When i turn it on i get nothing is there a fuse inside the box ?
  • kakima Dec 22, 2016
    Hi gilbert george, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What is "it"?
  • gilbert george
    gilbert george Dec 22, 2016
    cavs dvd-101g
  • Televison & ... Master
  • 14,873 Answers
There may be one inside as part of the power supply unit.
http://www.karaokecenter.com/dvd-101g_ii.html
Posted on Dec 22, 2016
How do I check for a short when battery cable is connected
The clicking noise from fuse box is probably a relay! Nothing happening could mean anything! Without turning the ignition can you turn on headlights, does the inside light come on when you open the door, horn work?
Nov 02, 2014 | 2005 Pontiac Grand Prix
Ok i don't know about much about cars but i know
sounds like the signal switch relay fuse. turn your signal on and check your fuse boxes... inside the car and under the hood. it will look like a little square box inside your fuse box next to your other fuses. with your signal on, you should be able to locate the relay because it will be making a clicking noise. pull it straight out and go get another one. hope this helps.
Nov 03, 2012 | Cars & Trucks
Turned on heater switch and nothing happened
A good place to start would be to check the fuse or relay. Most fuse box/ relay centers have diagrams inside the covers that indicate which fuse or relay is used for that purpose. The easiest way to check this without the use of test equipment is to substitute the suspect fuse with one of the same amp rating from another part of the fuse box or a relay with the same part number. If this is not the problem then, the control head itself could be bad or a problem that will require more advanced testing procedures. Most common locations for fuse box/relay centers are : Under the hood, glove box, passenger side kick panel or inside the trunk. Keep me updated on your progress if you are interested in further assistance. Thank you for using fixya.com
Oct 29, 2012 | 2007 Hummer H3
Wiper fuse location 2002 Ford explorer
There is a relay in the battery junction box K140 and a 30 amp fuse F2.8 in the central fuse box inside the vehicle.
Feb 16, 2011 | 2002 Ford Explorer
2005 chevy colorado...2 lighter receptacles in the cab & neither one working. nothing marked on fuse block diagram for the lighter. any ideas? Just bought the tuck & no owners manual. Thanks
GET A GOOD FUSE TESTER, TEST EVERY FUSE, FUSE BOX UNDER THE HOOD & FUSE BOX INSIDE THE VEHICLE. TURN ON IGNITION SWITCH FOR THE FUSE TEST.
Jan 25, 2011 | 2005 Chevrolet Colorado
2006 Dodge Ram 2500 diesel truck----need inside fuse box diagram
If you are looking for the fuse box diagrams or any other diagrams for your Ram, check promanuals.net for a factory service manual for around 20 bucks or so. It's an invaluable tool for my Ram 2500.
Sep 19, 2009 | 2001 Dodge Ram 2500 Truck
MY TURN SIGNAL QUIT WORKING IS THERE A FLASHER
My service manual states that the '02 T+C has a combination turn signal/hazard flasher/daytime running lights module which is located on the junction block, adjacent to and left of the steering column. To access it, you must remove the steering column lower cover and knee pad panel. There is also a fuse for turn signal/hazard flasher. If none of them work, check the fuse 1st.
Jul 18, 2009 | 2003 Chrysler Town & Country
LEFT TRAILER TURN SIGNAL DOES NOT WORK
I have seen once before that the fuse box was bad on a 2003 Dodge 3500. I had power in and nothing out. We had to replace the box. Not cheap! Hope it is simple like a loose connection though. I think I had to pull the inner fender on the drivers side to access the bottom of the fuse box. Pain in the ****, but...
Feb 25, 2009 | 2004 Dodge Ram 2500
Won't start. Battery has full charge and fuses good
You have a switch onthe side of your trans..that lets your ecm know when you are in P or N., Or possible starter.
Jan 01, 2009 | 2001 Chevrolet Silverado 1500
It just seemed to turn off
yes,unplug the unit ,remove the outer case ,follow the plug inside to the fuse ,read the amperage ,test the fuse with an ohm meter should read shot or 0 ohms if not replace whit same type and amperage,
Dec 01, 2007 | Emerson MW8168B Microwave Oven
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
