Question about Refrigerators
E388 freezer,door not closing for last 8 inches manually without pushing it
Door Tech
  • 98 Answers
SOURCE: Door opens alittle then closes but not back all the way
If you have a Chraftsman/Liftmaster:
1.Check to see if the door is running correctly.
A. Run the door down and pull the emergency release. See if the door will run easily by itself.
1. If it runs hard by hand try lubricating the rollers and hinges with silicone spray or some form of lubricant (not WD 40)
2. If the door is heavy and falls back to the ground, you probably have a spring issue (either broken or needs more tension) in this case call a professional door repair company in your area.
B. If the door runs fine then check the up and down force on your operator (the box that hangs from the ceiling and reads Craftsman). If the light(s) on your operator go from front and/or back, the force adjustment screw is on the back of the operator. If the lights are on the sides of the operator then the force adjustment screw is on the right side (looking from the back of the operator and facing the garage door). Turn the light blue adjustment screw with the up arrow to a higher number.
C. If this does not solve your problem the top bushing could be going out of your operator. Open the case and see if a lot of black filings are on the top of the big gear. If so the gear assy. will have to be replaced part # 41C4220A
Posted on Jan 04, 2009
SOURCE: Bottom freezer door/drawer won't close all the way on one side.
Remove all the food from the freezer and then the drawer from the cabinet. Now using a silicone based lubricant, lube the tracks up real well. Be sure to clean the tracks first if gunked up. Make sure nothing small fell out of the basket over time and is laying on the floor in the rear of the freezer section. Once done, you should be fine.
Eric Campion
Posted on Feb 21, 2009
  • 331 Answers
SOURCE: Side by side doors uneven at top
Hi Carol,
Interestingly enough, I answered a similar question just the other day. Maybe there's an outbreak of lazy factory technicians who "forget" to tighten the hinge brackets? Hmmmm. Makes on wonder...
Anyway, it's easy... The door alignment adjustment is done at the top hinge. Pull up a step-stool, then remove the hinge cover. Under there you'll see three screws, I think they're 5/16". Loosen these (since your door has dropped, they're probably already loose), then lift up on the door handle to align it with the other door... while keeping the door aligned, tighten the hinge screws (and put alot of torque on 'em to keep 'em from loosening in the future). Now just replace the hinge cover and your done!
(pssst!... don't forget to rate me, will ya? C'mon, throw me some love.)
Posted on May 29, 2009
  • 13 Answers
SOURCE: The refrigerator door does not close with a tight
adjust doors on the top of machine the hinges move to adjust and leval them. hope this helps
Posted on Jun 06, 2009
  • 189 Answers
SOURCE: kenmore 790.49073400 oven door won't close completely
Hello- You are on the right track. The hinge assemblies are 'sprung' or bent out of shape. Replacing them is pretty easy, so you can do it yourself. Four screws on each side. Be careful, these springs can snap closed and bite ya. Use the little pins that come with the new set to lock hinge so this doesn't happen. Let me know if this info helps- have more if needed- Thanks- Ed
Posted on Mar 19, 2010
Rather than self-closing, our refrigerator doors each stop about 4 inches short, requiring a strong push to close. Is this normal or problematic? No kidding ~ 41 views and no answer?!
it would seem as if the doors need fixing or that the icebox isnt leaned back enough to self close...but that is just my IMO sadly...
Dec 28, 2016 | Samsung Refrigerators
Bottom freezer door will not stay closed.
Check the hinges and the door seal. If you need parts Sears service center online has a great parts locator for kenmore
Feb 18, 2014 | Hardware & Accessories
I have a Fisher Paykel E388 upright freezer which freezes in the bottom couple of drawers but not toward the top. The motor is running and fan spins when you open freezer but stops when door is opened. Any...
Cold air always settles on the bottom Check the door seals above the cold area . Check for broken seals ,cracked seals and seals that are not touching the frame. Place a thin piece of paper between the seal and the frame and close the door . If the paper falls or is easy to pull out that may be your problem. Test at various points around the door.
Apr 06, 2013 | Refrigerators
My LMX289885T/02 LG refrigerator's left door will not close without manually pushing the long bar into place first.
Guessing your talking about the heater. Sometimes the sprin comes loose, in the end probably will have to change it out
Sep 08, 2012 | LG LMX28988 (27.5 cu. ft.) Bottom Freezer...
A neighboring car pushed a shopping card into the rear portion of the front drivers side quater panel -- that 6 to 8 inch portion behind the wheel-well. It's pushed in up to 1 1/2 inches max and 8 -10...
you can try removing the quarterpanell,& straightening it,but you are better off getting the offending neighbour to pay a body-shop to fix it Taking the door off is very involved &you will have to re-attach it, (not easy)
Apr 09, 2011 | 1997 Subaru Outback
Hi, the freezer door will not stay closed. need to push the last 1/2 inch, sometimes it pops out again that 1/2 inch. nothing in freezer to stop it closing. Door need adjusting?? Greg
If the refrigerator is not properly leveled the doors will not close easily, the front side should be a little bit higher than the rear side. If that's how it is, then the issue is with the hinge lever that seems to have gone bad and should be replaced. Hope this helps...please post back for further assistance.
Apr 06, 2011 | LG LSC23924 Side by Side Refrigerator
Magic Chef refridgerator with small built in freezer model#MCBR 980W. Defrosting instructions unclear; red button suppose to be pushed in for defrosting the small freezer, How is it suppose to actually...
I just defrosted my cooler and looked at the manual. It says that you should do it when the ice is only a 1/4 inch thick. Then it will do it without any effort. Well of course i waited till it was about 1 1/2 inches thick. The defrost button does help though. i pushed it and waited 3 hours and that loosened up the ice around the box. Then used an ice pick, flat head skrew driver, and a painters 5 in 1 tool. I cleaned the inside of the freezer fairly eaisly and let the rest of the defrost process clean the top and the sides of the box which i couldn't reach.
Jun 18, 2009 | Magic Chef Refrigerators
Changed freezer seal,bottom half of door won't close tight
tough job there , you must get a hair dryer and carefully heat gasket until it seals properly. some gaskets take hours to get to seal right.
Jun 10, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Eric Campion
Feb 21, 2009 | LG LRFD25850 French Door Refrigerator
Refrigerators Logo
21 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
