Question about Vacuums
How to remove clog of hair etc from main body of vacuum behind roller; all hoses are clear Removed back of cleaner and able to remove part of the clog next to rollers Wht can I do?
  • 77 Answers
SOURCE: Lift-Off Pet Hair vacuum doesn't lift off pet hair!
very light "stuff" like dog hair will get stuck to the filter since that is where the suction goes. it's primary purpose was to keep dust out of the motor. This is a problem with many "bagless" cleaners. A bagged cleaner keeps all dirt and hair away from filters by utilizing the bag as primary filter. If you have alot of dog hair then this may have been the incorrect choice of a vac. all you can do is brush off the filter each time you use the vac. it will still pick up o.k. even when there is hair on the filter unless you leave it on day after day.
Posted on Jun 14, 2008
SOURCE: Roller problem
I have 3 Prontos, one in each part of the house. Two of mine had the rollers stop. I figured out the problem and it fixed both. Take the roller out by turning the plastic screw and popping the plate off. Pull all debris off the wheel that turns. Turn unit on and make sure this wheel is turning freely. Take the brush and look on the end with the square part. Take some pliers and gently pull this square piece off. I had to wiggle it a little, but it pops right off. Clean all debis (mine had several small dust balls and 1 long hair) in the square part and down in where the square part goes. Push the square part back on and put brush back in unit. This fixed both of mine. Hope it helps.
Posted on Sep 23, 2008
renevacdoc
  • 84 Answers
SOURCE: vacuum roller stops turning
with cleaner plugged in and turned on, push the little reset button on the side of the lower base of vac. Remember that the brush will not turn in the upright position. release your handle and you should be in business. hope this helps. please let us know. thanks renevacdoc
Posted on Jul 24, 2009
SOURCE: Brush roller won't turn
On my Dyson, there is a brush reset button on the top right hand side (if you are looking at the front) that you can press to reset the brush. I was vacuuming and too lazy to move a toy and this worked for me once I freed the rope from the brush.
Posted on Mar 16, 2010
  • 693 Answers
SOURCE: How to repair roller on Vacuum cleaner
it migh be the belt.stretched and hardened from heat replace and try again
Posted on Feb 02, 2012
My Oreck XL is shooting dust out from the roller when I try to vacumn
This is a sign that the bag is full or there's a clog in the air flow piping. Check behind the brush for clogs and remove if there is. Open the cloth bag, remove the paper bag, and check inside the tube. If no blockage is visible, drop a coin or marble down the opening and see if it rolls out. If not, there's a clog that needs removed. You can use an air pressure hose to blow it out..
Feb 16, 2011 | Oreck XL Ultra Bagged Upright Vacuum
I was hoovering up pine needles and it has started to shoot the needles back out from the middle of the brush. I have emptied the oover and removed hair etc from around the roller but it is still...
This is an indication that there's a blockage in the airflow system. Check the hose, power head tube, and behind tank filter for clogs. For the hose and PN, you can detach the hose and drop a coin in one end. If it doesn't roll out, there's a blockage and it needs cleared. Try using a broom stick to push the clog out from the tank end. Or place PN end of hose to the tank in port and turn on vacuum. This should clear the hose.
For the PN, drop a coin into the hose connection. If it doesn't drop through, there's a clog in the PN tube, probably at either the elbow or behind the brush. You may be able to clear it using longnose pliers to pull needles out from the hose end, or try pushing out with a long, dull object. A wooden spoon or spatula handle will work fine.
Jan 13, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
My Dirt Devil Vibe bagless vacuum started giving off a burning smell. The brush roller was jammed with hair. I immediately shut it off and cut the hair out of the rollers with scissors until it turned...
It's more likely there's a clog in the hose somewhere, possibly where it connects to the power nozzle. Detach hose and check the PN.
If there's no clog in the PN, detach hose completely from machine and try to drop a marble or coin through the hose. If it doesn't fall through, there's a clog that needs removed/cleared. Hold PN end of hose tightly to tank of vacuum and turn on. That may be enough to **** the clog through. If not, use a canister or shop vacuum to blow the clog out.
