Question about RCA Televison & Video
My RCA HTS 2000 DVD/CD player won't read the discs... says "no disc" Whether I put in CDs or a DVD it won't read the disc. Just says "no disc".
    Top Expert:
  • RCA Master
  • 80,339 Answers
The player is defective, this is the common symptom.
Posted on Dec 22, 2016
Cds wont play in dvd-rw player
The only discs that a DVD player is guaranteed to read are DVD discs. Support for CD-ROM, CD-R, and CD-RW may be included, but is by no means guaranteed.
CD-R was designed to be read by an infrared 780nm laser. DVD uses a visible red 635nm or 650nm laser, which aren't reflected sufficiently by the organic dye polymers used in CD-R media. As a result, many DVD players can't read CD-R media. Some DVD players come with two lasers so that they can read CD-R.
But as I have already stated that Most DVDs today have the tendency of playing CDs. So if your DVD player is new then it must have that support. Have a look at the quality of your CDs also.
Oct 31, 2012 | HP Compaq Presario CQ60-249US Notebook
What video formats will RCA DRC279 DVD Player read
Hello
This player is compactable with DVDs, ACDs, Video CDS, CDs and JPEG files. You can't play the following type of discs. Laser discs, CD-1, CD-ROM, DVD-ROM, or discs recorded using other boradcast standards (ie PAL or SECAM); CDG discs.
If you want the user manual to this player, inform me by fixya comment, along with your email address. I'll send a copy of the user manual to you by return mail. It has all details. I can't send it to you by this window, as it does not allow ma to upload PDF files by it.
http://www.dataentryjobs.us/67948.html
Feb 27, 2012 | RCA DRC279 DVD Player
Bush portable DVD player will not load my disc
Hello
Just put in an audio CD disc or an MP3 disc, and see whether it reads them or not. If the player can read these discs, and only refuses to read DVD discs, make sure that the laser pickup unit of it is faulty, and should be replaced with same type and number. If none of them reads, there are two possibilities, the first one is of laser pickup disc itself and the second one is the strip wire [a flat flexible cable connected between laser pickup unit and the mainboard of the player] is faulty. First replace the strip wire. If it helps you, it's OK. If not replace the laser pickup unit also. The strip wire can be bought from most of the electronic spare part shops at your town. When buying laser pickup unit, its number must be noted, and exact replacement should be done. Otherwise, it won't match with the main board. OK.
Nov 08, 2011 | Televison & Video
Daewoo unigt plays CDs okay but when I try a DVD the message is "disc loading" followed by "no disc found"
This is the classic sign of a laser in the process of failing.
It takes less power to read a CD than it does a DVD but their will come a point where it won't read CDs either.
Unfortunately due to the cost of a replacement laser it is not cost effective to repair these units.
Aug 11, 2011 | Daewoo DV-6T955B DVD Player/VCR
Says no disc when i put in a dvd. dvd is new and clean, still won't work.
Hello
Put a video CD and see whether it reads and plays. If it also does not plays, or if video CD only plays and not DVD; in both cases; the Laser Pickup Unit is faulty and should be replaced with same type and number. OK.
Jun 10, 2011 | Coby TF-DVD7107 Portable DVD Player
When i put a dvd in my hitachi htdk185uk it says unknown disc what does this mean
Either a DVD with the wrong region code has been loaded, and your player doesn't recognise it, or you have inserted a disc which is either rewritable (or an incompatible format for your player), a blank DVD or CD, or the disc has not been finalised in a DVD recorder. It depends on the disc(s) you have, whether they are region coded or those using a compatible playback format (finalised DVD-Rs are the best as far as burned copies go).
Examples of incompatible formats for your player may include;
DVD-ROMs
DVD-RAMs (which are the wrong version/speed for your unit)
Mini-DVDs/CDs
CD-RWs
DVDs with a different region code to your player or rewritable discs
* When using shop-bought DVDs, including those purchased online, make sure their region code matches your player.
May 25, 2011 | Hitachi DV-P315U DVD Player
When I want to copy a CD must I only record on a CD blank disc; i.e. not a DVD
It depends upon what type of data you want to copy onto a CD or DVD.
If you want to copy and play music in a CD player then it needs to be on a CD disc.
If you want to copy and play movie DVDs in a DVD player then it needs to be on a DVD disc.
If you want to backup data files then it can be on either CD or DVD discs (depending upon the amount of data to be stored on the disc - CD holds 700 Mb, single layer DVD holds 4.7 Gb, and dual layer DVD holds 8.5 Gb of data).
A DVD player can read both CDs and DVDs, but a CD player cannot read DVD discs.
Dec 30, 2009 | Dell Insprion 4F778 (4F779) DVD Drive
Tray B of my RCA CD Burner does not recognize any CDs
Are you using the correct disc type??
The manual states that only discs that are labeled:
"Compact Digital Audio Disc Recordable" (Audio CDR)
*or*
"Compact Digital Audio Disc Rewritable" (Audio CD-RW) can be used.
The popular discs labeled "Compact Recordable" and Compact Disc "Rewritable" are for use in computers, and can NOT be used on the recorder.
Page 16 of the manual shows the graphic of the logos detailed above. The manual can be downloaded for free below:
http://www.retrevo.com/support/RCA-CDRW121-CD-Players-manual/id/19240bh946/t/2/
Feb 23, 2009 | RCA CDRW120 2-Disc CD Recorder
No disc
The optical lens is out of alignment. This is why it will read CDs which have much larger data pits that DVDs.
The unit should be able to read and playback CDs (both production and burned) and DVDs (both production and burned). If the optics are out of alignment and exceed their tolerances, the player will not read discs.
This is caused fromt he player being dropped or jarred.
This is not an easy fix for the home user. This is something that a qualified professional needs to correct.
Jan 10, 2008 | Insignia IS-PDVD10 Portable DVD Player
Panasonic cq-dvr909u
according to the manual it does not support cd-r, lemme copy this section right out of the book
The following discs cannot be played back on this product.
DVD-ROM - DVD-R/DVD-RAM - CD-ROM - VSD - CDV - CD-G - SACD - photo CD - CD-R* - some DTS CD discs - CD-EXTRA (audio-only playback possible) - DVDs with a region number other than "1" or "ALL" - discs recorded in PAL format, others.
(* Because this product has its own reading device, CD-R discs can not be played back.)
If i remember correctly somethin about a dual laser in it or somethin, I feel your pain wish it could but it does come with rca aux input that you can do headphone -> rca jack so you can hookup a mp3 player or laptop or whatever
Sep 07, 2007 | Panasonic CQ-DVR909U Car DVD Player
Televison & Video Logo
29 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
