Question about Westinghouse Refrigerators
MY WESTINGHOUSE BAR FRIDGE (RA 123T) WONT COOL. HAD BEEN TURNED OFF FOR A YEAR....
  • Westinghouse Master
  • 20,966 Answers
It probably needs gas, so you need a service engineer. Could also be a seized compressor I guess.
Posted on Dec 22, 2016
Testimonial: "thanks andrew, appreciate your time"
I have a westinghouse 2 door fridge that is not getting cold enough, 7 degrees in the fridge, freezer seems ok. not sure where to set the controls as i have no manual. its a 2 door,freeze at the top and...
i think your ref working normal try to adjust thermostat setting on the fridge if you want to cool lower than 7 degrees but this temp. allready can chill the food. then you said that freezer ok.
Feb 12, 2011 | Westinghouse Refrigerators
Westinghouse model RS663T - not cooling fridge or
IT IS THE DEFROST THERMO STAT REMOVE REAR COVER AND MELT ICE IT IS ROUND SILVER PART
Jan 31, 2010 | Refrigerators
42" westinghouse flat screen wont turn on
Some surge protectors fail just when most needed.
Jun 19, 2017 | Westinghouse TX-52F480S 52 in. LCD TV
Westinghouse fridge: no cool air circulating inside
Art, I need to get a little more information from you. Does the condenser fan under the refrigerator seem to work and blowing warm air from below and or behind the refrigerator? The motor feeling warm is OK. Only when too hot to touch on top. Needs to cycle also. When you opened the freezer did you hear the fan blowing? Thanks, JT
Apr 18, 2009 | Westinghouse Refrigerators
Fan is running, fridge and freezer not cold
I have a Westinghouse side by side refrig/freezer that the compressor will run but will not cool or freeze. Do you have any suggestions?
Apr 06, 2009 | Refrigerators
Over Chilling Refridgeration set on 7C still goes to 0C Digital thermostat
sounds like a bad thermostat,you can check it with a meter by putting the meter on omes,thermostat in closed position no reading turn thermostat all the way on you should get a reading if not replace,let me know-mike
Sep 29, 2008 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Westinghouse Fridge Problem
Is the fan in the freezer running? You should be able to hear it. If not, that is your problem. Check the door light/fan switch or check if the fan has power to it when you press the door switch in by hand. If fan is running, you could have a defrost problem. The defrost timer or the defrost heater could be faulty.
Nov 04, 2007 | Refrigerators
Refrigerators Logo
43 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