Nov 13, 2010 | Windsor SR12 Sensor Bagged Upright Vacuum
After we change the bag, it still gives us a red light
Greetings,
The bag full indicator on most vacuum cleaners is not completley fool proof. Most vacuums will just register a loss of suction, and they will then illuminate the bag full indicator, whether or not the bag is full.
If you've changed the bag, and the machine is still indicating a full bag, then this could mean one of two things.
1. Dirty Filter. According to the part diagram for your vacuum, there is a filter underneath of the vacuum cleaner bag (Bissell Part Number
203-1013) that is there to protect anything from getting into the motor. Since the filter is located before the motor, most refer to this as a pre-motor filter. Sometimes if this filter is really dirty, it can cause the vacuum to loose suction, which will also cause the bag full indicator to incorrectly display. Simply clean this filter by running it under warm water, then allow it to completely dry before replacing it in the vacuum. While the filter is out of the vacuum you can turn it back on and test to see if the light is off now that the filter is out. If the light goes off, then you have found the problem! If the bag full indicator is still on, please see the next possible problem.
2. Clog In the Vacuum. If the vacuum was run with a full bag, and when you removed the bag, the bag was completely jammed full, then your vacuum cleaner may be clogged somewhere. When the bag is packed full of dirt, the vacuum continues to try and put more and more dirt in the bag, even if it's full. Sometimes the dirt will even start accumulating inside the hose as it has no other place to go. The first place you should check is the hole that you connect the bag to. Remove the new bag that you installed and examine the hole that the bag connects to inside the vacuum. Can you see anything stuck here? If yes, do your best to try and dislodge it. If you're not able to visibly see anything here, your clog may be inside the hose, or even in the base of the vacuum.
If you have another vacuum cleaner this will really help you in clearing the clog. With the other vacuum, take the suction hose of the good vacuum, and connect it to the hose on your Bissell (still while the bag is removed, and the bag housing door is open). When you connect the hose of the other vacuum, can you hear a difference in the motor? Does the motor start running at a higher pitch when it's connected to your Bissell? If yes, then you've narrowed it down to a clog in your hose. If you can feel suction from the other vacuum through the hole that the bag connects onto, and the good vacuum's motor doesn't change noise when connected to the Bissell, then your clog is in the bottom section of the vacuum. You can sometimes stretch out the hose of the Bissell while the other vacuum is attached, and this will dislodge the clog.
If you don't have another vacuum, simply remove the hose from the Bissell completely. I believe that there maybe 2 screws that hold this hose onto the back of your Bissell, simply remove these two screws, and remove the hose. An easy way you can clear clogs is to take the hose outside, and use a water hose that has a pressurized nozzle on it, and spray down the hose while holding the hose of your Bissell vertically to allow gravity to work its magic. You can also stretch out the hose of the Bissell to get maximum benefit of gravity and the water.
If the clog is in the lower part of the vacuum, it is usually right at the suction port behind the roller brush. This is the most narrow part of the vacuums suction intake in the lower part of the vacuum, and is prone to clogs. Simply remove the four screws on the bottom of your Bissell to remove the bottom plate. Look behind the roller brush to where the suction port is to see if you can see any clogged debris.
If this doesn't help clear your clog, or fix the bag full indicator, I'd really like to try and diagnosis this further with you. Please just use the Clarification Request or add a comment and explain what happend after trying these things I mentioned above. I'll be more then happy to try and assist your further. I really hope that this was helpful to you. If you found this helpful, please be kind and rate my repair by clicking the thumbs up icon in the review.
Thank you very much,
Chris J.
Mar 21, 2010 | Bissell 3522 PowerForce Bagged Upright...
Doesnt ****
If the vacuum sounds like it usually does and still doesn’t pick up, you probably need to replace the belt. To check this, turn the vacuum on and lay it down sideways. Check to see if the roller is spinning. If it's spinning, turn the vacuum off. Stand it up and turn it back on. Do you hear the roller spinning. Some belts stretch over time. If the roller was spinning when the vacuum was on it’s side and stops when the roller has some pressure on it (your carpet), change the belt.
