Question about Microsoft Xbox 360 Arcade
I power my 360 the light just blinks and the dvd drive wont open
I just turned my console on and the green light was just blinking and i tried to open my dvd drive and nothing i cant even see my dashboard!!!! :( what should i do???
    Problem Solver:
  • 13 Answers
Could be that you have your avi cable set to hd mode and play it on a reg tv. or the cable could be bad it self. some times the blinking light is trying to tell you that its not getting the proper signle
Posted on Jul 21, 2009
What is wrong with my xbox it says error 65?
Error 65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot.
Flashing red:
1.the av cable cannot be detected
Make sure that the AV cable is correctly connected to the Xbox 360 console.
Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
2.general hardware failure
Try restarting the console.
If restarting the console does not resolve the behavior, follow these steps:
Turn the console off.
Unplug all the power and AV cables from the console.
Unplug the power cord from the wall socket.
Firmly reconnect all the cables.
Turn on the console.
If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the RoL flash red.
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
0001 power supply problem
0002 Network Interface problem
0003 Power problem could be the PSU could be the GPU/CPU, somehow the console isn't getting clean power from the power supply.
0010 over heating
0011 over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsync screws are tightened securely to the board/heatsink holes.
0012 over heating
0013 over heating
0021 DVD Drive Time out - Can be caused by problems with a firmware flash. This is also speculated to sometime be caused by a problem with the southbridge chipset on the motherboard.
0022 GPU Error / GPU Overheating
Feb 08, 2010 | Microsoft Xbox Console
Blinking green light
The blinking green light is because your 360 is not understanding that the disc tray is closed. That's also the reason that the tray comes back open. It's not getting fully closed. Next time you insert a gamepush the drive closed with your hand. You'll know the drive is closed when the light stops blinking.
Dec 26, 2009 | Microsoft Xbox 360 Console
My xbox now have an blinking green light and the tray would come out
The blinking green light is because your 360 is not understanding that the disc tray is closed. That's also the reason that the tray comes back open. It's not getting fully closed. Next time you insert a game push the drive closed with your hand. You'll know the drive is closed when the light stops blinking.
Dec 23, 2009 | Microsoft Xbox 360 Console
The power light blinks, reads open tray/close tray . . .
it sounds like your dvd drive is dead if its still under warranty you should just send it back to microsoft the only other thing you could do is buy a replacement dvd drive and put it in yourself but only do that if microsoft wont take it or you'll void your warranty
Aug 25, 2009 | Microsoft Xbox 360 Console
Blinking orange light
green light mean on
orange light means standby
red light means power failure
no light means the fuse my have blown
good luck
shaun
Jul 31, 2009 | Microsoft Xbox 360 Console
Blinking green light/won't detect disk drive
the sata cable sliped from the dvd drive (if under warranty send it back) if not open yourself and plug it back it
May 22, 2009 | Microsoft Xbox 360 Pro System Console
My Tray Door popped open after two red lights shut down console and won't close!
Here is a great page that has a step by step process for opening your unit. (they also sell parts and mod equipment)
http://www.llamma.com/xbox360/repair/Xbox-360-Disassembly.htm
You may need a new drive, but I doubt it. After you get the Xbox open, peel off the silver tape thats on the bottom front of the DVD player, unplug the 2 connections, and lift it out. Turn the player upside down and remove the 4 screws, flip it back over and make sure that the try is lined up correctly with the mechinism.
I hope this helps. Good luck and happy gaming!!
Sep 12, 2008 | Microsoft Xbox 360 Console
Dvd drive
it means spell your words out so we will understand what you are trying to say!
May 26, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Arcade Logo
208 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
