Question about KitchenAid Food Mixers
KitchenAid K5A mixer stopped working. No motor sounds. Took capacitor out of circuit did not start. Installed new motor bushes. This is the pre-solid state model. Any ideas on what to trouble shoot?
    Top Expert:
  • KitchenAid Master
  • 76,846 Answers
Is the motor getting power when turned on? NUMBER ONE TEST.
Posted on Dec 22, 2016
  • Bob Albert
    Bob Albert Dec 22, 2016
    Is there a way of testing for voltage without taking more than the rear access apart?
  • yadayada
    yadayada Dec 22, 2016
    You must access the motors electrical connections, so whatever that entails you must do.
Can anyone tell me the value of the resistor in a Kitchenaid K5A mixer. I think mine grew legs and walked away. Thanks, Mike
Are there any colors on the resistor or it is missing. If you know what the voltage and current should be in the circuit you can calculate the resistor value.
May 08, 2014 | KitchenAid K45SS Classic Stand Mixer
KitchenAid k5a arcing on control board
it was stuck on high speed because the phase control board went out, your fix may not be absolutely 100% and it is now causing an uneven distribution of the electric charge in the mixer and it is arching. My recommendation is to replace the speed control board (black and copper plate) and the phase control board. i bet it fixes the problem as these are the two parts that regulate the electricity in the mixer. Hope that helps. Buy the way if you don't fix the problem and continue to use the mixer you may have to replace the motor eventually as you can cause the armature and stator to short or burn out.
Feb 03, 2013 | KitchenAid K5ADH 5 Quart Mixer Dough Hook...
Kitchenaid K45 Mixer will only run at one speed, fast
is it a K45 or a K45SS? If it is a K45 you will have to replace the filters inside and probably the speed control plate, if it is a K45SS then you need a new phase control board. The K45 is pre 1978 and the K45SS is post 1978. Your information is correct on pre 1978 K45 models that the capacitor is bad, but it might be cheaper to go garage sale hunting and find a second machine as the parts are no longer made and having spares on hand may be a significant advantage in the future, also there are a great many of the K45SS parts that will also repair the K45 mixer so it may not be a practical solution. Watch ebay regularly for K45 parts, they come up every couple of months. On the parts diagram also look for the K5 diagram as it is identical to the K45, one is a 5 quart mixer and the other one is 4.5 quart, same parts same motor same everything.
Jan 30, 2013 | KitchenAid Food Mixers
Mixer only runs at one speed
if it runs only at high speed it needs a new phase control board if the mixer is post 1978, if the mixer is pre 1978 then you will have to replace a capacitor on the end of the power cord inside the mixer. if the mixer only works on one speed that is not high speed then you need to adjust or replace the speed control plate on post 1978 mixers and the capacitor on pre 1978 machines. Hope that helps
My wife has a K5A mixer from the '70's that she loves. While I was checking the brushes, I over-tightened the brush cap and broke the threaded part it screws into. Can I get a new part?
The Brush holder caps / covers for the K5 series whether Hobart or Kitchenaid by Whirlpool (after 1986 when Whirlpool bought Kitchenaid from Hobart) will fit the K5-A they just wont be flush like the older Hobart caps. They come in black or white.
Jan 10, 2012 | KitchenAid K5SS Heavy Duty Commercial...
The capacitor on the speed switch is burning out.
I have found that the capacitor is no longer available, along with
any of the motor parts. Armature, brushes, motor end bearing, etc, are not available.
Dec 18, 2009 | KitchenAid K5AWH Stand Mixer
KitchenAid K5 Mixer Bowl Rocks Back & Forth
This may be explained with the bowl assembly. Being a bowl lift mixer, please follow the following steps to make sure the bowl is being secured before mixing:
There are the bowl-holding arms on the left and right hand side of the mixer. You will place the bowl on these arms, securing it onto the pegs.
Also, take your fingertips and press down firmly at the back of the bowl where it is resting against the base. You will hear an audible click as the bowl secures down into a spring latch mechanism on the stand mixer base, allowing the mixing bowl to sit flush and secure.
May 03, 2009 | KitchenAid K5AWH Stand Mixer
Capacitor value needed for KitchenAid stand mixer 3-C
hey had the same problem with a k5a they have them at radio shack part 272-1053 hope this works on yours
Dec 27, 2007 | KitchenAid Food Mixers
Food Mixers Logo
111 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
