect and instal you memo pad in the pc then go to folders ask the paawoard archive edit it and ready clear all paswoard in to you memo pad vote please
Dec 07, 2013 | ASUS MeMO Pad HD 7
Will not turn on
check the voly out in you vcd adapter if this exist go to open you pad and rebulding soldering the conector volt in and then ready you pad work again please vote
Dec 03, 2013 | ASUS MeMO Pad HD 7
My asus memo hd 7 will not take a charge or turn on whatsoever..How can I fix this..?
first open your pad check the conector to volt in 4.5v maybe need a rebulding soldering do it then close your pad and work agan vote please
Nov 04, 2013 | ASUS MeMO Pad HD 7
Tablets & eReaders Logo
20 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
