How to fix H5 error code in gree inverter unit
SOURCE: code H5-01 indicated from the screen
H5-01 Exit sensor problem try to reset with simulation mode Press "Program" Press "Interrrupt: Press "Clear" Press "Interrupt" enter 1 & 4 then Press "Start"
Posted on Jul 12, 2008
  • 990 Answers
SOURCE: error code h5-01
Hello sir; the paper exit sensor get stock, just put back in the track let it moved free.
Posted on Apr 14, 2009
  • 62 Answers
SOURCE: sharp ar-m350u error code h5-01. How do I fix
vheck this link out http://www.fixya.com/support/t1570580-remove_h5_01_error_code_sharp_arm550n
Posted on Apr 15, 2009
  • 87 Answers
SOURCE: error code H5-01
HI.H5-01
it shows there is some problem in exit sensor .it is in fuser unit.may be its lever is broken .
sensor is dirty clean it
check lever home position and its movemment
check its cable
reset this code
press ,p,*,clear,*
screen will go dead press 14 ,start code will bi reset
never forget to rate the solution.MIAN AKHLAQ
Posted on May 09, 2009
  • 22 Answers
SOURCE: error code H5-01 sharp MX2300N
pascale_algu
Its a cause by continuous misfeeding. You better find the cause of that problem.
to cancel the code press program key(P), asterisks, clear key, program key . when the stand by for simulation code appears type 14 to cancel the trouble code.
Good Luck
Posted on Aug 13, 2009
How to fix H5 error
Ipm is inverter protect. Replace PCB (printed circut board)
Oct 12, 2016 | Gree 18000 Btu 20 Seer Ductless Mini Split...
How do i fix sharp copy machine AR5520N with error code H5?
H5 error is protection against big damage of the fuser caused by multiple paper jams in the fuser area. First clean and check paper way, check sensor operation and then reset the error. Reset with key operation # - INTERRUPT - CLEAR - INTERRUPT - 1 - 4 - START
Aug 14, 2016 | Sharp AR-5520N
AlvinInside unit fan works; outside unit does not come on. Inside unit showed H5 code once. How do I proceed?
H is most likely for heat pump, meaning error 5 on outdoor unit. My guess would be low pressure since your power to the indoor unit most likely comes from the outdoor unit. Check manual for codes or research model number error codes.
Jun 03, 2016 | Fedders Heating & Cooling
WHAT IS ERROR CODE H5 FOR A FRIGIDAIRE HEAT/COOL WINDOW UNIT?
Thank you for your inquiry, Angela Babin!
From my understanding your Frigidaire air conditioner is displaying an error code "H5". Normally, the error code "H5" stands for heater thermistor error. I would recommend performing a reset on your air conditioner by unplugging it for ten minutes. If that does not help correct the error code it could be a possible problem with your thermistor or control board. I hope this is helpfully. -Matt
Nov 02, 2014 | Frigidaire Heating & Cooling
Error code H5-01 and the coppier doesn't start
H5-1 means, the copier jammed more than 2 times at the fuser unit. Check the unit if any the fingers are ok, check if the fuser gear is ok. Inspect if fuser rollers condition. Once you figuer out the problem, you need to reset the error code. The procedure of resetting error codes depends on the model.
Dec 06, 2013 | Sharp Office Equipment & Supplies
Machine reads h5 01
The error code H5-01 is a error code for the fixing unit is not at the correct temp. You can try to rest it in service mode with mode 16....If that will not clear the code you have a problem with the thermistor or thermal fuse or the heater lamp.... Good Luck
Jun 08, 2012 | Sharp AR-M207E Black and White Copier
Sharp MX 3100n showing code H5-01 , what is it,how do I fix
when your copier paper jam in fuser unit area. than show H5-01 error code.
if you fix it self,open right door and relese the jam paper carefully.
Feb 19, 2010 | Sharp MX-3501N All-In-One Printer
H5 flashing on the display, anyone tell me what the error is please? It's a Sharp AR-161 copier
H5 doesn't show up on the service code manual. However, all error codes beginning with 'H' are related to the fuser, this is the heating portion of the machine. Be careful if it still prints despite the error code, you may damage the unit. It should be looked at by a service rep.
Jan 12, 2010 | Sharp AR-161 Laser Printer
Gree air conditioning unit turns itself off and has an error code of HI dont know what the error codes are
i had this problem it was freezing up outside it was only a short pipe run so it was over gassed i took some out and it was fine
Dec 24, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Code H5-01 indicated from the screen
Jul 12, 2008 | Sharp AR-407 Copier
654 people viewed this question
k24674
jasbo
jasbo
