My VCR tape brakes. One wheel spins & the other doesn't so the tape brakes. Help me!
    Top Expert:
  • Televison & ... Master
  • 75,797 Answers
You need to take it apart and see if you have a broken drive bet first, if the belts are ok then it may be a motor drive issue.
Posted on Dec 22, 2016
My VHS tape is also stuck--tapping didn't help
does ur vcr have a idler wheel or gears (between both spindles?) if its an idler wheel, with rubber band it commonly can go bad. their a pain. unfortunately there may not be a replacemant part. if nopt, inspect the belt for cracks or glazing. it needs friction to spin the spindle to take up the tape being played. or if ejecting, to wind the tape back in the cassete. take off the cover of vcr and watch. if the right side wheel of tape is not turning while playing, theres ur problem. the tape is instead floating every whichway. another possibility could be a belt on the right spindle. if any bands need replacing, use an ordinary rubber band ,. should work just as good
Jul 31, 2009 | Televison & Video
Emerson EWD2004 vcr eating vcr tapes
This is caused by mechanical problems in the VCR. Depending on the age and maker of the VCR, the take-up reel in the cassette is driven by a gear, a belt or a rubber wheel. This isn't happening properly in your VCR, so the tape is piling up inside. Given the low cost of replacement combo players (I don't think you can find just a VCR these days), it's not worth having repaired. You can expect to spend $60 to $100 on a repair for this kind of trouble, assuming there are even shops still willing to take the machine in.
May 13, 2009 | Emerson Televison & Video
Tape Problem
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through. The pincher wheel & capstan are not used during a fast forward or fast rewind, so if your tape is getting caught during the FF or RW and not Play, it's probably not related to capstan & pincher wheel.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
3. There's also a brake pad that is designed to grab and stop the tape wheels from spinning when you hit stop. If those pads are worn, the wheels will not stop fast enough and the tape will continue to feed (spool) out of the cassette and not be taken up by the other wheel.
So when when you hit eject, the excess tape that should have been wound up tight in the cassette before the eject sequence, is getting caught inside the player.
Let me know if I can be of further assistance to you.
- Jim
Jun 27, 2008 | Mitsubishi HS-U776 VCR
Vcr eating tapes
Let me know if you need more information as to where to purchase these parts.
- Jim
Feb 12, 2008 | Philips Magnavox 20MC4304 20 in....
VCR problem in EWR2OV4
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle. The pincher wheel can become worn and/or dirty from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out than can be wound up. You can try using a re-grip solution on the idler tire or replace it.
- Jim
Jan 29, 2008 | Emerson EWR20V4 DVD Recorder/VCR
SANYO VCR VWM-900 playback is jerky
Your post/description indicates that possibly the brake mechanism of the supply reel is acting up. A typical VCR has 2 reels inside that spins the tape. The left side is the supply while the right is the take up. If the brake (on the left/supply) is engaged (even partially), then the entire mechanism would have a hard time pulling the tape around the video/audio head and would partially be stretching. This would represent itself as jerky audio/video in most instances. There would possible also be a low screeching sound coming from the machine/tape. An indicator would be stretched tape - there would be uneven edges of the tape.
Since this is an electro-mechanical problem, perhaps your best course of action is to seek the services of a qualified video machine technician.
Alternately, it may be possible to loosen things up by first fast forwarding the entire tape and thereafter rewinding fully before you play it.
Hope that this be of some help/idea. Pls post back how things worked out or should you need additional information.
Good luck and kind regards.
Dec 07, 2007 | Sanyo VWM-900 VHS VCR
Tape get stuck when I playback after fast forward the tape
Yes, that is a possibility. Also check the mechanism which activates the brakes- is something sticking or broken? A dried or sticky grease can cause the brake mech. to hang up. A broken or cracked lever or slide piece could be your problem too. Late VCRs of the last 10+ years are rather breakable, unlike the older ones which were often built like tanks, comparatively speaking.
Sep 26, 2007 | JVC HR-S7600 S-VHS VCR
Eats tapes
3. You didn't say if the unit played ok. There's also a brake pad that is designed to grab and stop the tape wheels from spinning when you hit stop. If those pads are worn, the wheels will not stop fast enough and the tape will continue to feed (spool) out of the cassette and not be taken up by the other wheel.
- Jim
Feb 20, 2007 | Symphonic WF803 DVD Player/VCR
Tape plays for a while then stops...
play it till it stops when it ejects see if you can spin the wheel with your finger or if it feels like it is hung up try a different tape se if the problem goes away if it does not go away sounds like you need to get the heads cleaned or get a new VCR or better yet get a dvd player/recorder you can get one with a dvd/vcr and record your vhs on to DVDs
Jan 02, 2007 | RCA VR702HF VCR
Cassette stuck in VCR
You are almost on the right track. did you look where your finger was? what happened was you did not allow the blocking a photo sensor which mimicked the clear part of the tape and this caused the eject to take place. What was happening in your case was the arm would come fully out and the sensor would sense no tape so the VCR shut off in a trouble condition to prevent damage from ocurrin.
Oct 28, 2006 | GPX TVR950 VCR
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Electro Med Services...
