Question about Sanyo DP26640 LCD TV
How do I unlock my Sanyo DP26640?
I am trying to install software and it says that it's locked.
3 Suggested Answers
gopakumarg43
  • 74106 Answers
SOURCE: What is the code for a Sanyo DP26640 26" LCD TV
Hello
Remote code for Sanyo TV with Comcast Custom DVR-3 device universal remote control is
0154
1. Turn on a device (e.g., VCR or DVD
Player) and, if applicable, insert
media, (e.g., video cassette or disc).
NOTE: Please read steps 2 to 6 completely
before proceeding. Highlight or write
down the codes and device you wish to
program before moving on to step 2.
2. On the remote control, press a
device key once (i.e., AUX or TV).
NOTE: Use the AUX key to program
control of an Audio Amplifier or
Receiver, a DVD Player, a Home-
Theater-In-A-Box Device, a PVR (or
DVR), or a VCR.
3. Press and hold Setup until the
selected mode key blinks twice,
then release Setup.
4. Locate the code for your device in
Manufacturer's Codes on the back
of this user guide. Brands are listed
in alphabetical order with the
most popular codes listed first.
5. Enter the first four-digit code for
your device. If you perform this
procedure correctly, the selected
mode key will blink twice.
NOTE: If you enter an invalid code, the
selected mode key will display one long
blink and exit the programming mode.
Repeat steps 2 to 5 with a valid code.
6. Aim the remote control at your
device and press Power once. The
device should turn off. If it does
not respond, repeat steps 2 to 6,
trying each code listed for your
brand until you find one that
works. If it still does not work, try
Searching For Your Code.
NOTE: If the device does not have a
Power key, press the (Play) key
Posted on Apr 30, 2011
ka4iup
  • 3957 Answers
SOURCE: whee is the analog audio output for sanyo dp26640
After reviewing the manual ( http://www.manualslib.com/manual/306783/Sanyo-Dp26640.html#manual - page 6), it does not appear that this television has an analog output. A fix to this problem would be to purchase a digital to analog audio converter (just Google this) and some inexpensive solutions are available.
Good luck,
Posted on Feb 04, 2015
Sanyo DP26640 LCD TV won't power up. Is there a fuse somewhere inside?
Every TV will have an AC fuse inside. This fuse can be located at its main power regulator [SMPS] board. This is a protection fuse; and if it is found burned [open], there should be sufficient reason for it. some kind of short circuit, or over voltage etc: Replacing this fuse without make sure, about the cause to burn the fuse; the newly inserted fuse too will fail, and more damage to set can occur. So, it is better to contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 22, 2016 | Sanyo DP26640 LCD TV
I Need A Remote for a sanyo dp26640 tv.
First place is to google the correct model number for the remote that pairs with that tv.then see if you can source this via EBay.
most remotes range £15 to £25. Sometimes you can programme a universal remote but this is hit and miss.
Dec 08, 2015 | Sanyo Televison & Video
The sound went out on my Sanyo DP26640 24 tv! What's wrong?
Hi Lisa,
Failed speakers is one of the most common reason for no sound in this kind of TV sets. Please have them checked.
Aug 16, 2015 | Sanyo Televison & Video
I have a sanyo dp26640 when on green led lights up but screen will not is it worth the fix or not if so what do I need
Indicates that the main board is not working properly. Contact any service technician. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jun 16, 2015 | Sanyo Televison & Video
Whee is the analog audio output for sanyo dp26640
Good luck,
Feb 04, 2015 | Sanyo DP26640ARB - 26 LCD HD TV 720p...
I have a Sanyo TV Model # DP26640. I have a Magnavox DVD Player model # DV2100. i am unable to play discs I make on my computer on the TV HELP!
If you can play original CDs then the problem is in neither the TV nor the DVD player , but in your DVD authoring software or your skills to use it (no offense meant).
Overall I seriously doubt the TV make and model is relevant here.
Depending on what exactly are you burning and how are you burning it the DVD player may be important as it may have certain limitations, e.g. codec formats supported or media types supported (e.g. DVD-R vs DVD+R etc.)
Feb 17, 2013 | Sanyo DP26640 LCD TV
My Sanyo DP26640 will not come on
Look for any loose contacts in power outlet.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 05, 2012 | Sanyo DP26649 26 in. TV
Where can you buy a fuse for the sanyo DP26640?
What rating is the fuse? It should be printed next to the fuse or fuse holder. We will need this get help you get the right one.
Jun 09, 2012 | Sanyo DP26640ARB - 26 LCD HD TV 720p...
I need the code for a sanyo dp26640
Not sure if this is a DVD/DP player but here are some codes to try:Sanyo 20670, 20675, 20695, 20873, 21334
Apr 05, 2012 | Televison & Video
How do I Delet A Locked Photo in a Sanyo VPC-T700
try connecting it to your computer so you can view each photo like viewing files then download Unlocker, small program that unlocks files
Download Link: http://ccollomb.free.fr/unlocker/unlocker1.8.7.exe
install it
right click on the photo and it will say unlocker try that works for me on anything
Regards
Jan 12, 2009 | Sanyo Xacti VPC-T700 Digital Camera
Sanyo DP26640 LCD TV Logo
32 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