A clogged vacuum cleaner usually sounds "clogged". The noise the vacuum normally makes will seem muffled. First, Unplug Your Vacuum. Then change the vacuum bag or empty the dirt cup. If the bag is filled up more than halfway, this could reduce your suction. Throw out the bag. Look at the area that holds the dirt cup or vacuum bag. Remove any debris. Look for a filter in this area. If you find a filter make sure it's relatively clean. A clogged filter will shorten the life span of your vacuum. Make sure your filter is back in place or replaced, and reinstall the vacuum bag or dirt cup.
A lot of the current style upright vacuum cleaners have attachments and a hose on board. If you have a vacuum hose on your upright, pull it out like your going to vacuum with it. Look at the area you removed the hose from. Remove any debris. I recommend wearing gloves, and try not to use any sharp tools like a needle nose pliers that might puncture your vacuum hose.
For the final step in this vacuum cleaner repair, place the vacuum in a position where you have a birds eye view of the bottom plate. You can usually see if there is any debris that requires removal.
Here is a link that will take you to a site that shows how to access your machine to change belt or look for clogs.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps
Jan 30, 2010 | Hoover U6311-930 Power Drive Bagged...
Won't work cleaning tools
There is a clog somewhere.
Most likely at any bends or where the hose enters the main body of the vac.
Make sure it's unplugged.
Romove the hose, stretch it out straight and see if you can see through it.
If there arer any hard piped bends try running a pipe cleaner through it to see where the blockage is.
Again, it's likely where the hose base meets the vac housing.
Needle nose pliers com in handy for pulling out string, hair, rig fibers pet fur etc.
Dec 06, 2008 | Hoover U5264-930 TurboPower Bagged Upright...
Suction loss when handle is tipped back to clean carpet
can any one help,
Our Dyson Animal vacuum has plenty of suction when it is upright and the attachments are being used off the hose, but when the handle is tipped back to begin cleaning carpets the beater head is getting no suction. As the handle is being tipped back you can hear what sounds like a flapper valve in the body of the vacuum opening and then all the suction just goes away.
Nov 19, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
KENMORE pROGRESSIVE WITH DIRECT DRIVE SUCKING NOISE
I had the exact same problem. The port is a relief valve to prevent the motor from burning out if the hose/bag are clogged. Check the main hose from end to end after removing the 3 screws that hold it to the body of the vacuum near the handle. If that's clear then it's almost certainly clogged in the short tube that goes from the beater bar housing to the hose extension (where the flex tube attaches). There are two ways of going about this.
Option 2
(the way I did it) -- Lock the base on the upright position and turn the unit over. Unscrew the 12 or so screws in the black base. You'll need to depress the release pedal when removing the screw at the end of the pedal. Once you have all of the screws removed carefully wiggle the base loose. You do not need to remove it completely to access the short flex tube. Clean it out and replace everything in the opposite order from how you removed it.
Option 1 (what I would do next time) -- Cut a wire coat hanger and make a small 1/2" hook at the end. Bend the straight section into about a 4" radius arc leaving plenty to handle at the end opposite the hook. Carefully snake the hanger down the tube and pull out the giant clump of hair and dirt that's clogging the vacuum.
cheers -- eric
Nov 15, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Hoover eite rewind vacuum has blocked airflow, how do i fix?
Is there suction at the end of the hose, if not then the blockage is in the hose, unhook the hose and dig out the debris, if hose isn't blocked, then clean out the filters, if they get clogged, then air can;t flow thru them and you won't have suction. If you have suction at the end of the hose, then it is clogged down in the nozzle asm. there is an inlet by the brush roll and it comes up to where the hose plugs into. Clean the clog out.
Jan 03, 2008 | Hoover U5507900 Elite Rewind Bagless...
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Vacuums Logo
22 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
